Everything posted by subaru_styles
who's red turbo loyale?
subaru_styles replied to thesubeguy's topic in Meet n' Greet. Your USMB Welcome Center
sounds cool, you should take a pic next time -
nice vids!.. +1 for The Faint
phew:rolleyes: i was having withdrawls..kinda of funny how most of us flocked over to nasioc. that thread went to crap really fast.sorry:lol:
winter plans - suspension!
subaru_styles replied to nkx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
here's a pic I took showing the difference in struts, as thats what lowers the car as for the rear you can fit 2.5 ID springs in the rear, which many companys (afco, eibach, etc) make in a varity of lengths and lb. ratings. im currently going to be using some eibach springs that are about 2" shorter and about 20lb or so stiffer than stock rears. its for the coupe so im gonna use adjustable wagon shocks as they're higher damping than non-rx coupe shocks -
well just putting 2wd springs on your struts isnt really going to lower the front, its just gonna make you have gushy soft springs in front. -
if you are goign to take the front down you're going to want to use 2wd xt front struts.. preferably with stiffer springs (RX, or 2wd xt6 if you can find them) for the rear you will need a set of rear swing arms with the sway bar mounts. xt6 awd sway bars are the largest.. -
ok here's the deal... i need, (and haven't been able to find) a specific egr hard line. one form the bottom of the head to the egr valve from a turbo spider manifold.. so would anyone have a part # for the pipe w/fittings? i need to see if i can even get it from the dealer? -Brad
Pillar guages for EA82 cars?
subaru_styles replied to Tin Soldier's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yeah i have a gen1 impreza single pillar pod..fits great -
thanks man..wait till you see it and my wagon in a few months :cool:
kibs45, it looks like this..right? its the ea82 "gl/loyale" body style . you mostly see wagons and 4drs
gl turbo coupe or rx?
subaru_styles replied to GlTurbo1987's topic in Old Gen.: 80's GL/DL/XT/Loyales...
difference between teh 87 turbo coupe and RX coupe.. RX gets the full body gorund efffects, paint matched (turbo coupe just got front dam & wing), paint matched mirrors, and the special high damping suspension with stiffer front springs -
Idling problems...EA82T, '87 RX
subaru_styles replied to TheSubaruJunkie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
temp sensor or purge, or both, check them out -
just so you know, thoose cheapy HID kits are all garbage (and yes even if they use philips ballasts) ..teh only correct way to use an hid setup is for it to be inside something that is designed for that type of bulb ie; it needs to be in a HIDprojector . ....composite headlamps and thoose clear h4 converison lamps do not have the "reflection design" to properly project the hid pattern.. example http://hidtech.com/view/1064770217 this info comes from first hand experiance of "learning from mistakes" due to setting up a true hid system in a honda (no it was not mine) however, since the h4 conversion lamps are crystal clear, you can do a retro fit into them. hope that helps
wrx intercooler on rx leone good or not
subaru_styles replied to gravilboy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
well considering the ea82t doesn't have an intercooler, it would definitly be a worthwile mod..plus the wrx IC seems to fit quite nice in an ea82. <--has a wrx ic in his wagon -
What engines are in these cars.....??
subaru_styles replied to NVBigBlue's topic in Old Gen.: 80's GL/DL/XT/Loyales...
get both cars. if that GL is a 5spd, swap trannys & diffs to the turbo loyale + spare parts on hadn!.Im sure theres maybe a few other littel interior things to trade over as the loyale is somewhat stripped down form teh Gl;s -
Get the RX! im sure when later on it will be easier to find an xt6 (if you want one) then another 3dr rx
Vicious LSD 3.9 Rear end/EA82 installation
subaru_styles replied to torxxx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
cool. i too just picked up a 3.9vlsd last week..but its gona sit for awhile before it goes in teh wagon -
NA spyder on Turbo?
subaru_styles replied to blownbimer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
well with my never ending digi problems i had to take a pic with my camera phone -
NA spyder on Turbo?
there is a hardline that is right under the t-stat housing. it curves around toward teh turbo then there is a short peice of rubber line between that and the turbo hard line -
NA spyder on Turbo?
tomorrow i can take some pics for you has i have my upper manifold removed on t3h wagon.. -
i bought the turbo coupe, and sold the red car back in june as i really didn't have the space for 3 soobs
werd, aaron's a friend of mine who bought my last coupe.. ^^good ole muddy pic:banana:
