wentz912
Everything posted by wentz912
  1. Yes they will. the hump comes back down to non-outback roof lines at the rear hatch.
  2. I seriously NEED that hood!
  3. wentz912 replied to rpholz's topic in Members Rides
    Thanks very much, shows some good data for the frankie builds!
  4. wentz912 replied to rpholz's topic in Members Rides
    So which line is who on the dyno chart? Sorry if I suck at reading them.
  5. The general AT2s are pretty affordable. Not sure what the largest tire that will fit under a first gen with a strut lift is, but I LOVE the 27x8.50x14s under my second gen with OB struts and Forester springs. That, and they were $430 delivered to my door from discount tire direct.
  6. Lucky for him, he's MAYBE 30 minutes from at least half a dozen reliable, big name shops.
  7. Would it be too outrageous to ask for a turbo, single port header? I'm gathering parts to turbo my NA EJ22. Can you handle it?
  8. In my opinion you're better off using the foz springs than just about anything since they are pretty widely available, AND you can use all four instead of mix/matching a set.
  9. 98-02 Forester springs on Outback KYB GR2 struts is your best bet and will net you the 2" of lift you are after. Other than that, spacer blocks are your only real option AFAIK. And they don't offer anything other than being able to stuff more tire under her.
  10. Baja is based on the Legacy platform, so compare your suspension to that and go from there.
  11. Sent you a pm to not clutter up your thread.
  12. Any interest in some JDM headlights and some H&R springs for this monster? I've got an extra set of both since I decided to lift my second wagon instead of lowering it.
  13. Bratman18- Does your friend have the information for his source on them still? It'd be worth looking into at least. Gloyale- First off, this wagon won't be much of a "wheeling" rig, just a mild logging road bomber and stuff like that. As far as two hands on the wheel goes, that's never been a requirement while wheeling my SA'd 4runner on 37" tires and locked F/R. Maybe our "wheeling" styles are different, I'm not sure. I've wished for a third foot more than once while running manuals in the woods though. More on topic though. I'm convinced that, with the right design the existing cable clutch systems on either an EA D/R manual OR an EJ AWD manual could be adapted to a motorcycle type hand lever operation. It WILL have to be a custom one off part, but I have access to that sort of tooling.
  14. So is this procedure as simple as having the parts in hand, jacking the car, drop drive shaft and fluid, pull tail housing? That seems waaaaaaay too easy.
  15. I'd love to hear the story! want a manual in this thing baaaaaad
  16. Pedals all curve wrong direction, less space to work with, brackets are dissimilar. I've been able to compare photos of each and I just don't think it's worth doing. Plus, I like making one off stuff AND I'd be able to drive two footed in the woods
  17. You need some sweet JDM headlights for this monster
  18. So, I have a 1996 Legacy Postal Wagon in my possession. I would like to make it a five speed versus the standard 4EAT that, to the best of my knowledge, ALL of these cars were. The body is a little rough on this car, so the current plan is to lift it and use an EA D/R 5 speed transmission, unless I happen to fall into a smoking deal on an AWD D/R box. However, my biggest hurdle at this point in time is that the pedal sets for RHD five speeds are incredibly difficult to come by, and are rather cost prohibitive when/if I could get my hands on one. Soooo, with that being said I think I might be able to craft a hand operated clutch lever, similar to that used on motorcycles, but with much more leverage required, as well as a longer throw, that could be mounted on the shifter, and allow me to use a 5 speed transmission in my AT equipped car. I haven't yet started designing or sketching yet, but the idea popped into my head this afternoon, and i thought I'd propose it here. What do you guys think?
  19. I hear mosquitos are the state birds out there.
  20. Anything new ever happen with this car?
  21. Dang! I should almost have you do my two cars! They both need paint pretty bad.
  22. So all right hand drive, manual transmission legacy pedal boxes use a hydraulic clutch actuator versus a cable system?
  23. Beliefs don't tell me anything, I need to hear from someone that KNOWS. I am just going to use a transmission from a same year car, so it will still be cable clutch so no concerns with mounting a master or slave cylinder. Really just need to know about the pedal box. Found a guy a few hours from me That has a JDM Legacy GTB that's a five speed, waiting to hear back from him with pictures of his pedal box.
