Everything posted by BlueSteel
nah it was all dark with those pics... some were with flash and others just a long exposure on the camera was a good days wheeling tho
just ran the angle grinder roughly around where the flared bit on the guards start, ended up cutting too much off the rears (i wanted that much tho) and got into the double skinned bit, so had to weld in some sheet metal to cover the gap between the two skins then screwed on a set of flexy flares and it was done
give us a yell if you ever do come down, lots of tracks around to explore been plenty of rain happening lately, so lots of mud, and unfortunately lots of water (poor brumby needs a snorkel )
some more for good luck that will do for now
and some more
Heres a few for you
http://www.crossbredperformance.com/index.html they have them there and BYB-01 on ausubaru.com might be making some soon too but find yourself some xt6 stuff... has gotta be cheaper
A few from the weekend
easiest way would be to go to all your local suspension places with a few measurements Length Compressed Length Extended What ends you need (eyes, loops, whetever theyre called) i did this and got some air shocks to suit my 4" lifted brumby (but i had to cut one eye off and weld it back on, but turned around 90 degrees) oh and that was pedders suspension
you can fix up the rear camber by starting with new bushings on the rear control arm thingy where it bolts to the torsion bar tube and if its still screwed up you can drill another hole on the torsion bar tube a little bit lower on the same bolt to push it further towards negative camber also with the rear torsion bar all it is really doing when you try to lift the car with it, is adding preload to the spring (torsion bar) so it will stiffen it up just the same as when you move the big adjustment bolt in the middle
yeah all you gotta do is unbolt the 3 17mm's on the trailing arm and the 12mm that is underneath the tube near the end then just tap the trailing arm out with a hammer clean up the splines a bit and spray on some wd40 or anything like that to make things much easier then just position the trailking arm at the height you would like and slide it back in chuck the 3 17mm's back in and the 12mm at the bottom and youre done and you have gotta do it oin both sides i have done this before on a wagon... not really the best solution:confused: if you go as low as it looks like your front is, then you will basically be riding on the bumpstops in the rear you can get some extra suspension travel by removiong the bumpstops (they are meant to screw out, but ive never been able to) a setup similar to the rear of the l series would be the go, stiffen the rear up and have short stroke shocks and you should be laughing
i use a couple plastic zip ties in mine... and they still pull the insides out of doj's before brealing the zip tie get yourself a 23 spline axle and stop worrying!
good to see its all sorted chris have fun with it!
ive got a 4" hi-rise kit in my brumby took about a week from sending my money to receiving the kit (they had it in stock and im in aus) only drama was they didnt send instructions and i still havent got them out of them is all in and no breakages yet tho
im not sure what its off i got my extension when i bought my lift kit (in aussie) but ive pulled single and double uni joints off ea81's and ea82's so i dont know what belongs to what any more
i have a brumby with powersteering and 4" lift the steering linkage extension is the standard double uni joint with a 4" peice welded in the middle of the 2 uni joints dont have a pic tho sorry... or a working camera
Steering rack loose on EA81
BlueSteel replied to CornerHard's topic in Old Gen.: 80's GL/DL/XT/Loyales...
could even be the steering rack mountiung bolts that are loose... this will make the car wander everywhere -
thats a right hand drive soob... so dont get confused there
http://www.pickupspecialties.com/Flexy_flares.htm the 2 1/4" should be about the right size for 30's depending on offset mine were 50mm and work a treat heres an idea can sorta see what the width is like here.. bad pix i know... but they were pulled of a vid camera
4.11 differential question
BlueSteel replied to baccaruda's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the 3.9 is 39/10 and the 3.7 is 37/10 afaik
