Everything posted by rweddy
Actually fog light shine down and if properly aligned and working add a lot of view to the side up close down low on the road. Driving lights are the ones that blind other drivers. I love mine, I live in some what rural Colorado and they add tons of visibly to my commute. Plus the help with ground blizzards and other adverse weather conditions.
Kind of.First off, the AWD systems used in Subarus differ, depending on what transmission you have. Automatic-equipped Subarus use a computer-controlled hydraulic clutch pack, similar to those found in an automatic transmission, to transfer torque to the rear axle when the sensors detect a 20% difference in axle rotation speeds between the front and rear axles. Normally torque is split 90 front/10 rear. Not really all that different from most of the other AWD systems. Manual-equipped Subarus use a viscous coupling, similar to a limited slip differential (and certain full-time 4WD transfer cases) where under normal, dry circumstances the torque is split 50/50 until the physical difference of the rotational speeds of the axles causes the hydraulic fluid in the coupling to heat up to the point where it acts as a clutch, forcing the two axles to turn at the same speed. It's basically the sameas full-time 4WD without the extra low gear. It can transfer torque front and back almost 100/0 or 0/100 if necessary. Better than most. BTW Honda's system is not very good. Go test a CRV, they are front wheel drive until the real slips then the rear kicks in but by then it is too late.
I have heard of this issue before. Because of the design and the way the front sunroof sits it is very common to get hit by rocks. A local sunroof shop here in Denver told me they replace lots of these from rock hits. You would be surprised how far ahead a car can throw a rock from when traveling at highway speed.
2.5 have head gasket issues. So just keep $1200 in the bank for when they blow. Unfortunately with the 2.5 is it not a matter of if but more of a matter of when. But other than this issue, these are Awesome cars, you will love it. I like my 96 OWB best of any of the many Subaru’s I have owned. Plus I think the limited has the cold weather package, I love this option on mine.
I agree with 99obw. Once you have a set of snow tires you will never go back. AWD helps you get moving for sure but snow tires improve handling, braking, etc. I also find some “cheap” tires are great. I got a set of these tires from discount tire, this is a store only brand made for them by Goodyear. Tires I was able to talk them down to $65 a tire and they have been great in all conditions, wet, snow, dry, etc. But after seeing the amazing improvements of my wife’s Honda with dedicated studded snow tires, I am also going to get an extra set of wheels & snow tires for my car in the very near future. They have made such an amazing difference in her front wheel drive I cannot wait to see AWD and Snow tires.
Wow this is the exact opposite of my experience. I have owned several Toyotas landcruiser, 4runner, truck, etc. I have never owned vehicles that parts have been so expensive. Alternator for $600 fuel pumps $900 plug wires $130 etc. Maybe it is different here in the states but Subaru parts are way cheaper than the Toyota’s and Hondas I have/used to own. I rank them like this from most expensive to cheapest Toyota Honda Nissan Subaru
