86subaru
Everything posted by 86subaru
put in a new 2 row radiator + light duty tranny cooler into my 88 turbo a/t turbo wagon , before if running ac on regular setting 4th speed on fan it would be 2 bars from red , driving 70mph , now ac on max 4th speed 70mph , 1 bar below red , the cooler was hooked up to run though radiator + tranny cooler , + all new antifreeze of course , so my point is if you have a a/t in a turbo run a light duty tranny cooler + going to drain / fill tranny again
got it , this is 86 subaru 's wife , did it myself found extra passanger side switch in a box full of extra window switches , he is taking a extra run tonight ,soooooooo had to fix it myself , chance of rain thanks
it;s the passanger front only , all other work, the switch at the drivers side does not work or the switch at the door
tranny cooler or oil cooler /88turbo a/t
86subaru replied to 86subaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
thanks , will be getting a light duty a/t cooler , advance auto , for 30 bucks -
looking around for a tranny cooler found some for around 30 bucks , light duty , or heavy duty for 10 bucks more , along with new 2row radiator + drain fill tranny , my question is should i go with light duty or heavy duty ? i will be using the ac this summer , car has no problem with tranny,or go with oil cooler instead ?? thanks + what type of tranny fluid ?
i agree also
need place to get 2row radiator for my turbo
received new radiator , 3 days after ordering -
IL,WI,IN, and IA Subies
86subaru replied to SyntheticBlinkerFluid's topic in Meet n' Greet. Your USMB Welcome Center
i am in western ,OHIO, -
thanks , got one coming -
FWD Turbo 4eat XT? Rare?
86subaru replied to RallyKeith's topic in Old Gen.: 80's GL/DL/XT/Loyales...
buy it , fix it up or strip it out :banana:thats how i found my first xt , mine had a bad tranny ,but a good turbo motor ,which i still have as a spare -
looked it up it says non turbo 2 row metal radiator ?? radiator express for a rx,122.95 $,so this is the correct one for my 88 a/t turbo wagon -
yes coolant+ oil are where they should be , temp gauge reads in the middle , motor sounds the same , it just goes on for a few seconds then off then on ,thanks
ok, where is the switch located at , ? must be close to the light on the dash ,thanks
Anyone ever have knocking with synthetic oil.
86subaru replied to Gl-boost's topic in Old Gen.: 80's GL/DL/XT/Loyales...
if you have oil leaks it will leak more , -
it is on my 88 dl spfi d/r 193,000mi , oil pressure is good, [ after market gauge] oil level good, new oil + filter , motor sounds the same , it came on then off then on while driving , possibe oil sending unit ? wire is hooked up
Does anyone use VHF radio on land?
86subaru replied to skinnyhb's topic in Old Gen.: 80's GL/DL/XT/Loyales...
marine radio's are for boats only, if you get caught there is a fine , stay off ch-16 , i would use frs uhf radio's or gmrs -
any pics:grin:
Gas tank removal on a 87 Gl-10.
when removing a gas tank ,what about the tube or spout ? will it just pull right out, i am sure there is bolts holding it in ? -
Any Ideas? 89 Subaru GL Has an Owie
86subaru replied to Cynthia's topic in Old Gen.: 80's GL/DL/XT/Loyales...
ask a local board member to test drive before you take it to a shop , because the shop may take you for a ride for alot of $$$$$ , + the board member who drives it may be able to put a tranny in for you -
under the hood on top of the motor it might say turbo ,the fluid for the tranny is real thick and smells pretty bad, not like oil , check the manual it should show how to check it , it seems to me it might be alittle low , i am sure some board member closer than me would put a fwd tranny in for you
