Everything posted by Myxalplyx
Monster Justy
I am in love with that Justy. It is just about everything I ever would have wanted in trying to make a Subaru fast and the model I'd choose to do it in. Omg!! I am stoked!
Turbo XT or XT6?
Good luck on whatever you choose Psyko. Can not wait to see what you plan on doing to the XT6.
XT6 Gear Ratio
So Subex!! Are you going to go ahead with this project?
The Hyperbolic ER27 Twin Turbo Build
With 15psi, I say he will make between 200-250hp. Depends on his compression. Good luck with the project. Looks nice! I agree, 15psi is not alot. Just need to keep it cool and give it fuel.
Dyno run with my coupe
Going to check it out now. Cab, If you see this, can you send me your dyno file if you have it? I save everyone's dyno file and compare them to mine and analyze for days/weeks/months (because I have problems). I am talking about the file in .drf format. That is awesome being naturally aspirated and all. My RX turbo dyno'd at about 79hp stock. You are only 8hp off from it. Nice! I just looked over at NASIOC. I did not see any pics over there.
170˚ Thermostat
http://www.ultimatesubaru.org/80s/ea-performance-page/subaru-ea-performance.html "The thermostat is one of the most overlooked performance enhancements. By reducing the operating temperature of the engine a number of things happen. First, volumetric efficiency is increased. That is when the engine runs cooler the air/fuel mixture entering the engine is also cooler. A cooler mixture means the mixture is more dense. The higher the mixture density the more that can be packed into the cylinder. You would be surprised how much more responsive the engine becomes just by changing the thermostat from 195°F to 180°F. The next step would be a 170°F thermostat. 170°F thermostats for the EA series engine are hard to find however almost any 170°F thermostat with a 54mm diameter will work. The little 'jiggler'' valve is not required but its preferable. The valve helps to purge air in the system and allows a slight flow of water around the thermostat to eliminate any temperature differentials between the area around the thermostat and the engine itself. Second, with the combustion clambers running cooler a lower octane fuel can be used. Or if you're looking for better low-end torque, you can advance the ignition timing a few degrees without having to worry about detonation. (Author's note: After installing a 160°F thermostat the performance increase was negligible. However, I was able to advance the ignition liming another 2° and use 87 octane[R + M/2] gasoline with NO detonation at all!)"
Good to see you have gotten a baseline data on your car. Need more info about your car though. What is it's current state of tune (mods)? Still stock? It is turbo right? Thanks for putting up this info. Also, don't forget if your car is turbo, you can get upwards to 35whp just by installing exhaust parts and changing the turbo (Ex: Techworks parts). This is without turning up the boost and keeping your same air/fuel ratio.
Turbo XT or XT6?
So, what are you considering as a swap or retrofit? If you are planning on a 6 cylinder to swap in, I'd say consider the XT6. If 4 cylinder turbo, go with the lighter XT turbo. And what Gary said!
I kill Subarus
Good pics! Keep the covers off until you can get some new ones. Just try to stay away from going too far off the road, if you do.
So i was thinking again....thats dangerous...
OMG!! That sucks!! Literally..
XT6 Gear Ratio
Not sure Gary! This is foreign territory for me.
I kill Subarus
I was wondering what that cogged piece is myself. Sorry to read about your misfortune. Will stay tuned!
XT6 Gear Ratio
Gary! Me no hijacker...just over-excited that someone else was thinking of doing this. I would like to see him go through with it...or even you. Haven't tried looking for a shop again. Big YES for 4.44 gears in AWD automatic. Yes, going in tranny with modified valve body (or so the shop said anyways). What do you got cooking in your brain Gary? And why are you awake so late? BTW: Just got back up from the basement scavenging for parts. Found these--> Is this all that is needed for a 4.44 swap? If so..Subex..at least you know what you need to do. I'm ready like...yesterday. I provided the little calculation above to give Subex an idea on what he could expect with the swap/upgrade if he were to do it. Also Subex, I have read stories that it would help but am not sure. I would gladly be a guinea pig though. Just hate sitting around wondering how things would be. Life is short. Are you going to go ahead with the swap/upgrade? Don't give up that easy. These 'little' things add up.
XT6 Gear Ratio
I was trying to have this same thing done on my XT6. I have the 4.44 gears for the front and the rear. Was talking to TomsSVX on the SVX board to do the hookup for me since I do not know how. I just need it installed. I a ready to go. I KNOW the car will be faster. Here's what I posted at the XT6 site. *Added for personal reference* Gear ratio torque "What many car enthusiasts don't know, or simply overlook, is that you can get more performance out of the power you already have. Power (more accurately, torque) is never delivered directly from the flywheel to the pavement, without first being multiplied by gear ratios in the transmission and differential. The math is pretty simple: A car with a 4.0:1 gear ratio puts 33% more torque to the wheels than a car with a 3.0:1 gear ratio with no increase in engine torque. "My estimates using above 33%---> 3.70 to 4.11 = 16.5% more torque 3.70 to 4.44 = 23% more torque I am going to keep a close eye on this thread. (Headed to the garage 1:57am in the morning to scavenge the 4.44 parts).
Or try a 4.44 gear swap in an auto (If that is what you have). That's for another thread though. WJM and his ideas.
Ea82t
Brian, That is a beautiful setup. Seems like the car should have came like that from the factory. Would be nice to see someone sell that as a kit. The brackets that stand the intercooler up is sweet.
Ea82t
Not to go to far off topic but maybe this link will convince you to get an intercooler installed (Especially being higher compressioned and all). http://www.ultimatesubaru.org/forum/showthread.php?t=15554&highlight=inlet+temp
Ea82t
Use what the owners manual says to use. If it pings, use the next higher octane. I used 93 octane because I was wuss and didn't want to try and wait to hear ping, detontation, etc on a lower grade octane. Also, I remember that thread that was posted with the inlet temperature of a non-intercooled EA82T. I loved that thread and the numbers. Hot air is not good. I thought of cylinders #1 and #3 overheating and the cooling system problems people have had over the years. I thought of headgaskets going bad and leaking. Using 93 octane gave me a warm, fuzzy feeling inside, even when it was intercooled. Car ran great even though the body went all to hell. Hrrm...I think that is all. :cool:
Nitrous and Turbo EA81T EA82T
I wish I could say yes. Must be WJM or someone else here though. My plans were to get the RX in the 13's, in the 1/4 mile. I just wanted to be able to say I was the first to do it.
I am talking either dry or wet. I have only ran a wet system on one of my XT6s once. It made about 40whp or so on the dyno but the power was not smooth. My #3 cylinder had really low compression on it so maybe that was a factor. I just wished I had a chance to use the happy juice on the EA82T. Looking for those who has and their feedback.
Brought the RX home today...
Beautiful looking RX. After you fix it all up, get rid of the funky smells and get bored with it, shoot me a PM.
What Cam grinds avail for EA82T ?
Delta Cams come to mind. As to the specifics on the cam grind numbers, I can not remember. Perhaps WJM and others can fill in here.
Yeah, I am back from the dead and lurking. Still have not read a whole lot in the way of racing and horsepower since the WJM wars. I miss my RX turbo dearly (Pours beer to the ground) since it rusted away. My next step with that car in the way of horsepower was to add a 50-60hp shot of nitrous. Has anyone done this here and if so, what was your experience with it? I know these cars are ancient but still. I was hoping I had a chance to do that. Thanks for any feedback on those that tried it. I still have my Techworks parts in my garage, waiting for another turbo model to someday mod up again. Until then...I sit.
TD05H or Big compressor VF7?
You could always try to find a Techworks kit off of someone on here. I got 35whp out of mine without turning up the boost. And reliably to boot! Car had no problems. It just rusted itself too death and went to Gary Gross... Oh...and the turbo with the kit was a GT46 (I know I got it wrong probably) ball bearing unit. Spooled nicely!
YESSSSSSSSS!!! It's gonna Sell w00t!!
Good sell! Makes me wonder what he wants with an XT6 though.
