Everything posted by svxpert
gasket- oil separator cover turbo only 11832aa001 85-88 11832aa002 88-90 engine numbers 557731-up part number is superceeded they only use the 002 now.
Board Member Engine Rebuilders
svxpert replied to Myxalplyx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
<<I've got an ea82 with bad rings in one cylinder. It was a used japanese import engine, and I put 20,000 miles on it, none of which I would consider abuse, always keeping the oil up and never overheating it. >> so you know the complete history on the engine, and the previouse owner did't overheat it and changed the oil on regular intervalls? from what i know about imported jap engines are Japan has some law/rule that you don't own a car with more that x amout of miles on it. so if thats the case, what would be the incentive for a person in Japan to really take care of the engine, being that he has only x amout of miles to drive it? maybe i'm wrong but with regular maintaince rings should last forever (almost) in a suby engine. now i'm stating in general, theres always that occasional exception. thanks -
we just rebuilt a EA82T engine and its sitting on my bench looking for a home. i'm just waiting for parts to come in for a ER27 rebuild for my XT-6. -
what engine do you want to re-build? why does it need piston rings? did you run it without oil or overheat it? i've never seen a suby engine with bad rings before with just regular wear and tear. -
I just picked up a 88 XT-6 (5speed, diff lock). when i start the car, it runs between 1800-2000 rpm for at least 5 min. then it slows down to 1200- or so. that seems a little high? is there a idle screw on this engine? thanks for the help in advance.
its in the trunk hanging next to the rear speakers.
i posted pics of the differences last month. do a search and you'll find info.
I can't be done. Think of it this way. Subaru pays this 3rd party guy to do this job under warranty. You get a 12,000 mile one year Subaruwarranty on this new job from the 3rd party guy because he used Subaru parts. The headgasket goes bad again and Subaru pays this guy to do the job again (or does he really do it again?) see how this is could turn into a scam, thats why Subaru doesn't do it.
<<with rallyruss's honda spring upgrade for the rear>> whats this? i haven't heard of this. can you tell us more, i'll need some rear suspention soon. thanks
How about a turbo?
RX WTF engine issues...a solution
svxpert replied to WJM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
<<I applyed sealer to directions.>> where did you apply sealer to? -
<<the Spyder Intake was pretty complicated, so the standar intake is installed for now, the spyder conversion to come sometime later.>> can you give us some info on the problems you came up with when you tried to do the intake? thanks
i'm the one selling the xt body kit. i'm looking to get $400 for it. the kit is brand new and unpainted. subarueast@yahoo.com
Rear diff gear ratios from Forrester...
svxpert replied to StormTrooper's topic in Old Gen.: 80's GL/DL/XT/Loyales...
depends on the tranny. auto or manual? -
Anyone running aftermarket or custom intake manifold?
svxpert replied to Dante's topic in Old Gen.: 80's GL/DL/XT/Loyales...
<<Dennis, Aren't you supposed to be at work right now???? ha ha Must be nice. Let me know if you wanna go grab it, I will call and see how much he wants, either that or we can pull it and I can set it aside for a dark and stormy night..........>> Dennis doesn't need one, he has one already. I'm the one that needs one for my project.....maybe we can work something out. -
just use a screwdriver and a socket.
WRX I/C in 87 Turbowagon
svxpert replied to Hondasucks's topic in Old Gen.: 80's GL/DL/XT/Loyales...
does the I/C fit under the hood ok or do you need to modify the hood any more, other than fitting a scoupe of course? to me it looks like it fits perfectly under the hood. nice job. -
cam shaft difference in the EA-82?
svxpert replied to svxpert's topic in Old Gen.: 80's GL/DL/XT/Loyales...
thanks for the info. i was just trying to squeeze some more hp from my engine. -
while tearing down my EA-82T and EA-82N/A engines, I was wondering if there was a difference (in HP) between the two engine's camshafts. I checked my parts book and there is a difference in part numbers. I am in the process of building a EA-82T from a N/A shortblock and turbo heads and trying to put on a spider intake manifold. I was wondering if the 2 different cams will give me any extra HP? thanks in advance.
