avk
Everything posted by avk
I know '97 control panel is different from '93-96 because recirculation flap is operated by cable, but the opening and trim should be the same. If so, the screws should be on the recessed surface of the bezel that surrounds the knobs, at 12 o'clock position facing straight down. The screws go in at an almost vertical angle so they aren't seen by people in the seats. If you still don't see any screw maybe the bezel is held only by the tabs, as '98+, but their dashboard is completely different.
Removing glovebox
avk replied to feef's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
If those are the plastic stopper pins near the top corners of the door, they can be removed by carefully squeezing the prongs that hold them, or you can just try and squeeze the glove box itself to make the pins clear the slots. All this should be done in warm weather. -
heater hoses
avk replied to lytnin88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Don't cut the hoses. They made them in one piece for a reason. -
Dimmer Switch?
The box you're looking for is called illumination control unit. I don't know where it is on a Legacy. The variable resistor in the stalk changes its input voltage and the unit controls current in the main circuit. It sits on the ground side of it. I'd suggest checking both input and output voltages with a meter while moving the adjusting knob, then you'll know which component is bad. -
I believe a marine epoxy paste will hold it. I used a product found at hardware stores, named PC-11, to attach to the roof a bracket for a Legacy map light. Has been holding for 3.5 years, car parked outside. It's thick enough to stay in the gap and gives you enough time to position the parts. Then there are specialized structural adhesives sold by body shop suppliers but they are necessary only for load-bearing parts.
Saabaru
avk replied to Aja1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Servicing it at Subaru shouldn't be a problem, except maybe for anything that requires look-up by VIN. -
This is from an aftermarket parts catalog, used by a number of vendors, in reference to phase I SOHC timing belt: Timing belt 13028 AA102 is exactly the same size as belt 13028 AA150 and can be used in its place as long as the different position of the crankshaft reference marks (dotted paint stripe) between the two belts has been taken into account (belt timing positions on California engines for this application are slightly different than those for Federal engines). Not sure I understand what they mean. Are the tooth counts between timing marks not the same between Cal. and non-Cal. belts? The service manual does not say about any difference.
