Everything posted by rxleone
Help required on how to get rid of "gurgle" from dash (air pockets in cooling system)
First gen pre facelift EJ22 legacy sedan. Does anyone know how to get rid of the air pockets in the heater core? I've done the burp thing several times to no avail. Gurgling sound occurs under acceleration (while coolant is getting pushed around I suppose) and while it's not a major, I'd like to get rid of it if I can.
1st gen Legacy sedan - how to replace passenger side door lock solenoid?
Hi all, I have a 89' Legacy sedan, EJ22. My passengers door lock solenoid is shot, as far as I can tell. I have power to the solenoid but it does not work when I unlock the drivers door. I need to replace it, so I went to the junkyard to have a look and see what I could get. I managed to get one out, but it seems like it's attached to the door lock itself, and doesn't come apart. Has anyone had any luck changing these out, and do you have any pointers or documentation on how to do this correctly? I don't want to half-rump roast it and have to fix it again in the near future.
Gas gauge not working 1990 Legacy
rxleone replied to Kenneth1948's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've had this problem on my 89 sedan Legacy, gauge would be erratic on long trips. Pulled right hand (US passenger side) sender and tested continuity with a multimeter. Several dead spots. Went to the junkyard armed with the multimeter, pulled sender units until I found one that went the whole range with no breaks. Installed in my car, no problems in two years.
Ea82 transmission with ej20 front casing.
Check out the EA 2 EJ swap - it's a stickied thread at the top of this forum. I don't think you can swap bellhousings, but you can buy or make an adaptor plate to go between the EA transmission and the EJ engine.
auto to manual swap in a 1998 Subaru Legacy outback wagon
rxleone replied to mightGETaSUBARU's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think it's more for fuel maps so the motor doesn't die when you push the clutch in when coasting.
Subaru Diesel Spotted!
rxleone replied to soobenthusiast's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI still don't understand why the US doesn't have these as standard - we have a huge amount of Subaru diesels rolling around on NZ roads. The sedan model gets something ridiculous like 6.7l/100km (35mpg) on average.. I haven't heard of any reliability issues with the EE20 either - which is always a good sign. I work as the stock controller at a car auction house so I see them and drive them quite regularly. They feel like they have a remarkable amount of torque for a two litre turbo diesel.
90 Legacy won't idle cold
rxleone replied to Redcap's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think it has something to do with the 90 - 91 IAC being a two-wire affair while the facelift 92 - 93 model was a 3-wire. I believe you may have to swap the ECU for it to work with the later style IAC but I've been reading about the later style injectors and may have them confused if someone could clarify. Might also want to try swapping out your coolant temp sensor (CTS) - these have a pretty big impact on both cold and hot idling as they control the amount of fuel used at idle. They're relatively cheap so it's not a bad idea to replace them as just a maintenance item.
Sometimes you get lucky. EJ25 saved.
rxleone replied to Corvid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGod that's close! As a one-time timing belt victim (on a 89' EJ20D interference motor) I know the pain that a snapped belt can cause. Good on you for catching it - you've saved your friend one hell of a headache!!! ...I might just have to check my timing belt tonight after work after seeing this
requested! Pictures of the EA82t/TD04 Turbo
Are you running an EA82T on 20PSI? Dude...you are either very brave or completely insane...or both?
Early EJ22 Reseal Thread with Part Numbers
rxleone replied to Corvid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSorry to hijack the thread, but what are the quality of the Mizumoauto rocker covers/bolt seals like? I'm getting swindled at Subaru here for them, they want twenty-something dollars for each gasket and $6 for each bolt seal, if they're any good I'd rather order the whole kit just for those parts.
Recently purchased 2000 B4- Troubleshooting flaws
rxleone replied to wasral's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo this. Anything the previous owner has done should be remedied before suspecting something factory. Also probably shouldn't be boosting to 17 PSI - I'd get that checked out ASAP, as that could be doing serious damage to your motor.
New to the forums, and new to Subaru. 2001 Legacy GT Limited
rxleone replied to KingJerd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNice ride! I still have no idea why some people continue to put massive stickers all over their nice cars...crazy. Looks like a good score though, congratulations and welcome to the USMB!
will i need new heads?
rxleone replied to outback steve's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep, unfortunately that does sound like a damaged idler or something. And in that late a model, yes, if the belt lets go is is pretty much guaranteed engine damage.. sorry buddy
2001 lego overheating issue
rxleone replied to luko's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep, I'd go with some sort of intermittent fan failure. Check your thermo switch first.
08 legacy diesel
rxleone replied to fitzers's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like headgaskets to me. First time I've heard of these kind of problems on a diesel boxer.
Stereo and Speakers Watts
rxleone replied to SubieTrav's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXStudio tech here - they'll work, but not to their full potential. Chances are, the 300w label you have on the speakers is peak power, while the 80w probably refers to RMS power (or average power if you like). The speakers are probably 40 to 60w RMS. Put them in, see if they sound alright - if they're good enough for you then stick with em. If not, upgrade your head unit.
Which Doors Will Fit?
rxleone replied to lostinthe202's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou'd be best off just swapping out the glass - it's really quite a simple thing to do if you take your time and pay attention to how everything fits in. Had to do it a couple years back on my Legacy. Good luck.
1990 wagon gearbox help
rxleone replied to mikemac124's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs long as the gearbox is from a early (first generation) turbo Legacy or Impreza and has the same gear ratio, it will work.
What does it cost you to run your car where you are?
It's gone up again as well, to $2.15/l. Fluctuates pretty badly over here in NZ. I hear fuel is even more expensive in the UK then ours. Yeah, I noticed that our insurance seems a lot cheaper. That said, my $12 a month is 3rd party, so it only covers repairs to cars I hit, and not to my own. But that's irrelevant, considering my Legacy is only worth about $1250 NZD - any damage to it would probably write it off. What are high mileage diesels? We pretty much only have one grade of diesel, and it's not really taxed - however, any diesel vehicle pays road user charges, or RUCs, which are about $35 or so per 1000km travelled for a standard SUV/car.
Here in NZ fuels costing me $2.11/l - which works out to be $6.27USD/gal. Costs me about $50NZD a week - I do about 200km/week. I hope you guys over in the states don't think your $3.99/gal fuel is expensive!!! I pay about $12/mo for 3rd party insurance on my 89 Legacy 2.2. Rego $78 every three months. WOF (Warrant of Fitness, safety testing basically, no emissions) $40 every 6 months Comes out to $3136NZD or $2466USD a year, give or take a few hundred for maintenance and extra gas for trips. Not bad really.
Lateral Link Bolt Cut Off, Knuckle Damaged, Doh!
rxleone replied to stevetone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI can't really help you with the issue, but that much rust on a 2003 model? That's bad!!
Gen 1 Legacy Sedan - 215/45/R17 on factory WRX mags rubbing on strut tower
I've recently gotten my hands of a set of five spoke WRX mags with 215/45R17 rubber and put them on my first gen 90 EJ22 Legacy sedan. The back ones rub on the strut towers right under the spring, have burnt a flat spot on the tyre wall and taken the paint off the strut tower. Has anyone had this problem before, and what did you do to solve it? I've taken them off now as I figure it's probably not the best situation to have smoke pouring out of your wheel wells at 35MPH down the street. It's only a couple of MM difference but I'd rather be safe, but would like to get them on at some stage, as they just look so good!
Old Gens and the long haul: Road trip discussion
I've done this to my Legacy door card - it's hella ugly but I'm still pretty stoked with it
94 jdm 2.0 twin turbo problems
rxleone replied to ivans imports's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere's an absolute ton of these EJ20TT legacies in the junkyards where I live...tell me what you need and I'll go have a look for it over the weekend.
Do Foresters share the same style ignition barrel as Legacies, Imprezas, etc?
Hi guys, looking at buying a stolen/recovered 1997 Subaru Forester S/TB (JDM spec, EJ20G turbo) 5MT for cheap. Car is in relatively good condition, but the thieves destroyed the ignition barrel in order to steal the car. I've attached a photo of the damage. My questions are: Can I use a key barrel from a Legacy/Impreza? Foresters are scarce in the junkyards here, but there's plenty of Legos and Imps. Is this a big job to replace the barrel? It looks straightforward enough, but I'm concerned there may be something I'm missing.
