scrapdaddytatum
Everything posted by scrapdaddytatum
  1. so i am building a 96 legacy gtb for a customer and i am wondering what the market is for these cars, ill give the specs i want to know what you would be willing to pay for the car so i can guage wether or not to try and build another and sell it 1996-99 legacy mail car (US car with clear US title) in good shape 1996-99 BG5-GTB ej20h twin turbo with manual trans and posi rear(4.44 ratio) white line springs/kyb agx adjustable shocks/whiteline sways wrx brakes wheels tires(drilled brembos/EBC greenstuffs) JDM projector headlights JDM power folding mirrors JDM gtb front bumper USDM legacy OB hood with scoop with power windows and a/c no anti lock brakes new wheel bearings and axles all round, sti mounts(motor and trans) stock interior i know how much it costs to build and how much i would need to sell it for to make it worth will but i want to know what people that know would be willing to pay thanks scrapdaddy
  2. hey you got RHD drives there??? in tasmania, i havnt been there but iv been to aussie, want to find and send me a clutch pedal and clutch master assem????? ill pay you well or send you parts what ever suits you cheers scrapdaddy
  3. i am a very well traveled veteren, and linguistics was my specialty, i have an natural nack for picking up foreign tongues. its a blessing and a curse, i dream in 3 different tongues, my first tongue was creol/french, then spanish then english all by 6, its been an interesting life.......
  4. i think all american mail cars were auto's but i dont know for shore?>....
  5. i need a manual pedal set and clutch master for a RHD legacy, 95-99, mail car parts will work, japanese, Ausie, NZ, and brit parts will work too, any help out there also i could use a manual for a 96 twin turbo legacy, english prefered but i do speak and read german, manderin, chinese, french, spanish, some baltic languages, russian, poshtun(indian) but not japanese any help????/
  6. what could be turning the relay on im confused on this i have swaped all 4 little relays in the under hood fuse block with no change, also pulling the 10amp a/c fuse stops the fan a/c doesnt actually work---no freon and the switch on the inside is off, and the defrost is not on
  7. so i swaped the ecu, no change, swaped all the a/c relays in the front fuse box, no change, when i pull the 10amp fuse in the underhood box the fan shuts off, both ecus acted the exact same everything on the car works fine, well a/c needs freon but thats it and frreon level should not turn on the fan this one is stating to bug me next idea.........
  8. ok, so i looked at the connectors ( i am now in pain, dont ask) they are not hooked up darn it, i was hoping on that
  9. well i will look and see, i bought this car from the junk yard along with 5 other legacy's( i flip them) and have done a tranny swap and rad support front metal, and 60k service to motor and some interior work, but i havent touched the connectors myself but i will look and see
  10. update the TPS problem was related to an loose engine harness main plug i will check the fan relay monday the "soft" shut off is still confusing me does anybody think the ignition switch could coase a "soft" shut off???
  11. will do, i did mess with the harness a bit when swaping the trans i hope its an easy find, any ideas about the rest..........
  12. so the car is rebuild new trans, front sheetmetal motor is original 1.check engine light-code 120 TPS replaced and played with light stays on 2.a/c fan runs from key on allways 3.doesnt shut off right, roll's off ,dies slowly runs good, trans seems good, i cant find anything wrong with throtle body to effect TPS in bad way code 120 is the only code any help
  13. ok green gave a double flash and nothing else black gave me codes 33/35/51, the 51 is it being in nuetral 33 is a speed sensor 35 is purge control syl car runs fine except for the occasionla lope any help here i dont even know where these sensors are
  14. my alt plug was cooked but i replaced it, checked battery, its ok, i still get that beeping sound plus check engine light comes and goes, how do i get codes out of this beast
  15. ill get the battery tested too, but its new
