Everything posted by erik litchy
damn thats one clean engine what casued that?
digital camo
obviously i cant make it can someone take some pics
hey now they can look good
supposedly the washers are one use only, but its not a huge deal to re use them
sounds like a no brainer buy it
EA82T lack of power and idling problem
erik litchy replied to soukka's topic in Old Gen.: 80's GL/DL/XT/Loyales...
high Carbon monoxide can mean a bad catalytic converter. -
id worry more about turn signals
Guido almost bit the Dust today.
erik litchy replied to The Dude Abides's topic in Old Gen.: 80's GL/DL/XT/Loyales...
happens every day around here, ill give you a tip. dont lock up the brakes if you want to steer, i slam on the brakes all the time but i dont try to lock them up. usually it happens so often (illinois drivers really are horrid) that i often just leave myself a space where i can run off the road instead. -
Subaru 360 van Dyno day
erik litchy replied to 2stroketurbo's topic in Historic Subaru Forum: 50's thru 70's
thanks, i havent heard that song in a long long time. -
oh im sorry, sounds frustrating to use.
or just bend the corners more so its a tighter fit
if you have a nice "stick welder" what i would do, and am eventually, is to buy a wire feeder for it. sure it wont have all the bells and whistles of a normal mig, like spray mode etc, but it will get the job done.
a good idea anyway, any voltage drop makes for a lot of dimmness.
those are a large step up from the ones in the first post. are those Autopals? anyway the better ones can handle the heat from more powerful bulbs.
the light flywheels vary from manufacturer. they should clearly specify the weight. they also should provide the surface area. but its almost always the same as oem.
however if you put bright bulbs in them they would blind everyone they dont have the correct reflector these or equilivant will work http://www.amazon.com/Hella-Halogen-Replacement-Headlight-Standard/dp/B000FKIURK
those ebay lights arent very good, the beam pattern is pretty bad. stick with a name brand like hella or cibie, and make sure you get them in E codes, NOT DOT.
sounds like the mustang's driver was very good. no matter what he was running in it i still cant imagine that chassis as anything but a handicap. no evos? are the times published somewhere?
so um how well does a mustang do? those cars have a pretty bad suspension geometry from the factroy, as well as being really front heavy i imagine it must have been a handful!
