Everything posted by 1-3-2-4
Wait.. not all of them are located in the passenger side beside the glove box.. I know on my 97 OBW it's right under the kick panel right under the steering column. Not sure where the switch over was but I guess it became too much of a pain in the rump roast to get to where the old location was.. I know that's true I ended up with a bloody hand.
Sorry late to the party.. It's the Head Gaskets. Mine did it back in April as the video lists.. I finally changed them in Aug. Been fine ever since then if it's not already been said it's how the sender for the gauge is because of no coolant running over the sensor to cool it down then When the piston is not pressuring the radiator it starts flowing normal again. I took many pictures of the old gaskets never made it to the oil passages (thankfully) About 3,000 Mi on the new gaskets.
god damnit I've been looking for a rear spoiler for my outback for the longest time hardly anything on ebay.. and the dealership is a true ripoff.
ugh.. well it was easy to find the breaks.. slowly moving along... 12v... then it's gone.. SO many of the lines are in poor shape it had to been a tint that was removed forcefully.. I hope I can clean up the look of the rear since I used painters tape to mask the color is lighter so when removed you can see on the outside rear.. I only started on the passenger side since that's where the (+) is. this is just part of it..
haha next time I go off road I'm going to mount the ECM up higher myself.. learned the hard way last year with the '95 Legacy.. I guess muddy water came in around where the tube for the AC drain line goes out and.. well the ECU got soaked good.. I was on the trail with nipper and neo and I got out of the car and walked away with the car still running and that's when I heard it die... long story short neo saved my rump roast had the exact same ecu in his car lol.. it would of been a painful way back since it was like 70 some miles from home.
So with this last storm and it getting colder I should of did this a little sooner.. but to get to the point.. I'm trying to figure out how to find a break in the lines.. OK.. if the wire had a break in it it should show (lets say 12 V) 12 V most of the length until you hit the break and it goes to 0 V right? On a wire that's ok it starts at 12 V one end and tapers off on the other end right? it's painful because I think pretty much all the lines have issues.. must of been a tint or something on the rear glass? I do get battery voltage to the tabs and a bit down the wires but it's hard to say for sure where the breaks are.. I do know you never see any defrosting action in it's current state.. i did buy a repair kit but not sure how well it's going to work.
1997 Outback
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
that's odd.. I never heard anything like that before.. Today we got our first frost and it was 35F out this morning and my car had no problems. -
Stick the red probe from the volt meter to the post on the top of the alternator and stick the other to the battery negative terminal and if you don't see 14V with the engine running the alt is week or shot. Also another test is to set the meter to AC and see if it's outputting AC (should not) when running.. that can cause odd things to happen and nasty things. if the belt was replaced it does not mean much.. in order for it to not work the belt would have to be so loose that the PS pump would squeal before the alternator did.. besides the PS would feel heavy when turning if the belt was loose.
Sounds like the alt went.. Mine did that really bad when I drove down to VA.. it only did it once when I was leaving work but I thought I could do it again but nope.. in the end I think the alt output wire was grounding to the alternator body and did it in.. I should of known because I changed all my dash lights to LED's and they were flickering like mad in the days it got really bad and it burned out a good few of them..
