Everything posted by tractor pole
Tranny swap
As most on here will tell you, the search function is your best bet... The linkage is different at least for the 4wd shifter, that is all that I can tell contribute.
Lug Nuts!
IIRC lug nut torque is 74ft/lbs at least that's whats called out in the FSM M12 range should be 70-80 ft/lbs
5MT D/R difficult to get out of 4hi
I looked today for the ID tag but it was unreadable, but I think it is working as advertised. Since I did not have an owners manual that covered the D/R transmission I assumed it worked like any other "shift on the fly" 4wd, but I know better now.
so I think all is ok, I tried it today on snow covered road and noticeably easier to shift. thanks for all the input, I think a crisis has been averted. Ben
Snow pics thread. . .
crappy cell phone pics, first pics on here of the finished five lug swap. I will take some better ones tomorrow.
I hadn't realized that it would bind up that easily... I will have to just get used to it. thanks for the input everyone. I am still curious if the JDM transmission actually has a different final drive ratio than 3.90.
I should also add that it feels like a brake is dragging when "bound up". once back in fwd it feels normal.
it was on wet pavement , I know that's not the same as snow/ice or gravel. the diff ratio in the car is the original, 91 Loyale that came with a 3AT, 3.90 is what is on the tag. this is not the original trans, I swapped it from a 3AT so I do not have the owners manual since you couldn't get the Loyale with a D/R... Do you know what the JDM ratio is? I have looked and looked and all I can find is 3.90 for the PT D/R.
the tires are all brand new 195/60-15. Driving in a straight line, yes. As I described in post #2 I can't see the linkage being out of adjustment, that is why I was thinking different ratios in the rear diff and trans.
I guess I should add that when it is not running shifting from fwd to 4 hi and back is easy but it seems that after you have driven in 4hi it gets difficult.
So I have been able to actually test the 4wd in my recently installed 5MT D/R and found that getting from 4hi to fwd is more difficult than I think it should be. once in 4hi it will shift to 4lo and back with no problem, the difficulty comes when you shift from 4 hi to fwd. I have tried all different scenarios: engine on, off. clutch in, out. rolling or stopped. the only way I can get it to go back to fwd is to roll slowly 2-3mph clutch in in neutral and force the lever down. it makes a loud banging noise when it disengages. I have only done this twice, I am trying to keep from damaging it. I am pretty sure that all 5mt D/R are a 3.90 final drive, the rear diff in my car is a 3.90. The trans has 23 spline axle shafts so i am 99% sure it is from a non-turbo car. Is it possible that a JDM trans (from japanese engines) could be a different ratio? thoughts? Ben
XT6 Rear Caliper Bolts
oh yeah, I meant just the EJ bolts won't fit. sorry bout that.
here is the answer, NO. the EJ bolts are completely different. I had to get them from the dealer, $11/ea
My new Project: Leone Turismo
looks like a rear fog light on the left side, would be a cool thing to have.
My '92 Landcruiser: Safariwagon-II
Looking good! reading this makes me really want a FJ80!! OME lifts are very nice, looks like it was a pretty straight forward installation. can't wait to see what it looks like with the rear done as well.
'88 EA82 FSM Wiring Section
looks like Dave beat me to it.
I have a copy, but i wouldn't be able to get it scanned until late tonight or tomorrow morning. Ben
1999 Phase II EJ22 into 1987 GL Wagon (carb)
Very nice, I am planning on doing this swap down the road. thanks for putting up the time to make the spreadsheet.
Seattle area machine shop recommendation
I must have overlooked this one. Thanks for the info. Ben
New clutch slips, how to float gears?
I think the pressure plate side of the clutch disk would hit the flywheel if you put it in backwards, from what I remember when I did the clutch in my EA two weeks ago...
Is it possible to install a rocker arm without pulling the cam carrier?
the hardest part would be to get the rocker arm to seat or unseat from the hla, I am not sure you could get the valve to compress enough to slide it over the ball end. but hey give it a shot.
New guy from WA
Welcome! More locals, cool!
Loyale 5 Lug swap; my list...
I will keep that in mind, I haven't driven it too much(less than 5 miles) since I got it aligned. I am driving it to work today.
I was told that my steering rack was toast but I am not sure of it is because of the tie rods or just a bad rack.
Good call, I noticed they bottomed out, but they didn't move or make any noise. Any ea81 or a specific year/model?
