czny
Everything posted by czny
  1. The prank aspect occurred to me too Bennie. Worse yet is the jokester who walks off with your hardware in their toolkit. Did the OP replace a ball joint while at it? We don't know, yet. BUT, sometimes there's a new spare bolt with nut included in ball joint kits.
  2. Lower control arm inner pivot bolt? Can't recall at the moment if stock pivot bolt is 10 mm or 12 mm shank diameter. Strut knuckle bolt maybe?
  3. That VVT engine might've gotten the "STP oil treatment" https://community.cartalk.com/t/stp-oil-additive-good-or-bad/5851 Many people advise against using that stuff in modern engines.
  4. https://wetechnologies.com/technical-info/Stranded Wire Chart.pdf Compare your wire to fractional small drill bits to gauge the wire, if you don't have inch calipers.
  5. What's closest? 2 inch or 1.75"? Something like this in 1.75" tube? https://www.ebay.com/itm/195316337367?itmmeta=01HQPNTDJPX2HY3RWBH7GKM4PT&hash=item2d79c2cad7:g:MhUAAOSw6LVjDNzX or this https://www.ebay.com/itm/195294326139?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D260885%26meid%3D542ddf04b4dc462ba8b55b9f1103e42e%26pid%3D101875%26rk%3D1%26rkt%3D4%26sd%3D194866476331%26itm%3D195294326139%26pmt%3D1%26noa%3D0%26pg%3D4429486%26algv%3DSimplAMLv11WebTrimmedV3MskuWithLambda85KnnRecallV1V2V4ItemNrtInQueryAndCassiniVisualRankerAndBertRecallWithVMEV3CPCAutoWithCassiniEmbRecallManual&_trksid=p4429486.c101875.m1851&itmprp=cksum%3A195294326139542ddf04b4dc462ba8b55b9f1103e42e|enc%3AAQAIAAABcKAO6YGL7I8ZT6VFWcHmDuKm898HGH9cNRsnG%2Fep%2BzC3UPHwPSmfpPq3b41cHxht%2FCiwo5DdbtiFsRNqRhAUlK8x2MLrmISu5pnzSn%2FhiW3P7y%2BKcxGllTjL%2BG3bIP4k8fGgzCrVY1dxXbjuBFp3vefxTYgjBXBRUWQBgGciI%2FuQ5Mjsfl%2B%2FiL4cv70dT88jK6Z5YT9T2oLeJmAohqKKX8IVzzDAekdJV%2Fxq%2Bc3GsCg7X6Zze2%2F6TY9OGC3J%2BQ7KI%2BVNS7pIKfcR80mWjD7SPrLmg1rkuhBuMZJGO%2BwXDaWZn%2FU9HC7IhySjoZuaI5ar%2FdYRxsTkuYh%2FHm92l9PZtxSCdxkKEl4Rdb21HYgsNR6ryk3p%2Fu2LVIclbR2uLxqMOcqWXzb1TO%2Fn9J5a74wK0Et0QvPntwqvSQx6vkV%2BfmUtlH7ZxWakTq%2Bv9wbGy72morz2ZZB656MgHu8JE7tW7xMZYQI2qRPEDTukMfnti3oc|ampid%3APL_CLK|clp%3A4429486&itmmeta=01HQPNSZZXEE8X7NAKXNMES546
  6. https://www.ultimatesubaru.org/forum/topic/183806-on-the-spot-endurance-engineering/ Although this car owner's abilities aren't up to this level, some of his repairs came close to it. NOT! "Just in time racing" Just kidding.
  7. The owner has already been told that he made a really bad decision on this one. How can anyone not hear the sound, and feel the engine cutting out, with valves hitting pistons, and keep driving it?!!! He's had 2 GM vehicles and destroyed those too! Slow motion train wreck...
  8. While these 2005 pistons are most like the original ones, https://www.amazon.com/DNJ-Piston-2005-2005-Subaru-Outback/dp/B00TM25ZSE/ref=pd_ybh_a_d_sccl_7/137-0407383-1406803?pd_rd_w=QPGdW&content-id=amzn1.sym.67f8cf21-ade4-4299-b433-69e404eeecf1&pf_rd_p=67f8cf21-ade4-4299-b433-69e404eeecf1&pf_rd_r=58PM5VRME6WGQNSZ6QJD&pd_rd_wg=0Qlch&pd_rd_r=7f9575e7-966f-43b1-8c20-cfd734b13365&pd_rd_i=B00TM25ZSE&th=1 I opted to get these because they are listed for 2004 MY EJ259 engines https://www.ebay.com/itm/134624910093 I had already ordered a set of std NPR rings for the old pistons, BUT, the old ones had collapsed skirts, carbon stuck oil rings, carboned up oil return holes and valve hit damages on all the pistons. The old ones would've had high oil consumption, cold piston slap and been a real PITA to recondition in general. Had the heads resurfaced to the head height limit leaving some spitting in non critical places - to use with 642 OEM gaskets. #4 rod brg was too loose compared to other 3 ones, SO, case halves will have to come apart to refresh the R&M brgs and polish the crank. #4 rod big end mikes out as OK - round and on size at 2.165" in 3 places. New OEM timing belt, tensioner & idlers, oil pump, water pump & heads gskts are already here. Money is really tight on this repair so a new, or used, short block was not an option This engine, in fact the whole car, has been driven into the ground. Whatever else needs repair is just gonna have to wait. Pics will follow later...
  9. Read the last post. https://www.subaruoutback.org/threads/pzev-ej259-to-ej203-swap.336497/
  10. Looks like an answer here: https://www.subaruoutback.org/threads/2005-vs-2005-pzev-cylinder-head-valve-angle.537318/ All the original ej259 pistons are badly carboned up, especially #4 which was so bad that it had to be beaten out. No wonder this engine had no compression... Some constructive input would be helpful here.
  11. OK. Let's ask this in a different way. Does anyone here, possibly with engine machinist experience, think the valve angles of all SOHC heads of these MYs, Ej259 included, are the same? I know the valve sizes are the same in these SOHC heads for these years, 2000 to 2005, so interference would be fine there.
  12. This winter has been cold enough to kill batteries and my neighbor's 2004 OB, cold weather model by the VIN, didn't have a block heater. One day he contacts me about his car 'cause it wouldn't start - just cranks & cranks with no sound of compression. No huffing noises. 140k miles on it with no apparent service history. I pulled the engine to determine if it has a broken or stretched timing belt & bent valves. Pulled it down to short block today & indeed it had bent valves in both heads AND a stretched timing belt with cracks on the outside and a leaking tensioner. Someone had changed the head gaskets only, Felpro MLS Permatorques. 3 of the cylinder bores appeared very dry while L rear cyl had been burning oil. Yes, this has the early PZEV pistons with the horseshoe shaped trench in them. Has anyone here used ej pistons such as these in an ej259 block with 259 heads? https://www.ebay.com/itm/373015758427 My neighbor foolishly used diesel 15w-40 oil in his engine last year - hope the R&M brgs didn't suffer for it.I'll check out the rods while the oil pan is off for resealing. Found this old thread while searching for an answer: Help! EJ251 heads on EH259? - 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX - Ultimate Subaru Message Board
  13. Work up to the needed drill size in steps from smaller to required size. Use drill & tap fluid. Find a friend with a steady hand to do the drilling if you think you can;t hold the drill steady. You may be able to find thick-walled steel bushings at McMaster to hold against the case surface for a drill guide. Some are available at bigger Ace Hardware stores too. Take your time. Don't rush it.
  14. Drill & tap hole for new insert. Screw insert in with another bolt, short piece of tube backed with a nut. Drive in stakes until flush. Choose your inserts carefully because some sections on front of engine have limited metal to anchor into
  15. For less money https://www.mcmaster.com/93715A630/ insert tool https://www.mcmaster.com/94010A330/ You can also find taps and drill bits there at McMaster-Carr I had to do the helicoil repairs on all timing idler & tensioner holes on a 2003 Forester engine in 2021. Take your time when tapping holes and clean out chips with compressed air frequently as you go.
  16. Yeah, everything I have here in Troy that doesn't run is buried in snow too. When I asked Chris about it he said that it was a single range pushbutton manual car. He may have access to a tractor but then you'd have to sling it thru the door openings with a big tie down strap to the loader bucket. Shovel snow, sling bucket to roof, pick it, drive back the quarter mile and set it on your trailer. I thought about getting it last winter this way but other things became priorities.
  17. Those OBX fixit "kits" were parts sourced from McMaster-Carr IIRC. I may still have the PNs for those on another computer but I'll have to search. Nothing but metric allen bolts and Belleville washers! And I'll leave this here for reading: https://www.ultimatesubaru.org/forum/topic/46877-front-diff-interchangeability-the-true-answer/
  18. Looks like you've got an OBX Torsen front diff in there Bennie. Nice! Bringing this back up: https://www.ultimatesubaru.org/forum/topic/121582-transmission-reseal-new-bearing-with-pics/ And this for an '89 DL/GL: https://www.scribd.com/document/49628667/Subaru-EA-82-Service-Manual-Part-1 And this for someday in the future: https://www.ultimatesubaru.org/forum/topic/142019-dual-range-swap-into-loyale/
  19. Contact Chris in Libby. Ask him when it could be convenient to get the whole car. Go there with truck and trailer to bring it home. Push the rollovered donor into the garage and pull engine & trans. Push the donor out to some safe, as in not in the way, place. Tarp the donor until spring so people with nose problems don't complain. This will get you some time to fix your trans or find a good 5mt d/r trans you wish you had instead AND spare axles, rear diff, etc.
  20. Hope your garage is heated. It's -25*F here in NW Montana this morning & you're weather is likewise cold. NOAA states for Spokane Valley a balmy -8*F. 🥶 Correction, the low here was -35F. I trust my old time u shaped Taylor mercury thermometer more than the digital one.
  21. Good luck finding spare single range 5 spd trans at the local PNP yards around Spokane - this one may not be available later given that you didn't get it now. Snooze you lose. PM was sent about this deal earlier but I guess you didn't get around to reading it(?)
  22. Don't forget the brake proportioning valve is also back there. I had one leak fluid from the end seal but only on hard braking only.
  23. Did you check out the rear rubber brake lines between the cross member and the swing arms for cracks or splits at the ends? https://www.rockauto.com/en/catalog/subaru,1991,loyale,1.8l+h4,1270112,brake+&+wheel+hub,brake+hose,1792
  24. silverbullet, If you need another trans like yours contact Chris at NAPA in Libby MT, 406-293-3743. He has a Loyale that was rolled he'd like to get rid of. That is the store phone number. He needs the entire car gone, not just parts. All or none.
