Everything posted by subyrally
intake manifold pwns me
subi81, that looks almost exactly like what we are dealing with. so it just takes leverage, hmmm. it certainly is stubborn though.
so yeah, iam trying to figure out how to get the intake manifold off of an ea82t, which ive done many times before. but this time, i have a broken bold, the one behing the thermostat, next to the coolant passage. the bolt head brok off like 1 mm below the surface of the manifold. i think its the crud thats built up in the bolt hole that is holding hte manifold down, but we couldnt get it to come off of the heads at all. the driver side would come up just a hair, but the passenger side seems to still be firmly attached. im sure that if we can get hte manifold off of the heads, we can get the bolt out without much effort, but yeah, the manifold is stuck. has anyone else had to deal with the manifold getting stuck in this manor? we needs some help.
5 stud/lug conversion - Crossbred Performance
ea8? wet dream?
UAFC: Ultra Air Fuel Controller
and this is why Will is the man!! not that i ever lost hope for hte ea82t, but now i know there is more of a chance to do what i want to do with mine when i get it built up. on a side note, when did you move to mt. airy? i have family in that area.
TD04 swap questions
good luck and take lots of pictures.
Stealership? Part 1: Platimum Plugs? '05 OBW
subyrally replied to Juan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXin our area, ngk plugs range in price from $1.50 - $10.00 depending on what you are after. the regular platnum plugs are like $3 each. where as the iridium plugs are $7 and the "laser platnum" plugs are $10. the benefits of being an advance auto retail parts pro. granted, i quit there in march. i highly reccomend hte ngk iridium plugs. they are 6 times stronger than platnum and give a spark. as far as subaru saying that platinum should be changed at 60k or less, i think thats bs, that is the change interval on your standard copper core plugs. accourding to ngk, platinum is a 100k plug, the iridium plugs should last even longer, but i havent found the exact info on that yet. either way, i reccomend the irridium plugs, ive personally had very good luck with them. on top of my use of them, every customer that i sold them to from advance, came back a couple weeks later to thank me for the heads up on em. thy always said that they got better milage and a little more power (butt dyno)
TD04 swap questions
the oil lines should line right up, and the coolant lines might need lengthening, but its just hose, so you should be fine.
looks like you could actually benefit from it. if you are running larger injectors and an adjustable fpr, the ecu most likely isnt going to keep up with the fueling, either running too rich or too lean, at least with with afc of some sort, you can manage the fueling of the engine. it gives you the opportunity to shorten or lengthen the injector pulses, depending on your needs. only reason i didnt have one on my rx was that no one i knew of made one that worked with the old school suby maf's. personally, i would like to run megasquirt. but for the moment, if this will help keep the engine from leaning out on me, ill take it. hey Will, thanks for posting this. ill look into it, when i get my car on the road and get the ea82t built back up, ill let you all know ohow well it works out, unless someone else beats me to it, which im sure they will cause im still poor.
How did you break your first Subie??
i wouldnt say that i broke my impreza, i blame that damn deer hanging out on the highway. $4300 in front end damage. samshed the lights on the driversside, buckled the hood, crushed the grille into the radiator, pushed the fans into the belts, cracked the radiator, and a few other little things here and there. and that was at 65 mph. i didnt feel the impact at all. granted, i actuall accellerated when i saw the deer since i had no chance to acoid it and i didnt want it in my lap. the car did what it was made for, saved my pretty face from deer butt.
TD04 swap questions
yeah, if i get another ea82t equiped car, i am going to try out my idea of running the twin tube bit over the rear axle but keep it 3" from the turbo to that point, and then ill have just a regular 3" performance muffler after the axle. im sure its doable, just need to find the time to try it, and a car to try it on.
Brat living in New Hampshire...
nice brat. also diggin the vw's. i wouldnt mind getting ahold of an old camper, could have fun with one of those.
GL-10 odd no spark
h mm, just thought of this, but i hadthe same issue with my rx a few years back, i had checked the fuses and they were all good, but the ignition fuse, i believe the third from the left on the second row of fuses, wasnt hitting the contacts in the fuse box, double check the fuses and check the connctions for em as well.
TD04 swap questions
i never did bottom out on speed bumps, that last flange is just before the axle. the only issue was that it was the lowest place on the car uner the axle and i had to be careful of rocks and potholes when i went to the mountians. it is at stock height with 15" pugs and 205-50-15 nitto tires. rarely ever had any issues with ground clearance, then again, it was usually all about picing a line when in places that could be an issue. i was thinking about trying to get something like the perrin twin turbe exhaust for getting under the axle, that way instead of one large pipe hanging down, there would be two smaller pipes side by side under the axle into a collector attached to the muffler. that way, could also opt to run the pipes over the axle, i think anything less than 2" will fit without hittingthe axle like my old 2.5" exhaust did. not sure if ill have another rx or not, but if i do, i think ill try it out. the brat is going to have different exhaust when i am done. what do you guys think of that?
TD04 swap questions
i know that the hangers had to be relocated and i think a few spots needed a slight bend added to em. the down pipe had to be lengthend about 3", but that was causeof my turbo mounting. basically, i just took it to my local subaru tuning shop, talked to the guy that runs the place and said that id like it to fit the car a bit better.
TD04 swap questions
where in md were you living? actually, i do:grin: or as connie (bucky92) says, its a maxwell house coffee can on there, hey, i just noticed that the bumper of my impreza is in that pic, haha, i need sleep.
TD04 swap questions
it was an ebay special 4" bellmouth into a full 3" all the way back. took some work to get it to fit, but it was worth it. here is alink the an ebay auction selling the same kit that i used on mine. http://cgi.ebay.com/ebaymotors/02-06-WRX-STI-UP-PIPE-3-STAINLESS-DOWNPIPE-CATBACK_W0QQitemZ120193911265QQcmdZViewItem?hash=item120193911265 good luck and take lots of pics of your progress.
TD04 swap questions
hmmm, thats odd, maybe my car was cursed or something. idk, when i mounted the turbo to the stock manifold, pulled the stud and welded it back where it was needed, the top of the trans was in the way of the turbo outlet. just barely. i remember that it was a pain to get things liined up right. granted, in the pics i posted, the first one is with the manifold that i tried to build myself, the second on was after i had a local shop build it. rotating the turbo slightly made it really easy to work on and route the plumbing. the downpipe was from an ebay turboback that i got for my car, listed for the wrx/sti. but the dp had to be lengthend about three inches and the top section rotated to match the turbo.
TD04 swap questions
i would highly reccomend getting a custom manifold made up for the td04, it would also help to raise the tubo up a little bit and move it backward about an inch past the stock location. i found that if you try to mount it in the stock turbo location, there are a few bits that get in the way. mainly the transmission. that was my set up, worked well with the stock intake manifold and the spyder manifold in the pics.
Need some opinions on this car
personally, i think they have no idea of the actual value if the car. for $2k, i can get an impreza with no rust. granted it might only be a 1.8l impreza, it would still be about that much.
What Cam grinds avail for EA82T ?
i was looking at building a rally style engine for my rx, when talking hte people at delta, i found out that 260 is their mild street grind and what i wanted, 272 was closer to the rally cam that i need.
New Boy from Oz
ill see what i can do for you. hey, thats 4 days before my b-day.
87 rx rear wiper ?
yeah, tricos are ok if you really cant afford anything else, just never use roberk blades. absolute trash. i swear by bosch personally. i like the icons, but at $20 each, i have to wait till im working again. at least they last about 18 months for me, lol, worth the extra $$.
87 rx rear wiper ?
it should be the same style connectors as the front wipers, two screws holing on the wiper blade. i suggest that you go to your local parts place and spend a bit to get the bosch blades, i think that the 17" and 19" blades come with an adaptor that you bolt to the arm that lets you use the more common hook type blade attachents.... good luck.
New Brat Owner here from Texas
welcome to the club, and hve fun with your brat, hopfully its in better shape than mine.
New Boy from Oz
welcome to the club and that 22b is sex on wheels. i have always loved that car, pity i could never afford one, lol. if you are looking for a hatch, there is someone selling one in pennsylvania for like $300us. if you are ever in the washington dc area, be sure to let me know, im about 50 miles west and always down to meet new people.
