Everything posted by simbey1982
Engine Swap, a tale of Woe, Ignorance and Rank Stupidity!
simbey1982 replied to DDad's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave a 4EAT with all the trimmings....see my post http://www.ultimatesubaru.org/forum/showthread.php?t=26892
Who can quess what happened?
simbey1982 replied to skytow's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell...you A frame has fallen out....will cost you a million dollars...and thats just the labor =0) Sorry man that sucks...better luck with a new one Cory
Accessory Blowout Specials from Subaru! (Long)
the impreza speaker upgrade kit....what does that have in it...also the cargo net for the impreza that for the trunk?? Cory
AT/MT identifier, and gas guzzle?
simbey1982 replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks josh...ill let you know how it works out
simbey1982 replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXby existing AT wiring, you mean the connector in the engine compartment? No dash indicators so this isnt a problem thanks
simbey1982 replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk here is the story, in the beginning just to get the car to start, we wired two leads on the B11? (one in the engine compartment that the auto was connected to) connector this just fooled the car into thinking it was in neutral. then we wired up the same leads but this time (to make a long story short) basically wired it so when the clutch is pushed in it shorts these two leads and when it is out the circut is open.....should i wire the neutral switch from the transmission to the ECU? if so how? It had no wire coming out of it...we grounded it and got a 0V when grounded to chasis...that should be right...i have a 1997 impreza go here to see the ECU guide i used http://www.ravensblade-impreza.com/modifications/misc/wiring/wiring.html Thanks again josh i really appreciate all of your help Cory
simbey1982 replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWe wired the clutch pedal through a relay to the B11? connector pins 10 and 11 or 12 or something...so when i push the clutch in, it completes the circut telling the car it is in neutral and when the clutch is up, it is in gear....the rpms do go up and down when i push the clutch in and out...should i do something diffrently? also, we grounded the AT/MT pin so that we get a 0V reading on the chassis...no wire coming out of it....it was 5v until grounded..... on a funny note, i wired up the reverse light, no problem just used my ohm meter tested a couple leads found the ones hooked to the connector for the AT and \boom it worked....well the next day im driving to work and one of my coworkers says...your reverse lights were on when you were going by...so i looked no lights?? what?? turns out i had wired it to the nuetral sensor and it was completing the circuit every time i put it in gear =0) cory
Help need specs 00 obw head bolt torque
simbey1982 replied to Brokechump's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdont know if they have any chiltons or haynes for newer subies but if they do i found all the tourqe specs for my impreza in the chiltons manual
How to tell if AWD kicks in on 03 OBW automatic transmission?
simbey1982 replied to danz75's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi Agree
Please help!! What is the Part # for duty solenoid c???
simbey1982 replied to pearlm30's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLook for Legacy777, Dr. RX, Thawa...any of those guys might have manuals and might be able to look it up for you COry
so just why does subaru...............
simbey1982 replied to robb1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUm,,,The DUDE arent most subaru engines with exception to some of the newest ones, all non interference engines?? Far as i know the only thing that happens if the timing belt on my 97 impreza breaks it just means a tow and a timing belt.....im pretty sure most suby engines are non interference Cory
93 Legacy Misfiring??????
simbey1982 replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLot of freeking posts.....sorry no useful information to give just making an obvious observation:banana:
Sup all....havent given you an update on the swap in awhile....its about 95% done....of course there is something new i want to do everyday so it will never be at 100% Anyway any of you gurus out there want to enlighten me on all the functions of the AT/MT identifier pin...i have gathered it makes the mixture more or less rich...and im guessing the ECU is then looking for diffrent volatges on the nuetral pin etc....any other benifits....what about leaving it on AT any benifits disadvantages?? Also im getting about 210 miles out of a tank of gas....city driving mostly....seems a little low..even for a suby...any suggestions? thanks Cory
ATTN: Portland, Vancouver, Salem, and surrounding area members
I live near portland....any events coming up
Inspection hole for felx plate?
simbey1982 replied to sid_vicious's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust to let you know those flex plate bolts are annoyingly hard to get off
I've mentiond that Whitefish, is cool, how cool? Check out our newest police cruiser.
simbey1982 replied to mtsmiths's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXawesome car
Synthetic Oils-There is a difference!
simbey1982 replied to outbackfan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXany objective proof....less rants?
2003 Forester -Taking Bets
simbey1982 replied to BlueSoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like a bad one.....too bad the dealer wouldnt take it back.
new '96 Impreza owner
simbey1982 replied to tls223's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou want factory service manuals or just standard manual? You can buy the standard ones for very cheap ebay and other. 40,000 i cant think of anything but im not a pro....ask legacy777, Dr. Rx they would know
I found a 93 legacy with 30K on it for $1K...
you are a lucky man
Auto Tranny clutch binding
Just pointing out that mine didnt.....
Tranny Swap: Day X (issue)
simbey1982 replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah the routing is the same....my friend has a cable operated legacy and it looks the same
simbey1982 replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhmm...well it isnt the TO bearing after disscussing it with my friend its not really possible to install backwards....This is just perplexing because the pressure plate, clutch etc are all meant for cable.... if we just use our hands on the clutch fork it doesnt seem too terribly stiff we are still thinking it is something to do with the cable.....but i replaced with a new one with no change....perhaps a spring clip came off the TO bearing and is causing trouble....pressure plate giving up.... Thanks for all of your help Cory
duty C solenoid wont neccesarily give an error code if it is just malfunctioning...
what you all think? torque bind
I have noticed a huge amount of posts about torque bind in the AT's I think we need to have a section for answers to this problem I had this issue and it was a bit difficult to find useful information ...however i eventually found it....i would be willing to contribute Any others willing ideas suggestions
