10
Everything posted by ivans imports
Wonder how a 2.2 turbo would work in that ?
- 20 replies
- custom subaru
- chopped
(and 5 more)
Tagged with:
Realy was a dud cant work with a non interupted signal bummer so runs the same NOS setup on last years engine keep your fingers xrossed and will let you guys know how she does. No flushing the crapper this weekend !!!!
dude there is 50 of them have done lots ej22b with 99 outback twin cam heads 90 2.2 with 03 251heads 2.2 na with outback twinn cams 2.5d with 2.2 heads 1.8 with 2.2 heads my favort one the 2.2 na with 2.51 phase 2 heads this engine is a workhorse and uber reliabble. Note all theese engines require speatial time and care and mods to make work headgasket mods timing belt mods addjusters mods ect. Head port matching and intake mods. The engine combos have differnt block deck heights I also plane block halfs and heads then all deck to piston heights are checked and addjusted accodingly
Well you know by now that ivans therys are always different I dobut it whould have hurt trans towing it like that as it whould have no line preshure to engage awd clutch and the car whould be tilted up on front filling the back of trans with fliud so no run dry. To be honest i think it can only do damge to standard cars towing them like thiss or runing auto cars not runnning not awding. Did anyone check the rearmost Ujoint ? and how long dose it take to go into gear cold first time in morning ? the longer the worse it is. a'm a bitt confused about the VDC trans the vdc one i pulled apart was exactly the same as regular outback one no diff i could see anyway
Stop runing it till fixed what you cant see is the coolant leaking into the oil and evaporating off if its leaking externaly then its leaking internaly thats geting coolant into oil even tho you dont see it its geting in then pcv pulls the water out but leaves the sugars and additives from coolant in oil needs head surface and gaskets. PS do just as mnay forester headgaskets as outback ones no ej 2.5 is immune to headgasket failure. Have done over 40 heagasket jobs in last 6 months
Oh and good news i thoght i had only a 194 ft pass but turns out that i broke the beam so 3 compleate passes go figure engine broke 2 ft past the finish line but gives me my points for the year end nice
Thanks matt we are installing a 5 second time limit realy on nos sestem to prevent to long of nos burn any longer than 7 seconds and toast !
Nice 620 ! so your engine is leaking oil / coolant from the ds lower part of head and ps front lower part of head ? or boiling over coolant bottle ? dose the engine still run good ? any piston slap when cold ? I ushaly do head surface Head gaskets reseal timing belt idler pullys and waterpump all at same time and pull the engine and put it on stand to do thiss job is way better than trying to do in car. Make shure you surface heads is absolut must be done.
They like to get all 16 dont miss one have all valves checked even if they look good. I have had good luck with CP forged pistons and a'm geting some manley H beam rods to try suposed to be good for 600 hp. Also have many 2.51/2.53 heads here for parts if in need good luck and take your time rushing gets nowere
the subaru trans is still not ment to go backwards mabee addaptor plate to volks transs but then 2wd have seen reversing gear boxs for boats ect have you ever seen a porche 944 ? runs a tube from engine to trans is like 8 ft long but proves that can have engine in front and trans in the back and hold up have seen theese cars with 300+hp and the 8 ft input shaft holds up so could the trans be mounted remotly or somthing like that
found them manley H beams good for 600hp at almost a $ per hp but on there way
EJ22T after swap problems. Fuel cut at 3 to 5 lbs of boost.
ivans imports replied to Steve W.'s topic in Subaru Retrofitting
Sorry is hard to explane the air ratio from the o2 sends signals to ecu so if its reading lean ratio its telling ecu to go ritch and if its reading a ritch ratio its telling ecu to go lean. The 02 sweeps back and forth. can you put a pic of the map senser / boost senser / turbo wastegaste controler setup on your rig mabee somthing hooked up wrong -
whould love to park it next to the buggy at the race track we like short subies !!
- 20 replies
- custom subaru
- chopped
(and 5 more)
Tagged with:
Thats the sickest subaru iv'e seen in a long time fricken awsome !!!
- 20 replies
- custom subaru
- chopped
(and 5 more)
Tagged with:
1600 motor to 1800 tranny?
ivans imports replied to bcmohr's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Put a ea81 in it -
Thats not a bad idea or find a member who wants somthing that can trade or whos coming to get parts anyway I dont think they will let Ivan the teribble axross the border to easy
