avk
Everything posted by avk
If the pulley's already loose on the shaft but the crank isn't chewed you may not even need to remove the fans. This usually happens after the bolt wasn't tightened to the correct torque when replacing the timing belt. I can send you an 11 y.o. pulley with 80000 miles with some cracks in the rubber and some rust, for the cost of shipping. The keyway is intact. I know it won't work if you need it fixed ASAP.
The "Phase 2" changes were outlined in Endwrench, http://endwrench.com/images/pdfs/FuelEmissionsWin00.pdf The problem seems to be that the changeover occurred gradually during the model year. But apparently a number of other components changed along with the cam and crank gears, so the two kinds of engines shouldn't be so hard to tell apart. Pictures of the sprockets here: http://endwrench.com/images/pdfs/Crankshaft.pdf I admit it's not quite clear if the two sets of changes are actually related.
My understanding was that the new system was found on the Legacy from 1996 and on the Impreza starting in 1995 mid-year (my '95 wagon doesn't have front sensors). But now I have looked at the collision parts catalog at subarugenuineparts and it does show front impact sensors for Legacy. If they should be there, hopefully yours still are. The discounted price is $256.19 each.
I did a timing belt service at just over 80000 miles and here's some other things from my list: -replaced two O-rings between cylinder heads and camshaft supports. Same part number, both were leaking. Replaced O-rings between dipistick tube and oil pan (also a pair) because the tube had to come off to reach the cam support on the left. -replaced crankshaft pulley because rubber layer had cracks. Don't know if it was an overkill or how common those cracks are. Used new bolt and key for a good measure, they were about $5 together. -replaced all belt rollers and the tensioner because new ones had to be on hand anyway as I didn't know what I'd find. If I was doing it at 60000 miles like it was supposed to, I wouldn't have bought those parts. If your shop has parts in stock they would replace only what's necessary, in any case. -replaced timing cover gaskets but the old ones were usable even though the one on the bottom center was slightly distorted because of oil leak from the seals. That gasket is likely the only one that ever needs to be replaced. -Since my choice was to remove the radiator, new hoses and thermostat were put on, also the radiator cap, and the exposed AC condenser was cleaned. -Don't forget the heater bypass hose at water pump.
Credit card agreement says the coupons cannot be transferred. Mail-order places do require that the name matches, to prevent fraud. Don't know how strictly it is with over-the-counter purchases. I guess the answer is, some dealers might accept the bucks issued to a third party, but it shouldn't be taken for granted.
John, I ran into the same thing when trying to remove the pulley and posted aboout it a few weeks ago. I did use a 3-jaw puller to take it off. As to the marks, it takes hundreds of crank revolutions to line them up again. The exact figure is number of teeth on t-belt, times 2 (for 2.2 l, it's 422).
