Everything posted by Logan K
About to buy the Ultimate RX
So, I'm finally biting the bullet and buying that car. Paying more then I should, but hey, its worth it. Only one thing really worries me...the engine will not stay running without constant application of the throttle for at least a good few minutes after startup, regardless of engine temperature or length of time since it was last run. Is this just an idle timing issue, or something more serious?
cant get the door apart on an 81 brat
Hey, I recently bought some window glass from Moosens(who is an excellent person to do business with!) and could not figure out how to get the door apart to get it in. On other car doors that I've disassembled there is usually a screw on the window crank so you can remove the crank and get the door panel off. I cant see where this window crank has any of that, and i dont want to break anything by trying to pry it off...help?
Repair Shops in WA
Smart Subaru is a little pricey, but they do very high quality work. They have 2 shops in south snohomish county, one in Muckeltio and one in Edmonds/Shoreline. I have always been very satisfied when I've had to take a soob there.
FJ1600 Question
do either of you have pictures??
Any one have any pictures of lowered EA82's?
hmm...didnt really get any good pictures of it but here is my 81 brat lowered in the front only...actually looked pretty good, and the 195 series tires tucked perfectly in the fenders on the 14 inch pugs. put it back up to stock height last month because the cattle pusher bumper scraped on EVERYTHING. :-\
Lifted Justy
Just out of curiosity, has anyone ever tried to see if a D/R tranny would fit in a justy? seems like that would add alot of potential to this car.
Rarest Old-School Subaru Part or Option?
You know you can still order that from the dealer right? i picked up a new bottle from carter subaru about a year ago.
Hey WASHroad, do you live in the edmonds-lynnwood area? saw your car drive thru a few months back.
XT v8?
i know im a little late to the party since you sold the car, but what about a subaru boxer diesel? you could probably get one shipped from a british wrecking yard, and it would be VERY unique
81 Brat Starts but won't stay running
tried starting it the next day and it worked just fine..its a quirky little car.
Hi, last night when i was trying to start my 1981 Brat, it would not stay running, it would start up and idle for about 30 seconds and then die, it would do this even if i was giving it gas. also, both the warning lights for the battery and brakes were on the whole time, and usually never stay on for more then 5 seconds after i start the car. I tried starting it 4 times then gave up, does anyone have any idea what might be wrong?
How do i compress the brake piston?
okay, thank you for that. where did you get that book? sounds alot more useful then my chiltons.
When i was changing the drivers-front axle on my 81 brat, i forgot to compress the brake piston before taking the caliper and rotor off, and now im wondering how i can get it to compress. The only way I knew how to do it before was by taking a screwdriver and wedging it between the inner pad and rotor but obviously that will not work now...im sure this is an easy solution, but i have a total lack of experience, so any advice would be greatly appreciated.
Northwest folks.
Lynnwood/Edmonds WA
Tore out the nasty old carpet in the brat and slapped down some herculine, it looks alot nicer and I dont need to worry rust forming under the carpet anymore.
'79 brat swap
You could get an ea81 (1800 cc version of the ea71). I assume it bolts up to your existing tranny but I don't know that for a fact...maybe you should swap in a D/R tranny while your at it?
where did you get that sticker!
87 GL fwd lift
take the suspension out of a 4wd wagon
power window trouble
and where is the master switch? im a n00b when it comes to wiring.
bump for rain in the forecast and my windows still not rolling up :-\
Things to look for when buying a brat?
yep. axels look good, no dents, gashes or rust on the underside. its got a super sweet dual exhaust setup tho. The only thing im worried about right now is that little ticking sound.
sorry...i have a really crappy phone right now so no pictures. its a really clean looking brat thought.
Youtube video old gen car chase
I didn't know they made a RX for that generation of subies, were those JDM only?
Hey, my power windows in my xt6 decided to stop working today, and I was wondering if anyone else has had this problem before. the electric motors do not make any attempt to move either window, which makes me think that they are not getting any power. I replaced the fuse labeled "Meter Engine (Window)", and still nothing. Any ideas?
so far it all looks good...only thing i noticed was a small tick coming from the engine. It sounded like a really quiet ea82 lifter tick, the owner said that he thought it just needed a valve adjustment. other then that, it ran and drove fairly smoothly, and only has one small rust spot, near the passenger side rear fender.
