avk
Everything posted by avk
All the pulleys touching the smooth side of the timing belt rotate against the crank, that is counterclockwise if you look from the front. If you look at the pump from the inside, as on the photos, the impeller rotates clockwise. It sucks cooant from the radiator and creates high pressure in the round chamber from where the fluid flows into the block (separately top and bottom halves of it).
In early June I bought a water pump, among other things, from subarugenuineparts (thanks again Jamie) and it had a cast-iron impeller, same as the pump removed from a 1995 engine. And Paraut is an (exclusive) aftermarket division of the OE supplier in Japan: http://www.central-auto.co.jp/international/paraut.html Add: Endwrench does show different part numbers between 2.2 and 2.5, although that list might not be up to date: http://endwrench.com/oepropdf/enginecomponents.pdf?PHPSESSID=d481aeb7c626db6e5b02e8ce432b96af
I did reseal the oil pump while doing a timing belt recently. But mostly because of the reports of loose screws on the pump's back cover on some engines of that vintage (1995), and a TSB about possible casting flash left in the oil return hole in the block, to the right of the crankshaft. No problem was found with either item. On newer engines, i don't see a good reason to remove the oil pump. The O-ring for the oil gallery and the sealant are the same as used between the halves of the engine block, so one wouldn't expect them to fail prematurely.
Not all SOHC cams have the hexagon. Those with hydraulic lash adjusters certainly do not. porcupine: That tool costs about $65 from SPX. I understand it's less if you're able to open a business account with them. The wrench is made in Japan and has a Subaru part number on it. It's a good 1/4" thick and very heavy.
If the coild wasn't attached with screws, it should have come off at least with the help of a puller. Maybe everything on the front of the compressor was indeed thoroughly cooked. I once replaced a coil on a GM compressor and it was not pressed very tightly. The pulley bearing already holds it in place.
