smackvt
Everything posted by smackvt
  1. smackvt replied to smackvt's topic in Off Road
    no that was still 3 years ago end of the winter the plow was a snowway predator and usta be 8' i cut it down to 6'
  2. smackvt replied to smackvt's topic in Off Road
    here it is 2 years ago with a small blade upgrade [/img] [/img] [/img]
  3. hummmm yah yah ......how are those upers comming and whats going in those stacks ?
  4. smackvt posted a topic in Off Road
    hears my now dally driver 3 years ago [/img] [/img]
  5. EDIT* Read more repsonses.......apology accepted. Also I had assumed manual.....Auto has no VLSD......worth noting that a welded rear diff COULD have contributed to the clutch pack issue. ??? WHAT ABOUT 90 LEG SPORT (TURBO) I THOUGHT THEY HAD 3.9 VLSD ALLTHE WAY6 AROUIND
  6. and some drilled out 6 lug off nissan, toyota, chev ext:rolleyes:
  7. yes ej22 89-99....... not sure abou the flow thing
  8. my bad i see why its sitting there:lol:
  9. also thinking about rear struts from a gen 3 leg out all the way around ?your thoughts
  10. going to build up the trany w bigger diff or swap out iner cv ends (what i ended up doing, d/r in a 1jen leg) i see that push buton sitting there ?
  11. yes iv been envisioning this for a while now . r u thinking costom a arms with longer cv's ...... ? alot longer ? i was looking at cheep uper balljoints / a arm from like a ford exp....... show me more
  12. Weld the center diff
  13. prob the pump try an giv it a alternet fule suply while cracken the thotle
  14. [/img]5"frt 6"rear..... bald 31-11.50-15" on 5x4.5 hub adapters [/img]
  15. i run 31 11.5 15 swampers on my 90 leg wag ..aka plow car with d/r 5sp and 2.5 dohc it will burn them in 2wd until 3rd no prob .......and also off road where it seams to end up more offin than none ......
  16. Sorry 20 forward and 4 rev
  17. It's gota have 15 forward and 3 rev. In fwd , rwd Or 4wd With only 4 shift levers
  18. did you add the right amount of r-134 ? its labled on the rad spt low side sounds a little to low im thinking it should stay around 40 psi when running dont forget the comp oil
  19. and it doesn't get more custom than this " love the brat" any youtube shots? ?
  20. what you r looking for is a hub shark try napa and use that name:)
  21. idling issues ? :drunk:u know the idle-control is totally adjustable
  22. No Thers a spot where the power wires are all hooked together and some times ( in the east at least) water on the carpet gets the best of them good luck
  23. also ****** under the drivers carpet w seat removed ther will be some large windo sized wires in a juntion where growes some wierd blue funguy that will stop all windows from rolling any where:)
