Everything posted by 86subaru
99 forester will not start after maf sensor cleaning
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXchecked all no go , stalls out ,
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXchecked all hoses and rechecked no go , work on it tomorrow ,
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwill check , sure seems like that to me also , thanks all , very hot out , trying to get to hospital to see mother so it adds to it,
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes i agree running fine, but one thing i did not check was the air filter , which was very dirty , the car would stumble a few time , so decided to clean maf sensor ,now it starts but stalls ,if i stomp the pedle it will run but stall out, no check engine light on
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes and checked it again, :-\
cleaned it with mass air flow cleaner , it will start but stall out , also changed air filter which was very dirty , check all vacuum lines all good ?
would a bad maf sensor cause sluggish
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXright , thanks,
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcan i use seafoam spray to clean it or maf cleaner,
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno cel, no stalls, just at 65-70 mpr , not sure how old wires plugs are, temp gauge in the middle, very hot humidity very hi ,shifts fine all gears, new hg , valve job, also mpg is only 21 mpg, a/t , could it be a coil pk going bad, ?coolant temp
99 forester 2.5 a/t 157,000mi + mpg is 21, sluggish at take off , i have not cleaned it yet, new air filters, cleaned intake, new fuel filter,
Knock sensor from ebay any good?
86subaru replied to outback_97's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi have used them off ebay with no problem
accident bent control arm
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwondering if it could be heated up and fixed,
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX2000 legacy L wagon ,no spares
my boy had a accident no one hurt, front bumper cover broken, tire blown out, , fender, went to put on different tire same rim same size tire, the tire almost hits the mud flap , not sure what is bent
How does a non EGR engine, intake manifold, and ECU give EGR code?
86subaru replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmy 2000 a/t 2.5 has no egr, no engine code,engine never been swapped, ob 2
length of oil dipstick
86subaru replied to Gentz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit should show full, check it when engine is cold
dash lights out
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno , no dash lights
dash lights out
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes one of the tail lights were out , replaced it ,thanks
Why Subaru...sorry.
86subaru replied to AlanS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbuy a 95-97 with a 2.2 subaru , will last well over 200,000mi , i own 3 subaru;s 97, 97, 2000
dash lights out
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXall fuses good
crank postion sensor 97 2.2 question
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXchecked it out again no spark , changed coil before , for some reason the plugs are hard to change the socket will not go all the way in , i have a deep well
86subaru replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe old one really had to get out ,broke off the top of the sensor
ordered a new one oem, the old one broke off trying to remove it, is there another place which can be mounted and work , still no start, new cam sensor, coil , fuel filter , plugs wires, check all fuses, grounds , and getting fuel , newer timing belt, water pump, just cranks, just about ready to tow it to the junk yard
