LosDiosDeVerde86
Everything posted by LosDiosDeVerde86
  1. should be cool. i think the air intake is different, but should still bolt right on
  2. not to change the subject, but i'm gettin a kick out of your avatar
  3. we prefer not to speak of the DriveTrain-That-Shall-Remain-Nameless
  4. that's what i was gonna ask...i couldn't imagine it's easy to find parts.
  5. IT'S LEGACY, SAY IT!!! LEGACY!!! IT'S NOT A JEEP!!! GET IT RIGHT OR I'LL SWIM DOWN THERE AND POUND THE "LIBERTY" RIGHT OUT OF YOU!! i'm just playin.
  6. an alignment wouldn't solve a bad rack! (if that's what you were getting at...it's 6:45am and i havn't gone to bed so i could be reading it wrong). Also, i just (personally) did an alignment on my 96 legacy and camber caster and toe were all adjustable.
  7. how about that picture of AA's DL flyin through the air on the october Subie Sport? or perhaps that brat on the first page
  8. a problem that my rims had was corrosion. Sometimes some corrosion can form between the tires and the rim that can cause leaks. If you have time take off each wheel and spray a soapy mixture or water around the bead where the tire meets the rim. also do this around the valve stem. if litttle bubbles form, the rims need to be sanded down at the bean to get rid of the corrosion. a little bead sealer should be applied as well. also, with cold weather coming, tires lose about 1psi per 10 degree drop in air temperature. being that it's not THAT cold yet, that's most likely not the issue. also, over time tires lose pressure...thats just how it is. if more than one of your tires is losing pressure, i'd say it's rim corrosion. if that's the case take the car into a garage and tell them that you have beads leaks on whichever tires are leaking and they'll know what to do and charge you for a regular flat repair. normally around 20 bucks. good luck and Godspeed
  9. if yours is the yellow one, it's on page 1. if yours is a silver one, it's on the WCSS7 page, somehwere around page 20 by the AA DL flying through the air.
  10. i lifted my legacy too, but mine's a sedan. figure out what the 16" translation of 215/70R15 is and that's about your tire size limit.
  11. the seats in my 96 legacy LS have adjustable lumbar support. you could look into that
  12. not everyone's out to get you. you could check the public records of the liscence plate of the stolen car and ask the seller ifit matched. might even be able to do it with the VIN
  13. Anyone here in the Pittsburgh general area wanna take advantage of this wet weather?
  14. reminds of the WRX quad
  15. dear god.
  16. there's a red spray you can get that stop corrosion and protects terminals. it's what we use at the shop, but i don't remember what it's called. i'd imagine that is would be better than vasaline.
  17. the only thing to be biased about in news is politics. Come on, you guys have CNN, CNN Headline, MSNBC, CBS, ABC and MTV. Stop complaning about one channel that may be biased away from your views and the views of the other channels. but yes...back on topic: i agree. 5k to throw away on a trashed car that was on tv for 5 seconds and will be forgotten about in 3 more days if not already would be nice to have.
