Everything posted by Nug
"Where you are wealthy enough to drive a BMW, but still drink PBR."
Help me identify...
Nug replied to Nug's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Help me identify...
It's me with the disty on ebay. Yeah, I don't remember the year. It has 1 port for the vacuum canister. Hope this helps.
Forced induction. Sort of artificially raising the compression ratio.
As far as the o-ringing is concerned, It's not an actual o-ring. The deck has a groove cut around the circumference of the cylinder, and a stainless steel wire ring is put in there. So when you torque the head down, the ring is pressed into both the block and h/g. Kind of eliminates blown head gaskets altogether. Don't know if this is SOP for Cu H/G's, but I know it can be done with conventional (or whatever "normal") h/g's. Good for big lungfuls of N2O.
You can get a rebuild kit from turbo city for about a buck twenty-five. You won't have a way to balance it, but it will still work. Need a bucket of carb cleaner and some ridiculously small snap-ring pliers. And some torx bits (small ones) to take apart/reassemble it. Kit comes with directions. How worn out? Compressor wheel hitting housing? Might need a compressor also. Price unknown. Eric
Ah, the RTV game. As far as which gasket sauce is best, the "ultra" types of whichever color you like best seem to work wonders, but for the more heretical, Hondabond seems to work VERY well. Also in the realm of less soupy silicone sauce is an RTV avalible through Cummins (the diesel engine manufacturer) that is excellent, and if it can keep an insanely high boosted diesel running wide open from leaking, then it gets a gold star in my book. This post was probably absolutely unnecessary, but i felt like typing.
Even MORE coolant system troubles ::UPDATE::
Nug replied to MaroonDuneDoom's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Just take a few minutes and confirm that the impeller is still attached to the water pump's shaft. That has caused some of the most infuriating overheat problems i've ever seen. -
It will run like rump roast. You have to think about the metal particles from the blown up turbo bearings that will find their way into your oil.
The honda boys use a one way check valve from a fish tank aeriator. When there is a positive pressure at the maf, it blocks the pressure and the maf stays stady-state. You know what I'm talking about. I just woke up, and I can't think straight.
Advice on what to do about a spun bearing?
Nug replied to benaneely's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have a good longblock (or two) in my friend's basement for sale, If you feel like reusing your heads and stuff. -
question <could not think of a good subject line>
Nug replied to oddcomp's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It's good for vacuum hose, and covering other hoses, and that's about it. -
AT modulator Valve, what does it do?
Nug replied to ShawnW's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If you arre banging into gear, and it shifts late, it sounds like the modulator valve is making the line pressure go too high. Are the subaru ones adjustable? Some domestic ones are.
