Everything posted by Ricearu
EA82 Lifter ticking. TOD, etc. My recent experience.
i bought a 86 motor from "ruparts"... it has 80k on it. what are the chances it will tick if I did not do the cam tower O rings?
No prob, I was just lettin you know. In about 3-6 months in the sun, that "clear" film will turn VERY cloudy and sometimes white.
wagon to ute/pickup conversion?
holy "great stuff" batman!!!
dude, you can pull the clear off. your supposed to, its just transfer film from paper to window. pull it slowly at a 45* angle. Also, I yanked Leaky McGreasymotor out of the car, tonight I am swapping intake and accessories over. Just a couple more evenings and she will be alive again
Bought my new gasket set, waterpump, oil, and coolant. reseal here I come!
dude that is boss, did you just take out the front axles and weld the rear diff?
BWAHAHAHAHAHAHA!!! :lol::lol:
thats a backwards "outlaw" cowl induction hood section from jegs!
your cam cap
ouch noob shifting overrev. for the loss...
Thank you to all forum members
there's no need to use gasket maker if you have a gasket. if you want it stuck, use a little copper sprayagasket on both sides of the gasket and mating surfaces. I have reused headgaskets with that stuff (dirt track racing) I wouldn't advise it on hg's for daily driving though waterpumps, and intake gaskets, exhaust gaskets, etc. I will recommend it all day long. Its like spray glue that fills imperfections and pits.... love that stuff
creeping up there.....
i drive 30k plus per year:)
92 loyale ea82 ignition coil?
i gained a little umph from a spectre filter, I modified a firewall flange mount http://www.amazon.com/Spectre-8148-Intake-Mounting-Plate/dp/B000BPUTL4/ref=pd_sbs_auto_8 bolted that to the maf. also the throttle body sounds rockin:lol: then I put an exhaust on it, magnaflow sounds ok, I like my topspeed. get the maxima alt upgrade. you WILL need it. the stock 55amp alternator suffered on my car just from driving lights. It lasted a year...
well did it again
Everybody here told you that running a crap load of boost would end that way the detonation was caused by running 26psi on stock fuel system :lol: next time leave it stock, it will run a whole lot longer Honestly if you want an engine to tear up, do what suberdave did and put an EJ20G into your car. you'll be much happier
good ole gl
THAT SUCKS!!! man...
Steve's AWESOME Brat
old 2bbl motorcrafts work well on ea81's seen it myself, the guy made the adapter plate from 1/2" aluminum with a drill and a rat tail file. Worked DAMN good that thing will suck, both figuratively (and literally "gas")
There…. I fixed it!!!! (56k sammich time)
just rock it like that, it looks hardcore, and bondo will just fall off! lol
Wheel Bearing Job Gone RIGHT
been there, done that. Hell, I won the timed powerstack competition at school on a 4L60E 0:58 input to output. I also made a 96 in that class (the highest grade in that term)
lost key no spear any ideas how to get started??
The dealers down in texas still have all that info. Subaru offers better support than that. This ain't honda.
no offense markus, but that car can teach YOU a lesson in aerodynamics, It doesn't need the wing. If you are bent on having a wing, sell the ricer flyer and get a sweet sexy duckbill or maybe a rubber lip spoiler off an old prelude
no boost at all
I would start with pulling the intake pipe off the turbo and see if she'll spin before Id do anything else. Also, feel out the shaft play too, sometimes the play will be so bad, that it bounces around the inside of the housing.
interesting shuddering
we cleaned the tps connections, and she seems to run/boost better. anybody know how to pull codes from an 87 gl turbo? My 88 spfi has a green plug on the fire wall... can't find one on his
Remedies for leaking valve seals
1 quart of lucas oil stabilizer with each oil change will help. I know.
Seven year storage GL10 turbo ideas
if its locked, its just a boat anchor
its not lighter, that is the light refracting off the dirt! looks nice under there now!
