Everything posted by erik litchy
EA81 performance build essay *HI-RES PIC WARNING*
what do the ea82 pistons give you? that looks so simple to work on compared to the ea82.
Back......again....YAY
erik litchy replied to keltik's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXive never heard a car that sounds like that before. sorta like a cross between a vr6 vw with straight pipe and a M3...
Could a coolant leak cause O2 sensor fail?
the manifold gaskets wont fail if you use the gasket shellac on them. same happened to me.
exhaust leak results
erik litchy replied to unibrook's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdid you report them anyway
California SMOG : from Sconnie to Cali
that does not sound like the cops job, he should be fighting crime.
welcome! i dont know if the commies there allow anything. no offense to the folks that live there already but damn theres some horrible laws there.
What gasket?
ill help you out since my dealer was too dumb to figure this out cam case o ring part number is 13089aa010
alternator help
erik litchy replied to erik litchy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXprabably what i will do, thing is cores like that are usually the first to go from cars...
alternator help
erik litchy replied to erik litchy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell then how can a rebuild outfit do any work? i can only assume they use substandard parts to keep costs down? example i rebuild the alt in my jeep about 10 years ago using this AFFORDABLE rebuild kit, its still going. http://store.alternatorparts.com/partnod1-7130icebergalternatorconversionkitforthedelco-remycs-130type.aspx
alternator help
erik litchy replied to erik litchy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXim not im just being cheap, what do i get by doing this swap?
Cylinder head grooves left by old gaskets
erik litchy replied to abeauch's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi would, as a rule resurface any head that has a bad headgasket, not for flatness but for surface roughness. irregularities are the enemy. i think what would be needed is a Surf guage
Mpfi>>>spfi
no the ECU i think is shared with the turbo
clutch cable broke again
ok replaced it, lubed the cable with tri flow (real cable lube) greased the pivot bushing in the clutch pedal, and the pivot pin at the clutch end. seems radically diffrent, somewhat easier but a lot more springy. i curse the engineers that thought that would be easy to replace edit i routed the cable same as before
alternator help
erik litchy replied to erik litchy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes thats most likely the problem, as it put out nothing as if it had a bad brush
alternator help
ok its a 91 legacy unit. tested at 2 parts stores as bad. other than the rear bearing being shot i dont see anything obvious. id like to narrow down what could be wrong with it using the multimeter.
Off Road Bumper Project
ahh makes sense now
Towing
i liked that body style, the newer ones are just enormous in comparison. give me one with the 6 speed and 7.3 and fill one tank with vegi oil. never liked the gas ones, filling both gas tanks would be too depressing.
SeaFoam in a Manual Trans?
erik litchy replied to lostinthe202's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdoes it really call for gl5? GL4 or GL5 attack the yellow metal synchros IIRC, redline and synchromesh are gl-4s but with additives for use with yellow metals, could be wrong though
it looks like it will hurt your ground clearance and approach angle set up like that?
Towing
my tow rig gets decent mileage with a load about 17 mpg-flat road of coarse. it just did a 700 mile trip. shes an old 89 cherokee, only rated to tow 5500 lbs... pulls nice though! has the engine balanced, blueprinted, stroked, .060 overbore, forged pistons, 10 pounds lighter crankshaft, nice cam, bigger throttle body, header, 4.10 gears and 33's.
erik litchy replied to lostinthe202's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou poor guy, a 50 mile commute is just terrible. anyway once you get it cleaned out id use id use it in any manual tranny
finally got a hks super afr hooked up on my 87gl-10 awsome "Rough idle gone"
to me its not suprising a circit board can go bad after so many years. thousands of heat cycles to crack solder and capicitors prabably long dried up.
Electrical Problems On 90 loyale RS
i have a rebuilt one id love to sell
Anyone ever make a tool
made a simple press/dimple die
my new bumper
in not sure, my bumper is .120" thick all around.
