Everything posted by True2Blue
Opening an auto repair and modification shop in maple valley
Everything is going smooth
New shop tools & supplies (need list too)
Yea no good on the 'reznor' heater its natural gas and thats the pipe that broke under ground.. i was thinkin about modifying a wood stove and hangin it there
New Group!
- hi from washington, 1st 1993 loyale few problems hope to fix
Hey man.. it COULD be a fuel filter but by the way it sounds you may not have one your gas tank can have a vacuum/not vent right.. if you want to find the filter simply follow the fuel line.. These cars are stupid simple or ill just take 5 minutes to make a pic for you Looks like this from the side I'd just pull the thermostat housing and check er out.. with a ghetto fan rigged up and no thermostat (low/no heat from heater core) ill promise you that your radiator is plugged up and that was a cheap "fix" look for a radiator and remove the rigged fan heres a parts link http://seattle.craigslist.org/oly/pts/2058059213.html- New shop tools & supplies (need list too)
Good lesson/advise. ill look at it in a few minutes BUT its copper plumbed down like 6 feet under the shop so id have to cut the line somewhere or BUY pipe and run a new one off the machine, the fans were disconnected? im hoping there isnt an over heating issue or a smokey fan motor.- New shop tools & supplies (need list too)
Like I said its not mine, not mine to fix, not mine to mod. I don't wanna get kicked out cause I cant follow simple requests/instructions. I know its eatin you up inside and trust me I asked about it but im told to wait for an electrician to come out....- New shop tools & supplies (need list too)
its on order but cash needs to flow a bit better before i spend more money. my old shop had 2 of them and life was amazing this air piston lift is okay but bad for tranny jobs- New shop tools & supplies (need list too)
GD- Way easier said then done, like i said my land lord sucks she said "we will get to it" as in "dont touch" ill see if i can sneak a splitter off the line for the pressure washer (its on a well too) to the heater. ill take pics you seem very interested. Mugs- i use the purple power on the floor and the degreaser on the vehicles with my little nifty electric pressure washer that also has a foam nozzle. As far as storage ill be building mine once the welder comes in. its an awesome design 'no opening drawers or scrambling for wrenches' Everything is on magnet strips.. youll love my design for the air tools and the moisture catch BROKE on me the glass cracked so ours is on order but i need air.. im also extending the petcock valve so i don't have to reach under the tank everyday. there is a regulator its brand new. I currently run a business out of here. but it doubles as a personal benefit since I run it.- New shop tools & supplies (need list too)
i tried! but its a radiator and the water supply line broke under the concrete so thats a no go... the landlord sucks. she tried to tell me i couldn't carry my pistol on the property, told me not to call the cops when theres suspicious car in my driveway at 2am... she wont pay for new shop light bulbs or any shop appliances.. she just plain sucks:rolleyes: That "candle" works fine for now I just don't wanna spend money on another heater:lol: My boss was talkin about buyin a waste oil heater its 300,000 btu- New Subi.... *Updated*
how does it feel when you turn?- New Subi.... *Updated*
Bring it over:lol:- New shop tools & supplies (need list too)
happens often believe it or not and everything bought is used weekly if not daily. i WANT a coolant flush machine but cant seem to buy it.. i keep sayin "no only what i need to do the job" im busy though will all makes an models even 2010's:eek: (weird i know)- New shop tools & supplies (need list too)
I know right! its freezing at times but im not gonna spend the cash on it since i dont own it:rolleyes: im tryin to talk the "landlord" into buying it so i can install it:)- New shop tools & supplies (need list too)
ADDING Monthly Just purchased: Floor squeege Multimeter Micrometer 3/8 6" & 12" extensions 3/8 IR Titanium impact Engine hoist Cutoff tool Tranny jack 1500lb tranny/engine brace/stand engine stand 225 amp battery charger Compression test kit 1/2 impact socket set Lug nut flip socket w/anvil Genisys EVO 2009 OBD2 scanner Two ReelTec hose reels with 50' hose Matco micro OBD2 scanner Tire check and fill guage Spark plug gapper Timing light Whats next/on the way? Hobart Ironman 230 MIG Welder Rim Clamp 5045E tire changer Complete NEW set of sockets, ratchets, ratchet wrenches, hammers, screw drivers, torx bits, allen bits, pry bars, all the much needed hand tools. Body tools Paint booth and tools Complete IR titanium impact set Pipe/Tube bender Whats needed and not on the way yet Hot water pressure washer Floor cleaner (stripper/buffer like what they use at walmart i found one in a pawn shop) Floor jack and stands (heavy duty) Parts cleaner/washer ill add more when my brain is working properly I know this isnt much compared to some of you guys but im tryin NOTE: this isnt a show off attempt its an invitation I have no friends :lol: HEAT!- Alternator Problem.........
through out my 5 subarus and 3 2000watt+ stereo systems i know the symptoms of a bad regulator and yea if your over 14.7 or so your heating things up. my volt meter in the cluster would jump all they way up then level out randomly at first. i waited for money to come in to buy an upgrade then the vm needle would rise and fall with the rpms. my stereo 'deck' harness would get HOT and things would cut out like lights and speaker sound- Lets see your before and after photos
Before After- Wacky Heater Problem
Type: 87 GL wagon Vacuum lines.... your welcome to bring it by sometime ill have a look at it with you- 84 brat need help?????
Check your Grounds:)- WASHINGTON subaruERs
Had 3 guys stop by so far, nice guys they are welcome over any time. I hope to see some new faces soon. NEW tools finally delivered 2 new 50' air hose and reel units Titanium Ingersoll Rand 3/8 impact wrench Misc matco sockets and extensions (lug, axle and o2...) Genesis Master scan tool (does everything except make coffee) Welder not yet here ordering ratchet wrenches and more impact/air tool gear soon- Just saying hello
I bought NICE bumpers with front and rear receivers and spare tire swing gate, tail light guards and a roof rack with high lift mounting points made by HTi for $550 earlier this year he does good work check the Vendor section for his thread- New Subi.... *Updated*
the lifted F-350/Chev 350 yota guys will $hit when they see this bad rump roast rompin around- WASHINGTON subaruERs
hey ill be stickin around the welder didnt come in but the spools did... go figure and the engine diagnostics tool (man that's a nice piece of equipment) anyways if yould like to stop by again to hang out or do some actual work that would be fine.. and i could really use a wood stove im sure you would understand if you worked here at night haha anyways just shoot me an email or gimme a call or w/e im not going to fort Lewis tomorrow so ill be around i could use some help at the shop too so thats something we can talk about we could go shoot a few rounds sometime too- WASHINGTON subaruERs
my buddy from subaru called me up and i left to go see/help him at his work sorry about that. i left my number here in the thread but here it is again. 360 918 2404 ~Kody And I don't live up at the house i (my "boss") rent the shop for the business (I don't really like my landlord and I doubt she would be of any help) Ill be working on the Toyota tomorrow. but your welcome to come over im up at 7am and I get off work at 4pm my boss will be coming out but its cool I run this operation.- WASHINGTON subaruERs
tallwelder i cant send you messages your inbox/outbox is full hey man no worries i havent had one person come out yet. and i dont mind if anyone uses my lift what so ever. and i dont feel like anyone is a user cause i posted about it and offered my shop to local usmb members. just having people around is payment enough im am totally down for the engine build anytime i have done a few. i have everything i need to know at my finger tips and my tool guy (33 year mechanic/technition) whom always gives me help when need be- WASHINGTON subaruERs
that sounds amazing! ill be around alot this next week probably stay the night alot i have 3 more engine swaps (got all three calls today) Welder and master code reader coming monday/tuesday - hi from washington, 1st 1993 loyale few problems hope to fix
