erik litchy
Everything posted by erik litchy
  1. i think michelin is your only choice http://store.coker.com/blackwall-tires/michelin-trx/
  2. nice you got it home. its weird but i dont really think of taking pics until after when things go bad like this
  3. if someones passing by my place give a holler.
  4. i said affordable, but i have no idea what the markup is on them $193.95 seems what they retail for http://store.summitracing.com/partdetail.asp?part=ARP%2D260%2D4701&autoview=sku
  5. curious if anyone had a source for the head studs that doesnt cost an arm and a leg?
  6. if you change you coolant often, no. this one died from neglect.
  7. looking for advice notice my image, i have filed the mating surface quite a bit, and am worried about leaks in the future if it corrodes more also the throttle body area hose connector is no good what would you do, replace the mafifold or run form a gasket on the surfaces and hope that tube never rusts off?
  8. you are saying addng more cams adds power? why? i think you would have better result sending the cams to delta instead.
  9. thank you i will buy it
  10. i think the last 6 numbers are your cars unique serial number, at least on newer cars that is.
  11. what a huge diffrence! part of the reason is i found a rats nest in the intake box. but anyway without the silencer the hesitation i had before is gone. it sounds like a honda now though
  12. if its got no hose, yes what a pain
  13. i got nothing on you guys set of 33" tyres and wheels is all i got http://www.wtfhost.com//files/363/subaru/IMG_1603.JPG
  14. thats some serious snow. i see your tractor is a 2wd how well does that work?
  15. i did take out some toe but the rear is obviously worse than the front. im considering adding these http://www.ingallseng.com/product.php?productid=16328&cat=0&page= at some point...
  16. damn that doesnt even look wet in the pics.
  17. can some mod move this:banana:
  18. i always like the http://en.wikipedia.org/wiki/Italian_tuneup
  19. no offense but it sounds like a recipe for runner up next to the 1.6 diesel rabbit as about so slow as to be unsafe.
  20. so i bought a engine that needs new headgaskets what are some must do things for this engine? are delta cams a good idea? im going with gapless rings, they work great in my ea82, no regrets there. i also took off about .050 my heads, whats a good number for the ej22? since it has bad headgasket oil could have been contaminated so i will go with new rod and crank bearings, is any brand preferred? also i have the er27 exhaust on my car, it should be good enough for this engine right? its a lot better than stock is.
  21. sounds like a nice brat, welcome
  22. less than $100 80's cyber tig III now all i need is a water cooled torch and a pedal assy.
