'97 Legacy... buy some time or scrap?
Fairtax4me replied to pwbset's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy guess would be the sliders are rusted up and seized. The inner pad was doing all the work and the outer pad never moved. Either way, Remove the rotor and file/sand/wire wheel the majority of the rust off of the braking surface, or grab a decent rotor off a junkyard car. The amount of buildup on there will chew off half the new pad before it ever gets to clean metal, and still may not entirely remove all of the rust from the braking surface of the rotor. Clean up the sliders (remove all old grease/rust/dirt and re-grease with silicone Hi-temp brake grease. You can use the little packs that are $2 or whatever on the counter at the parts store. Clean up the caliper brackets where the pads it with sand paper/ wire brush and put everything back together with a new set of pads or decent pads off a junkyard car if you can find some. Autozone has a set of pads for under $15 that will work better than what's on there.
Prolonged High Idle Upon Start
Fairtax4me replied to brendanr279's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe "door" in the idle control valve will sit in different places depending on temperature. The ecu also cycles the valve opening as the engine is running to contole idle speed. After a while the valve gets crudded up and sticks. A good shot of Throttle body cleaner through the large hose usually cleans it up.
wobbly balancer
Fairtax4me replied to the3rsss's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe outer section of the balancer is falling off. You can grab it and wiggle it when it gets that loose. Replace it now before it falls off and gets flung into the radiator.
Need location of fasteners on Pass door Legacy.
Fairtax4me replied to SubeeTed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPretty sure there are only two screws. One behind the door release handle, the other under the door pull. Just have to pop the little covers off of the screws to get to them. The trim on the gusset seal (the black triangle) just prys off with a screwdriver. Then the rest of the door panel has plastic clips around the edges that pop loose easily with a trim tool.
Decreased fuel economy after installing transmission cooler
Fairtax4me replied to DM6156's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck your receipt, see what weight of oil they put in the engine.
Oil Burn - Change Interval?
Fairtax4me replied to axgutt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI wouldn't worry about it too much. As long as you're feeding it fresh oil when it needs it it should be fine. The filter will play a bigger part than losing/adding oil, and you do at least change that when it's supposed to be.
My Crank Pulley fell off!
Fairtax4me replied to NorthCoast's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI looked it up once it's like 87 ftlbs. Seems like it should be enough, but I don't want to be the one to find out. I torque them down pretty good with a breaker bar.
Digital Multi Meters
Yeah, but your Fluke will probably never die. Id love to have a nice Fluke meter with all the gadgets and gizmos, but my Craftsman $30 DMM works just fine for me. Has selectable and auto ranging, duty cycle/frequency test, diode test, and has a spot for a temperature probe, and of course all the usual stuff. I guess I've had it about two years now, no complaints. I had a smaller pocket multimeter with the leads that fold up into the case and that worked great for about 5 years until the wire to one of the leads frayed inside the insulation. I could fix it if I could find a new lead for it. http://www.sears.com/shc/s/p_10153_12605_03482139000P?sid=IDx20070921x00003a&ci_src=14110944&ci_sku=03482139000
alternator/charging questions - new update 4/16
Fairtax4me replied to heartless's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere's a huge one under the dash where the wire harness comes through the firewall. It's way over in the corner over top of the drivers kick panel I think. Did you happen to check inside the plug on the alternator for corrosion/dirt/crud?
repair or replace wrecked rear quarter panel
Fairtax4me replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMost U-pull-it yards don't want you out in the yard cutting corners off of cars. The ones that pull stuff for you will usually cut stuff up. Know anybody who works at a body shop? I see quarters/thirds/halves of cars on flatbed trucks going to the shop down the road here all the time.
Simplifying the EA82 Hitachi hose nightmare
Gotta love those Japanese engineers. Vacuum everything! What a mess! I'm not much help but you do appear to have a loose hose on the upper left corner of the pic.
Fairtax4me replied to NorthCoast's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you can manage to cut/grind/hack of the key off where it's messed up you can bolt the pulley on. Just as long as it goes on flat that's all that matters. The key doesn't do anything anyway, just lines up the sprocket, the bolt holds everything together and in place when it's tightened.
Fairtax4me replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, that'll buff right out. Honestly I don't see any way of fixing that without cutting and welding. If you're really patient with a sledgehammer and a block of wood you might be able to get it "Good enuff". Getting the tail light to fit back in is going to be the trick part. But you're in WV right so, one of those square trailer lights wont look too out of place?
Fairtax4me replied to NorthCoast's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you got enough battery you can probably make it home, but that's a long way to run on just the battery. You have the pulley and bolt, do you have any tools? Is this an auto or manual transmission?
Hydraulic lash adjuster maintenance
Fairtax4me replied to glkiller2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you can get the valve cover off you can get the rocker assembly off. It does take a bit of wiggling because there are two alignment dowels that it has to be worked off of. I said somewhere earlier in this thread to make sure the cams are unloaded before removing the rockers, that's not 100% necessary, but it makes it 100 times easier to re-install the assembly because you don't have to worry about warping or twisting the rocker shaft, or have to fight with valve spring tension while trying to get the bolts threaded in.
98 legacy won't crank.
Fairtax4me replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPretty much the same exact thing happened to my 95 a few months ago. I had let my mother borrow it for a day and she got stuck in the parking lot at the dentists office. She calls me and tells me the car won't start, it does nothing when she turns the key. Not even a click. But the radio and lights all work. I come over about 45 minutes later, jump in turn the key once and it starts right up. Hasn't done it since.
02 Impreza Kospeed Radiator?
Fairtax4me replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI guess you'll be the first here. :-p Never heard of them myself.
Fairtax4me replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXInhibitor switch is on the passenger side of the transmission. You can check that with a multimeter before replacing. I'm not at home or I would look up the circuit wiring to see what else there is in between the battery switch and starter. Seems to me there is a relay somewhere in there.
02 wrx steering wheel swap
I happen to like my "fugly" wheel. But I digress, did you get the plugs for the airbag and cruise/horn wiring with the wheel? The airbag wiring is not something you want to screw up. It should be separate from the horn and cruise wiring, and probably has a yellow plug. You WILL need the proper plug for the airbag module if the one in the car doesn't fit. The others you can solder together, but you should't solder wires directly onto an airbag module.
EJ22 Crankshaft Woodruf Key bent
Fairtax4me replied to jpwoody's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou night be able to pry the key out with some vice grips. Just make sure the crank bolts is good and tight when you reinstall the pulley and you won't have problems.
2005 Impreza gx timing jumps around
Fairtax4me replied to tazza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe ping stops because the knock sensor is picking it up and retarding the timing. The amount of advance varies depending on engine rpm as well, so I'd this is happening at 1000 rpm the timing may be normal. But it should advance smoothly as engine speed increases, then generally reach a peak in the mid rpm range. Manifold pressure. Thats the MAP reading I was asking about. It looks like your intake vacuum is too low. Seems to me that it should be around 55-65 kPa at idle, but I'll have to check on that.
Tires
Had Cooper Life-Liners on my Lincoln and I wouldn't buy them myself. (they were on the car when I bought it) They did seem to last a long time, but they liked to hydroplane even in light rain. And they left something to be desired when I really needed to stop. Hydroplaning is no fun, not being able to stop when you really need to is no fun.
Spring Washer, Rocker Arms
Fairtax4me replied to amhawks's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI found mine firmly encased in the grime in the bottom of the oil pan. I doubt any other pieces will go anywhere. Things is, I only found two halves of the washers. The other halves I think must have got stuck in the valve cover and were found when someone changed the gaskets at some point.
Fairtax4me replied to tazza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've just assumed this whole time that this is a non-turbo engine is that correct? I've seen up to 42 degrees of timing advance while driving my 96 Ej22, so 48 is probably in the ballpark for that engine. The USDM cars never got the high compression engines that they used in other markets. Engine tuning can vary quite a bit. I don't think most people use engine cleaners that often. A clean engine runs better though.
Fairtax4me replied to amhawks's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnd one is missing in that picture! Apparently it's a common thing! There is supposed to be a washer on both sides of the center mount. They keep the rocker arms in place over the oil feel holes in the rocker shaft, and keep them from rubbing against the cylinder head and center support. The rocker shaft is incredibly easy to disassemble once removed from the head. Remove the lock bolt from either end (the one on top of the end support) and all the parts on the shaft will slide off. Lay them out in order so you can put them back in the proper places.
