ivans imports
Everything posted by ivans imports
  1. i stand a 6x6 short block against the back side and hit the block with sledge thiss works happens to me dayly stuck salty rims its more of a problem geting a proper touque on them because titens up on center instead of wheel nuts. In one year have had over 40 subarus with loose wheels and 5 or more missing 3 or more wheel nuts make shure you antiseize the center of rim any check your toruque many times in a pattern.
  2. was doing thiss reseal on a ej 22 yesterday x2 cam seals x2 camseal plug orings x1 valve cover set x1 updated pcv plate x1 piston pin oring x1 rear main seal x1 front crank seal x1 oil filler oring and that should do it the single most important one is the cam plug orings as they crack and leak badly
  3. Oh i know thiss one to well the torington bering on the low reverse clutch pack drum has piled up alows the whole internal asembly to shuttle back and foruth and has probly wiped the planetarys out. Or the forward clutch pack has smoked out did it hesatate when going from drive to reverse or from reverse to drive any hesatation in transition indacates to mutch end play in trans internal asembly .
  4. change the wires and use a plane jane ngk plug check the coil for track marks to the base. To find them i mist water on the plug wires and coil pack with hand sprayer and watch for sparks and listen for misses
  5. way cool tool havent ever seen that before dam canada you guys get all the good stuff.
  6. the reason i use the rx one is that the axle stubs bolt in on the turbo legacy ones the axle stub clips in and have a bad habit of poping out and trashing splines have seen two get wreaked thiss way
  7. We have no air care of any kind here at all there is on the coast but not in the interior. I realy duobt i could even find a shop with a working exhaust gas analizer. It whould show a lean condition if you did put one on it. when i pull the plugs on the ?able cars they are white and way to clean 0 deposits. My buggy did thiss untill i put in the 550 injectors. And sudenly it had coulor to the plugs nice tan deposits and came into stioch [sorry that one i cant spell] . Anyway the injectors are just to small to feed sutch a big piston engine. thiss is also why the 2.2 dosent set the 420 code has the same size injectors but smaller pistons. I converted my top feed rails to side feed rails to get more feul to engine. whould not work on air asist injectors but worked good on the 251. One other thing is very overlooked is the comprestion of the engine if low on any holes will not make as mutch vacume witch will not pull hard enuff on map or mas and cerate lean conditions.
  8. deul range all the way have put alot of power through the 4x4 gears and blown only one set of tranfer gears ever and they are easy to change even a push button five speed whould do same transfer gears [no awd trans ]
  9. one step farther i took out the heater elements and put the whole sestem into my 79 wagon seats took a long time but nice wiring was perty simple
  10. came in turbo legacy 3.90 lsd rx 3.70 clutch pack lsd 3.54 svx lsd i use the rx one in my race buggy with 4.44 from a outback you can buy thicker plates for it to make it ajustablle i run mine realy tight works good
  11. no i'm damm proud of are canadian school sestem they use my intire generation as a experement to teach kidds to spell useing phonics gess that dident work as well as they planed. my ecu time is very limited so i rush alot when on here. but thiss is just a small part of my world of fixing subarus
  12. i cut down the harness added a mass air flow and high preshure pump and a return line taped into the gauge sender as brat had no return line and had to modify the distributor gear to fitt ea81 and move the coolant hoses on front of manifoild by the thermosat to clear the disstributor anyway thiss works very good on a ea81 i love it i put some pics on my tbi brat thread check it out
  13. tip you do not have to pull valve body or pan to inspect the trans i bett the forward clutch pack or band you will see whats wrong when you pull it apart keep note of how many shims on pinion shaft and make shure same amount go back in
  14. wow find anything on here no thiners for me but i take them off and wash them out with a low preshure preshure washer works well butt the subaru ones dont clog up because they run so lean catts stay clean and barly ever even start working on subarus no extra feul means no heat in catt has to get feul to get hot. I think buddys fix is probly cleaning the injectors instead of catt and thats why he gets results my money is on lean problem my test forester changed the feul fillter agian and air fillter agian light stayed off for 2 days longer but still came back on.
  15. take your trans and go through it takes me 25 min to pull it apart and diagnose it chances are you may have damaged the stator or not got the toruqe converter in all the way theese trans only fail in 3 ways broken planetary or broken band or the torington on the low reverse stator piles up and somtimes the forward clutch pack i rebiuld many of theese trans is not to hard takes me about 2 hours in total on bench. the pump is part of the cast member in center of trans and can be changed the last broken one the shaft thats atached to the cast member was cracked on the end were tq gos
  16. sorry dident look close enuff the yellow wire is the signal wire go's to the red and white wire on my car and the heavy white wire go's back to the power post on alt and black and white is not used hooking the heavy white wire up will stableize the voltage if you dont have a plug for alt get one i saw a 91 legacy at chillawack pickand pull had a alt on it. I will try and get a picture of the fishing car on here its only purpose is to go fishing i very remote places works crazy good smokes its 31s no problem and i have to hold back on gas or will bust trans makes way to mutch hp for the deul range 5 speed it uses
  17. have taken apart many engines that had damage from sitting that were run with rust in cly makes a mess but will run one had pitts in cly up to 10 thow deep and had stuck the rings to piston ran supriseingly good just smoked i find the rust damage is were the pistons stoped and sat just above that point if is on lower part of cly may be useabble but if on the top of cly needs a rebore
  18. tbi was the best way to fix poopy carbs not the easyest way but works the best the ea81 engines love it
  19. i can plane the heads and block height adjust the comp by useing different thickness of headgasket if you use a 2.2 crank in 2.5 d engine will lower the piston in bore then can deck the block down makes a 2.35 engine big pistons short stroke low comp big berrings and reliablity have made 4 now all work very good
  20. is werid that way have some leak like crazy or no mufler but no 420 codes seems to only efect certan cars the 01-03 forester is the worst offender so far
  21. I do thiss because i have 60 ej subaru engines laying around all a little bitt diferent is a good way to see what you can get away with 2.2 with 2.5d heads or 2.5 with 2.2 heads or 2.5 with 2.2 crank and 2.51 heads or 1.8 with 2.2 heads or 2.2 with 2.51 heads or eas with wrx pistons or any motor you can think of have done about all of them my daily driver is a 09 sti short block with 99 twin cam heads wrx turbo western star intercooler in a 79 wagon with 5 speed high low it works good
  22. TBI throttle body injection comes on 90 loyales and up and fitts a ea81 or ea82 engines i cut the harness down and put the tbi on have it on my 81 brat with ea81 more power and better throttle reponse and no carb problems has been on it for 10 years no problems
  23. spray some engine store into it before you turn it and feel for tight spots when turning it if smooth should be ok any scratching or resistance then mabee not ok
  24. heres a parts list for you cam seals x2 crank seal x1 cam orings x2 oil pump shaft seal x1 oil pump oring x1 oil pump mounting oring x1 valve cover set should seal it up the ticking is caused by air geting into the oil thrugh the oilpump shaft seal is a small seal in center of oilpump and is critical to come from subaru and most important seal on ea82
  25. feul temp senser will not do thiss could set code but pump will still work. Just one realy is controled by main realy and ecu the main has to power up before the feul pump realy can turn on
