Everything posted by ivans imports
99 Outback emissions monitors won't stay set
ivans imports replied to himile99's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXstop blaming the ecu find the real problem ecus causeing problems 3 out of 1200 cars very very rare i bet it has engine problem or exhuast problem is the egr opening try the ecu but not very optamistic
- LPG conversion...
Gauging Interest: Open-Source/-Hardware Engine Management.
could it just control the stock trans tcu ?
EA71 4spd trans teardown - help
put a rag into the crown and pinon teeth thru the oil drain hole to jam it up use a strong 1/2 gun i have a snapon one that is very snapy thiss helps a few wacks with a meatal drift on sides of nut may help relase it
Its buggy time agian
rosette weld ? defanatly needs a hoter weld my welder is a wimp sending them off to welding shop with preheating abillitys and high amp welder. A'm very glad we tried them before race at least we found out before the old ones still work fine and since matt straitened up the rear end the axles should hold up better. I also dialed back the waste gate was at 20 psi droped it to 10 psi to try and keep engine togther then can slowly increase the boost as needed
Blowing through MAP sensors?
ivans imports replied to crazyman03's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOr mabee engine has low vacume and it just thinks the map is bad it can only blame what it thinks is wrong
ivans imports replied to crazyman03's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI found was two types of codes one for senser falure and one for wire contanuity faliure is important to know witch is going on probly a wire harness problem never asume that a code for a part means the part is a problem .
engine swap
probly going to need a non power rack
Healing Heroes Car Show
ivans imports replied to 1988turbo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGoing to be any brats there ?
Have 5 of those trans on ground if cant be fixed 77-80 4speed single range ea71 1.6 l
I whould be interested and have test pilot cars being able to addjust timing or add extra sensers howbout being able to control a 4eat with the same ecu as engine ? thiss is a wall for me. Also boost control extra feul control and nos control rev limiters and over preshure limiters ect
95 Legacy Wagon - Starting Problems...(RESOLVED)
ivans imports replied to sorli's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCrank senser
- ECM re-program chip map data
think it comes off as you lift the housing up may need some heat or a drift with brass punch while holdig housing up
cant get the nut off or the gear off ? may have to be pressed do you have the case halfs apartt ?
Well axles were duds broke my welds on first try next is some heat treatment and a lot biger and hotter welder. A freind sugested to us that a mig weld is hard and brittle and a arc weld is more flexabble and stronger the axle shaft material is a hard meatal to weld to so we will shrink fitt it togther and try welding it agian
timing
ivans imports replied to judymayo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnd confirm marks are painted on the belt in right spot they dont always get it right
The Unofficial "How to Lift your Impreza" Thread
did a outback lift into a 93 impreza 4dr looked good and fit 15 think we put 225 75 15s on it
timing
ivans imports replied to judymayo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe arrows are for valve addjustment
ivans imports replied to sorli's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry a new ig realy and a different crank senser also check main engine harness conector is pluged in all the way and tight
No start condition - Out of ideas
So when i get a ?abble diss I plug in anuther one right next to it with key on and manualy spin the diss and see if it fires the injectors or makes spark making sure cap and wires are on it thiss will tell me if diss is working. have seen many bad diss on ea82 engines drove me nuts back in the day also check were the coil bolts down is the ground for coil transistor i add a extra ground wire from - post to coil bracket. also the ea82 cars had a bad habbit of pulling on the brown realy wire harness under dash and just slightly puling conector off one side make shure is pluged in all the way and turns on with key thiss caused 4 no starts in one year and loyales get towed in for this often
won't start after overheating
ivans imports replied to judymayo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou guys and your grammer spell it wrong just to mess with them !
tires
all awd subarus get 35 front 32 rear at my shop is standard procedure unless have special tires or race tires ect I do know that there is every kind of tire the there are michelins they stand apart and in there own catagory by far the toughest tires out there
ivans imports replied to himile99's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey check your car every year crazy glad i live here no emition testing of any kind. I whould start by making shure no exhaust leaks of any kind reset ecu and drive it see what codes come back. Have been having lots of bad 02 s latly also check flow of egr if equiped
EJ25 sitting in shed
different pistons cams plane block /heads not alot can do with it
