Everything posted by suberdave
Anyone ever replaced their key's battery??
i did that. LED works now. but light is still useless. but cool none the less... -=Suberdave=-
XT parts wanted
im not sure what a "blinker globe" is, maybe i call it something different. but i if you have a pic. i may have one. i have all the lights from an XT6 and i beleve they are the same... -=Superdave=-
Trashwagon 7!
looks good. now the fun starts... -=Suberdave=-
Let's see your USMB People Group photos
its Washington, dosnt mean 2 different days, could have just been an hour or two later. -=Suberdave=-
ea to ej quick question
fits in an EA-82 body with no mod. but would need mod for EA-81. there is about 3/4" - 1" on each side. fits like it was made to go in there. -=Suberdave=- http://www.suberdave.com
ej20t into an L wagon
here is some info on how i did mine. some of the problems i had. and just so no one else has to say it "there is no such thing as a EJ20t" it would be an EJ20G or EJ20K. http://www.ultimatesubaru.org/forum/showthread.php?t=50903 if you have any questions shoot me a PM. -=Suberdave=-
Loyale needs more power, EJ22T swap?
here is a pic of my wagon with WRX front suspension with 17" wheels and 40 series tires on it. i think it looks awesome. but thats because its mine... -=Suberdave=-
Crank and Cam sensor Trigger Pattern?
here is an old post, from a while ago, maybe it will help http://www.ultimatesubaru.org/forum/showthread.php?t=21628 -=Suberdave=-
Emission question for state of washington
5 years and newer and 25 years and older do not have to be tested. -=Suberdave=-
Which Motor would the experts use(DR RX, wjm,??)
i did an EJ20G from a JDM 96 STI, bought the whole front clip. after the price of the clip, the car, new wheels and tires, exhaust, and other stuff i am in the whole thing less than $3500. could have done it for less, but i bought "NEW" 17" wheels and tires. the trick is "get a good deal on a compleet front clip" -=Suberdave=- http://www.suberdave.com
to run WRX front susp. you will have to go to a 5 lug, for the knuckle to take the calipers. and you will have to go to a 16" poss 15" wheel. i tryed 14" wheels on my WRX converson on my GL wagon, didnt work. so i went with 17's -=Suberdave=- http://www.suberdave.com
Quick question about the tacho with EJ20G swap to -86 Loyale with carb
when i did my EJ20G swap the tach was the only thing i didnt get to work. i used a GL-10 with digi dash, but could not get the tach to work. i even bought a autometer tach adapter for use with the coil on plug ing. setup. still no luck. so i just went and bought an aftermarket tach. now it works fine, and i have a shift light. if you have any luck. let me know. i still would like t hook my tach up, if i can. -=Suberdave=-
EJ22 retrofitters - motor mounts
i 2nd that. not a problem. just dropped in. -=Suberdave=-
Moral Dilemma!
then keep it. if you want to make it AWD send me a PM and i will hook you up with all that you need to make it AWD. or junk it... -=Suberdave=-
Subaru RX Type RA?
here are some pics of my GL Wagon STI type RA if you will... www.suberdave.com/subaru/glwrxt -=Suberdave=-
Hi/Low Transfer
look in the center consol right behind the shift stick. do you have another stick that says 2WD 4HI and 4low? if not you dont have a hi/low transfer. if you have a button on top of your shift knob. then you only have 4 hi. -=Suberdave=-
Nissan 280ZX Turbo Injector Swap *DONE PROOF*
awesome. ill keep my eye out for one. -=Suberdave=-
Don't forget those idlers!
been there done that -=Suberdave=-
^%$#^%$ Swaybars!
i have hard that the GL-10 wagon rear sway bar is the largest sway bar ever put on an EA82, even larger than the XT6... anyone know for sure? -=Suberdave=-
EJ20t - VSS needed?
correct. with out it. the ECM goes into limp mode and sets a VSS code 33. and will not go into boost with out cutting fuel. and yes the 87 and later ea82 VSS will work. -=Suberdave=-
EJ Steering Wheel on my ea81?
looks like it will... -=Suberdave=-
try sending a PM to Qman, he put a WRX wheel on i beleave it was his brat. it could be a defferent car. but he would know. -=Suberdave=-
Driveshaft length
as long as they are both 5sp's yes they are. if i remember correctly. the manuals are all the same and the autos are the same. -=Suberdave=-
maybe Im crazy, but is it all necesary?
i beleave that was in the land of oz. some of there early EJ's came with the dist. hole in the left side head. but none of the US EJ's did. if i remember correctly -=Suberdave=-
ej20t(g) in an xt
you can keep the shift handel with the EJ trans. but the EA trans dosnt hardly hold the power of an EA engine. wouldnt even try it, get an EJ trans and diff. the drive shaft will have to be shortaned. and the rear axels will have to be modded. but not hard to do. -=Suberdave=- http://www.suberdave.com
