ccrinc
9
Everything posted by ccrinc
The setting really was awesome, in every sense of the word. No cathedral in the world could equal the backdrop of the snow covered peaks behind them. ps: Joy isn't the kind to "keep Shawn off the forum" now that they've made it legal and are no longer living in sin
I must put some feedback in here: Mal, the reason you haven't been contacted yet is that Rick (the owner and best diagnostician) injured his back very badly in January and has not been able to work consistently since then. (It's hard to work when your legs and feet are so numb that you can't walk.) Yes, we are aware. Yes, we are trying to diagnose the problem. Yes, we stand behind our work. I hope that he will be able to be in the office Monday or Tuesday, will be able to check this out further and offer his advice. Emily http://www.ccrengines.com
The other very obvious thing you are overlooking is that the radiator itself is clogged. Subaru radiators tend to corrode from the inside > out. At that kind of mileage, it's time for a new radiator anyway. (No recore: not very effective on Subarus.) No flow through the rad would account for different temps at the hoses. Sorry. Emily http://www.ccrengines.com
If it's one of the new style steel separator plates, you need to rough up the sealing edge. The new ones are awful! Use some steel wool, then clean it well. Otherwise, the sealant will literally not stick to it very well. Permatex UltraGray 599 IS anaerobic RTV and fume free. You can spend more for the newer stuff if you like, but honestly...IMHO it's no better than the 599.
The guy who used to turn cranks for Ridge Reamer now works for Area Machine. They do very good work. As for someone who "doesn't recommend" us, I guess you can't please everyone, though we sure try. Most who don't are old competitors from 15 years ago or so as far as I know. Emily http://www.ccrengines.com
Remember, the turbo is lubricated by the engine oil. High oil consumption = low lubrication to the turbo. Most common cause of that kind of oil consumption, all else being ok: Bad PCV valve. A $12 part that causes so many engine failures because dealers tend to overdiagnose issues. If they can't find it on a scanner, it doesn't exist. A bad PCV valve won't show up on a scanner because it's mechanical. My bet is that if he had changed the PCV valve early he would have saved himself $10,000!! Emily http://www.ccrengines.com
I recommend you also have the radiator tested. ANY kind of stop leak in a Subaru is not a wise decision. The most common result is clogging of the radiator. IF the radiator is clogged, and IF the system gets burped correctly, and IF you used a Subaru Genuine thermostat, it's possible that by now the headgaskets are also leaking. That would depend on how often and how badly the car overheated. Emily http://www.ccrengines.com
Underhood Oil Leak...Litterally!...Update
ccrinc replied to goatcheez's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Another possibility: oil pressure sending unit? small crack in right breather hose? Just thinking... Emily http://www.ccrengines.com
