Everything posted by shortlid
Happened to my Mom again this morning then went out. Brake warning light on, e-brake would not shut it off. This time the brake fluid level was a little lower so I am having her bring it to Prestige Imports Subaru In Plesantville, NY. It is closer to her work and I feel safer if she drives it the least posible miles before this situation is solved. She parks on a gravel driveway so seeing a brake fluid leak is imposible. I think some thing might have nicked a brake line!!
Same thing happened to my Mom's '03 GT Legacy sedan when heading too work today. She called me from down the road. She said the red BRAKE idiot light came on. She tried releasing the e-brake a few times with no change. I had her check the brake res. and the fluid level was fine. When she shut off and re started the car the brake idiot light went out and stayed out?? Only thing I can think of is stuck fluid level sensor in brake res.?
OK, in my Mom's '03 GT Legacy sedan the intake for the engine is RIGHT over the cap for the P/S tank! I guess I have to remove the intake. Also how do I get the cap off? Does it pull stright-up or spin off? With the 30k service I like to suck out the old ATF and put new Dextron III in. Is there a filter on this system? Should the PCV valve be replaced at 30k as well on the EJ253??
Ok, part of the 30k service I will be performing on my Mom's '03 Legacy GT sedan with AT is a diff. and traany drain and refill. What is the capacity of Mobil 1 for the front AND rear diffs (I know the rear diff of the GT is Limited Slip) does that make a differince :-\ ? When I drain and refill the 4EAT with the "sport shift option" how much Dextron III will I need to refill the tranny? BRAKE bleed, will this '03 GT have the same X pattern to flush and bleed the ABS system as my '98 Legacy L wagon? I have the procedure for bleeding the ABS detailed in an old Endwrench mag.
