Everything posted by Logan K
Unable to shift after replacing reverse light switch
Turns out the switch was actually the wrong one, just a little too long. Got another one from Napa and fixed the problem.
Yesterday morning, I installed a replacement reverse light switch from Napa. The car is a 1991 Subaru Loyale, with a 5 speed dual range swapped in. I drove about 15 miles, got to the store to get some supplies and all the trans would only shift into 5th gear! No 1-4 and reverse. Backed the switch out about 5 turns and my shifting returned. I do not see anything mechanically wrong with the switch, or different from the OEM one I removed from the transmission. Has anyone else run into this issue?
Using Carb longblock in SPFI Car (ea82)
I am using SPFI however...so will that throw off the fuel/air mixture if the EGR is disconnected
Any harm if I just block off the EGR? I dont really have the tooling to make a pipe.
Hey there, so I am replacing the longblock on my 91 loyale with an engine out of an earlier carbureted car. I will be swapping intake manifolds and exhaust over, is there any other things i need to do to get this vehicle to run properly? From my understanding it should be pretty straightforward, but I am planning on getting this done over the holiday weekend and would rather gather my parts together now. Any feedback would be appreciated. Thank you!
Can't keep replacing axles
Working in the automotive repair industry, I can say with some certainty that a BIG problem with some of the aftermarket CV axles is a lack of grease. Several of the failed units we have had come back for warranty replacement have been found to have little to no grease in the joints. There are several outfits that will rebuild your axle here in the USA...somewhat more expensive but the quality control is much higher.
02 WRX Intake leak from throttle body
Logan K replied to Logan K's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIT HAS a major leak from the throttle shaft at the tps side. No question about it. I know this is the problem, I was looking to see if anyone else had encountered it before and had a cheaper fix. Thank you for your help =)
- I think my ea81 is seized, who makes a decent rebuild kit?
starter momentarily stops/hesitates - then starts
Check draw from starter, load test battery? I think my XT6 did the same thing, i put a new starter in mine and fixed it.
Logan K replied to Logan K's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRough idle, fluctuating boost gauge, lousy fuel mileage. And no, not too normal but at 200k miles anything is possible right? I have seen similar problems before on fords and nissans.
Logan K replied to Logan K's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOrdered a "OEM" throttle body from Ebay for $130...we will see what happens
2002 WRX, i have an intake leak coming from the shaft that actuates the TPS on the side of the throttle body (Confirmed with smoke test). Has anyone had this problem before, and if so were you able to fix the throttle body without replacing it? New from the dealer is $600, and the aftermarket units look like they dont have a provision for cruise control. Any advice would greatly be appreciated! Thank you!
- Loyale tranny swap. Lost the backup lights. Need a diagram.
Control arm bushing diameters?
are you looking on the super-pro website? the larger diameter bushings they offer are for the ea81 stuff
Automatic seatbelt fuse location
Interesting...if all else fails i may put power to the motors, get my belts to go to the locked position and then unplug that module. Did that fuse affect your power windows at all?
Hit a big puddle offroad yesterday and now my power windows, power seatbelts and turn signals are all inoperable. The lights will still flash when i press the hazard button. I did not check this fuse however, as my horn and clock still work...has anyone had this problem before? I was almost wondering if my ignition switch might be an issue as the components that no longer work all run off key on power.
- Lifting a loyale and a 84 GL help.
Troubleshooting Electric Fan 1991 Loyale
That fan should come on before boiling temp. I would replace the sender/switch that goes into the radiator, those are pretty cheap.
How to identify Brat LSD
There was a fella from the Neatherlands (I think) on here a few years back that had a ea81 car that I do believe had a FACTORY lsd. Or at least one with a tag that looked different then the ea82 stuff im used to seeing. He was completely restoring the car, adding propane...he had a bunch of pictures.
new rear spring coils
Because they are no longer available new, and who knows how worn a used spring is going to be.
EA82 engine failure
TB299300K1 Is the part number for the Continental belt, tensioners and idler kit. It can be alot cheaper to buy the parts and pieces individually then as a kit however...
EA82 engine failure
Head gasket set Part Number HS9392PT2 for fel-pro. Can be purchased online. You will also need front and rear crank seals, oil pump gasket set and oil pan gasket. I would recommend shopping on RockAuto.com. In the vendor section of this forum there is a code posted for a 5% discount on any purchases made there.
