Everything posted by ivans imports
ea82 radius rod/lift kit questions
whoa volksy van !
'98 OBW Need new engine.. Anyone used JDM?
ivans imports replied to samneric's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhave been experimenting with sufrfacing a whole short block asembeled whould be neat trick it fitts in my surfacer and could be done without tearing down shortblock because my surfacer comes up from bottom whould not get materail in block and whould get a perfect surface for headgaskets to seal. Evry block half i have surfaced had at least 2+ thow warp worst on #4 @#2 i surface every one and new rod and mains if over 150000 kms on it [ or has ever got hot ]
Brat seats
Here's a question for you older brat guys how leagal do you think it is to let kids ride in back seats ? I have been leting my kidds ride in back but worys me that could get pulled over and fined. The laws here are very strict and whuold not whant to be stuck on side of road with kidds. I took the old brat to car show on weekend and it made for a good topic half the people said it was ileagal other half said it was ok but none actualy knew i'm the subaru athority around here and i dont know I will ask are local rcmp and see what they think. Any of you brat drivers have any ideas ?
Faulty wheel bearing '00 Outback?
I bought a kent moore wheel berring install tool specificaly designed for subaru front and rear berrings dose them on car cost 1500 $ but have done over 500 berrings with it
watch out for worn hubs ! have seen many wear the hub where the berring rides and the new berring will not sit tight on hub and works loose and wreaks new berring have had at least 10 thiss year all bad hubs happens from running with loose axle nut or the wrong axle nuts there are some that the collar of the nut is bigger and dosent titen up right thiss problem comes up alot right after axle jobs
83 1.8 EA81 Will Not Accelerate
plug wires wrong cly or way retarded timing what did you set the timing to ? should be 8-10 btdc with vacume didconected and pluged
90 legacy L help!!!
the over preshure switch on the recever dryer mabee to mutch preshure and will not alow it to turn on
Head lights quit working out of the blue?
alt is over chaging and belw the bulbs check carging voltage no more than 14.5 running with everything turned off at 3000 rpms
ivans imports replied to samneric's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdont orbital grind the block have seen damage up to 6 thow from theese tools and can get grinding debrie into engine should be torn down and surfaced and reberringed will save you mutch greif
Slave Cylinder or Master Cylinder? Answer Is.... Neither!
use a cherry picker with a long strap to lower trans down works spanky i bett your clutch looks like that blownout springs. I agree with the exedy clutch kitt top notch
ah man new problem
oil pump seals .
the back side of release fork gets dryed out have had luck spraying a bitt of lube down from above fork to losen it up
legacy clutch disc blows up after about 2-3000 miles
ivans imports replied to Coyote's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXriding the clutch ? or just cheap rivits watch out for china clutches the rivit steel quality is very low
ivans imports replied to Coyote's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe berring on the end of main shaft is the one that fails but will not damage clutch have seen many fail but never seen it do clutch damage sounds like poor sping quality in disk to me i see lots that springs are hamered out cheaper clutchs ar't always a good deal try a exedy one
One small tip have been running into the clutch peadal stuck to floor when hot engine the fix i found was to change out the fliud to dott 4 has a higher boiling point thiss seems to fix problem still a pain to bleed
Head gasket not the big problem here
Did a engine on 05 forester other day had to teardown to crank had the # 1 rod berring was bad had been run low on oil and caught just before damage just enuff to wipe the berring but only #1 the rest where fine anway when they are run low it hurts #1 first anyway thats # 6 in last two months all bad rod berrings
ea81 locking flywheel what to use?
come from the bottom with a big bar and lock it in ring gear agaist the block works well may take two people
EJ22 engine question
I see them burn oil when the oilring spacer gets worn in one spot you can see it on the ring spacer gets a realy shiny spot on it when it gets worn i bitt it cant push the oil scraper rings out enuff and oil bypases the rings needs to be reringed
Three months under water...no problem!
ivans imports replied to Deener's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlove it !!! ahh the rust will wear of the cly walls soon enuff
oil leak for 3rd time in the last year...
ivans imports replied to mcbrat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXin the last year have rebiult 40 engines of those 15 had at least two loose screws on oil pump plate the top 3 screws dosent seem to matter 2.2 2.5 year or milage its like they where missed at factory theese are all engines that oilpump had never been off even with as low as 90000kms loose screws i however could not see thiss causing a leak non of theese engines where leaking from pump unless had a black seal that was cracked
ej22 acceleration problems
carefull messing with injectors as it will dump feul into piston and could hydroilic engine and bend rod i do come across dead injectors from time to time but never more than one and they are ushaly water or rust damaged
Intermittent Engine problem on EJ22 Legacy
ivans imports replied to vamos's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXfeul pump and feul pump check power distibution box have seen fuses that have shook loose cause thiss had impreza that the 30 amp fuse had broken end and was just barly contacting had very intermitant starting problem the fuses dont have to look bad to be bad
4EAT labor costs?
ivans imports replied to SUBARU3's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThiss may help when i do theese trannys i use the cherry picker with a long strap lower it down from above and hook to were the strut brace bolts up then you can lift it up on the front while someone holds up the back works very well and no heavy lifting and it will hang so you can move it into place thiss is how i did them for years untill i got a hoist and tranny jack. I charge 500 for install with a cherry picker and a buddy should take you about 4 hours
97 legacy outback - running on 2 cylindars
ivans imports replied to DavieGravy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXget the odd ig mod that loses one side but whould be dead on 2/4 or 3/1 and is very rare to go bad timing belt or burnt valve or the idle moter is come unpluged they send the injector pulse through the idle moter to give it its signal if its unpluged or damaged will not fire #1 injector put a noid light on injector and look for injector pulse
85 subaru brat oil pump
the late model ea81 is hydrolic lifter type if oil preshure is low will tick thiss engine dumps off its exsess oil preshure through the pushrods and rocker assembly they put restictions in the rocker shafts to hold the oil preshure in the block the last one i had with low preshure had a bashed pan that had been pushed tight to oil pickup screen and was restriting the oil pickup screen
