Everything posted by erik litchy
ARP bolt?
is there a rod bolt upgrade for a EJ22? i could not find a part number. also does anyone know if i need a torque plate for final honing? where can i borrow one?
'87 leone wagon build up
wow that looks sweet. no dents or anything. and headlight washers.
A/C Compressor seal
erik litchy replied to fixitguy50's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhow did the shaft look? was it scored in any way? surface quality is important. also the front bearing is very good idea to change at the same time. basically theres no way to tell unless its apart
what to look for when buying a Loyale?
i would check the idle air valve for some debris. also the air filter if its been sitting, might find a rats nest, i did.
Forrester turbo died
erik litchy replied to koneall's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwow! i would get an oil analysis.
a little better introduction.....my new car.
erik litchy replied to monstaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwait so you have to make sure it has no codes for a title transfer? how strange. but you can remove the airbag with no problems?
EJ25 Big Trouble More Info
erik litchy replied to doogymon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthere is a company called damper dudes that repairs these things.
Head Gasket, $2900?!?-need mechanic!
erik litchy replied to reelst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthat quote is insane
Oil filters-would bigger be better?
erik litchy replied to Kwhistle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsure, if you remote mounted it. a oil cooler is also a great idea
rebuild
a bad valve would surely have shown up on a compression test
VIDEO: PIA/Cobb Tuning give the full STI swap treatment to Subaru Forester
erik litchy replied to doc526's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXso what are they doing to do with it? sell it and recoup their money?
87' Gl Wagon Blows the doors off an RX8
wow my wagon wouldnt beat a bus.
weber carb
is the weber larger as well? larger venturis would let you have more power.
Timing belt busted, '99 Outback
erik litchy replied to mr.radon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXso you only need a valve job on one head? or are you going to do both so they are even. most people say that the rear main seal isnt worth the effort if its not leaking. theres a few threads on it.
Blizzard of the Century
wow we dont have anything here
nothing but rain here. am i ever happy go get some pictures if you can
Rear Brake Pad options
im using a brand called Remsa Silver on mine, they seem pretty aggressive. cold they are decent but they get better hot. no fade
erik litchy replied to koneall's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwow im glad it was under warranty. Fairtax4me is right about letting it sit for a while
Red dust
erik litchy replied to skibumm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmaybe the ac clutch?
reuse head bolts?
erik litchy replied to aa8jzdial's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif you insist on replacing them, upgrading to head studs might be a better option.
My 81 Brat Never ending work in progress
what does it need next
Couple East Tennessee Snow Pics (Impreza Inside)
erik litchy replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXoh im not ready for snow!
splitting block
erik litchy replied to 6inarow's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX14mm
Prices/rareness? 91 turbo leg 5 speed in the junkyard
erik litchy replied to hatchsub's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthis car is very rare. yes the engine is good, but the heads dont flow as well as the newer models so they arent worth as much as the block.
96 Imprezza gets squirley on snow covered road
erik litchy replied to marinemedic's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXoh are they ever. my 89 cherokee is GREAT in ice, with the right tyres (Kumho MT) but never was worth a damn in snow. as soon as you lift off the gas it oversteered even at 10 mph. it has a limited slip front and rear diff. yes it has left me in the ditch a few times. the subaru is so much better in snow!
