3
Everything posted by suberdave
awesome!!! good work! lets see some pics of the install? -=Suberdave=-
is it poss. to put xt6 in 88 dl wagon
suberdave replied to jimpon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
it is possable and it has been done before. now my $0.02. if your going to go throught all that trouble, find a good EJ and put that in there. i think it would be an easyer swap -=Suberdave=- -
the last few days, with all the rain, my car has devolped a small leak on the drivers side floor board. it seems to be coming from the drivers vent control. you know the one that you can select from A/C to vent. has any one seen this before? and how did you fix it? -=Suberdave=-
main difference between the two swaps
suberdave replied to 7point62fmj's topic in Subaru Retrofitting
i beleave the frame rails are to close together. so slight modifacation will have to be done there. i have not done a swap on an ea81 but i have done one on an ea82 and it was an easy swap. -=Suberdave=- -
many people on the board have that same scoop. i have one just like it. works awesome. most of us bought them on ebay for around $20.00 -=Suberdave=-
Steering wheel time. *pics, WRX installed*
suberdave replied to WJM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
here is the wheel i just put on my car. its a Nardi Torino wheel and shift knob from the 96 STI to match the power train. -=Suberdave=- -
steering wheel swap? IMPREZA wheel in a GL
suberdave replied to suberdave's topic in Subaru Retrofitting
well i did mine today. will take pics tomorrow. fit nicely. but had to do some modafication to get the turn signals to cancel and to get the horn to work. its a Nardi Torino wheel and shift knob from the 96 STI to match the power train. -=Suberdave=- -
How to keep rain out of your Snorkel
suberdave replied to FlyB0y's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i dont. i fegure it is water injection, up the comp ratio. havent had any problems in the last 3 years. -=Suberdave=- -
so you want to convert a legacy? or impreza? everything after 96 was AWD. if your talking about an EA82 then the newest you will find is like 92ish. if your talking EA82 then i have everything you will need. PM me if interested.
Washington Noob Sayin Hi
suberdave replied to flakey's topic in Meet n' Greet. Your USMB Welcome Center
welcome. hope you find what you are looking for here. i know i did, and so much more. -=Suberdave=- -
Anyone have installation instructions for PK lift?
suberdave replied to Tin Soldier's topic in Off Road
here is the directions from my kit. it is many moons old. but i think its still the same. if this is copyright infrengment. let me know and ill take it down. *edit as per requested * -=Suberdave=- -
EJ20g into GL10 Wagon almost done ~EDIT DONE~
drove about 50 miles in town today running around. and about 15 on the freeway. went through emissions. passed with flying colors. like 18HC at idle and 24HC at cruse. but overall it went awesome. had to put the stock air box on, the CAI i made was causing it to run a little lean. -=Suberdave=- -
!!!!DONE!!!! code 33 was VSS. found out before i got the front clip the person in Japan had some sort of something hooked to the VSS. using one of those little clip things. well, i pulled the ECU and the wire was broke right at the little pink clip. used a good butt connector with heatshrenk on both ends. so now we know the VSS from a 1987 or newer GL will work with a EJ20 ECU... took it for a drive, wow. has way to much turbo lag. but once spooled up it goes very good. tomorrow new fuel filter and injector cleening, than emissions... -=Suberdave=- -
How To Keep Your Subaru Alive pdf file
suberdave replied to baccaruda's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i put it on my server also http://www.suberdave.com/subaru/HTKYSA/ -=Suberdave=- -
is it possable to swap a steering wheel from an impreza into a GL wagon. i think the GL steering wheel looks silly. could i use the wheel from my 96 Impreza front clip? do i need an adapter or will it bolt on? i guess i will try it if i dont hear word one way or the other. -=Suberdave=-
took this thing out on the freeway yesterday. got a code 33 VSS sensor not working. so looks like its back to the drawing board for the VSS. then i can drive it again. but it runs awesome. (before the light) -=Suberdave=- -
on my way out the door now to get a STI cat back Exhaust for it. then i can say "done" not "almost done" -=Suberdave=- -
took the wife for a ride today. she started screeming and looking for an "OS" handle. and i was only shifting into 2nd gear. still no exhaust. so im sure the neighbors arnt to happy. but i have an appointment for tomorrow morning to get some. gonna be lots of fun. i cant wate till tomorrow when i can take it out on the freeway. -
i didnt have any trouble i couldnt get solved. for the cross member i used the front and rear sections from a 88 XT6 and the center peace from the WRX. it bolted right up. then the front section of the driveshaft had to be shortened. 55mm. then to use the rear diff with LSD and matching ratio. i had to order custom CV races to mate the WRX inner cups to the GL axels. (i have an extra set if you need some or you can call RCV Peformance part# 184-068A) and then theres the clutch issue. thats a whole nother chapter. you have to use the clutch/brake box from a USDM WRX. not to much moding to be done. then drill a few holes in the fire wall for the clutch master. and bolt it all up. -=Suberdave=- http://www.suberdave.com/subaru/glwrxt -
took this bad boy for a test drive today (in the neighborhood, no tabs yet). man dose this thing boost some balls. when this thing spools up. you better be holding on to your shorts. kinda loud though. no exhaust yet, just the down pipe. deffantly a little adrenaline rush for me tonight. -=Suberdave=- http://www.suberdave.com/subaru/glwrxt -
maybe a little more on what its doing? when it dose it? and do you mean power as in "get up and go" or "electrical power"? -=Suberdave=-
got my converson races form RCV Peformance. worked awesome. i was able to drive it around the back yard. but could not take it on the street yet. i still need tires for the rear. should have them tomorrow. so they will be the same size. but it goes like crazy in the wet yard.
