idosubaru
344
Yea. It’s 100% benign for pre 2005 models. The ECU doesn’t use that data for fuel trim. It’s not indicative of anything but emissions. the biggest issue is you can’t tell when the code trips again. It’s routinely ignored in states that don’t check the check engine light for emissions or inspections for 100s of thousands of miles. Install an extender $10 on eBay and the code will go away. It’s just a spacer - remove rear O2 sensor, install spacer and reinstall O2 sensors into the spacer. It just makes the rear O2 sensor sit a little off the exhaust stream which is enough to trick 90% of them to not trip the code. repair usually includes replacing the converter. Aftermarkets sick and can cause the same issue in 1 month or 2 years. Subaru converters are $500+. So it’s not economical to repair if it’s not needed. it can often be caused also (conflating causes with an tires converter) due to an exhaust leak, fuel trim, vacuum leak, etc. but it’s nearly impossible to track down unless you’re a signals wizard. Most of the times the repair will be installing a new converter and making sure the engines working properly.
Good to see you beast! Lots of your parts went to good use and I still have quite a few! Yes cam and crank stay with the vehicle if you swap the engine swap the original crank and cam sprockets onto the new engine. Done that’s it. The swap that person did is a mountain of headache though because the idle control differences aren’t easy to work around. The ghetto work around is to just prop the throttle plate open but that’s not a great soltiuon either. good to *see* you. drove a friend to NH for grad school and passed by Albany and northern NY, beautiful.
Yeah they’re decent combos. Also have a 2002 H6 outback with 260k on it as well. mileage is comparable to H4s only under ideal driving conditions. Even moderate City, mountains, heavy foot and they plummet quicker than H4s…which I’ve owned a ton of too. The headgaskets don’t seem quite as bad as H4s but can be a problem. I bought the Tribeca (when they were still 5 digit vehicles) with blown headgaskets (cheap) at around 120k. Installed a JDM. The OBW is all original. I’ve owned others, been around lots of H6s and seen other headgaskets and repaired them as well. It’s a beast of a job compared to H4s. I like them personally, but they can hose someone who can’t DIY or doesn’t have a good reasonably priced mechanic or doesn’t purchase them well.
Ah I see. Yeah turbos and H6s (Outback legacy Tribeca) got the 5eat. Any Outback or legacy 5eat will work but final drive needs to match. If you find a diff gear ratio swap the matching rear diff. Not sure if Tribeca will work. The 5eat isn’t the beast like 4EATs but they’re not that bad, I’d just change the fluid and see how it does. My Tribeca has 260,000 miles on a smooth as butter original trans. I’ve changed the fluid once with Amsoil.
Determine what is in your car before thinking about swaps, which isn't likely to happen anyway. 4 ways to tell: 1. look in the cabin, does the gear selector move only straight forward and back and have a button on it and the base plate says P-N-D-1-2-3-R or some simlar combination for Park, neutral, drive..etc? That's an automatic. If it's a loan stick that has play left/rigth as much as forward/back without those demarcations then it's a manual. 2. Post a pic of the gear selector/center console, and we can tell you or compare to online photos of the same 3. plug the VIN into an online VIN decoder and it'll tell you what transmission it has. 4. Auto's have a long dipstick under the brake master cylinder on the drivers side, and a front diff gear oil cap on the passengers side. Manual only has gear oil cap on passengers side. This is too funny not to mention - I'm not sure how to own a car, see the trans fluid, and pull the engine without knowing what kind of transmission it has, the process to remove the engine is slightly different for each. A 4 speed easily installs in place of a 5 speed, they're like lego's and it bolts right up, but getting it to run is mad money or labor that's out of 99.9% of people's time or money thresholds. Wiring, TCU, cruise, cables, pedal assembly, driveshaft length differences, center console.... lots of work and parts. Yes other manual transmissions in other subaru's will fit that vehicle. if they have a different gear ratio you'll need a matching rear diff and your speedo will be off by a litlte bit.
1987 Subaru GL 4x4 steering rack suggestions
idosubaru replied to kanurys's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Someone post some manual racks for sale from rust free New Mexico a few times. Can’t recall if EA81 or EA82. have you looked for used one? reman racks are still available. -
Don’t recall year/model. I remember being surprised XT6s ran fine without an instrument cluster when I had a ton of them so I did it with later EJ (or possibly EZ) and they drove fine to work. It’s odd driving not knowing if check engine light tripped, speed and engine temp. some folks on vanagon forum mentioned sometimes it takes awhile for issues to show up with a lack of VSS so maybe I got away with it for a lone commute to work? Which I say because the Subaru vanagon conversion folks have to deal with this often maybe you could see what they say if you strike out here? Let us know what you find.
$30 a tube no kidding. cutting the bushings out and pressing in new ones sounds terrible but you’re probably right. this is closer to a farm truck than long term daily driver so, time being money, I’ll probably try window weld for the learning experience. ha I’ve got that same sika flex in my garage. Fascinating never consider using it for bushings.
Exactly. used Subaru pumps have higher 3 year survival rates than a new aftermarket. I would never install aftermarket unless I had an uncanny reason.
- 11 replies
- 1
I’ve driven EAs and EJs without an instrument cluster. It’s very weird to do so but they ran and drove fine without one. I wonder why that’s possible but you need it for a swap?
mud dauber nest. They paralyze a spider. Stuff it down each hole and lay an egg on it. The baby hatches and eats the paralyzed spider. There’s a rubber gasket under each lid. Have a replacement gasket or back up tube of sealant for triage if it rips.
- 11 replies
- 1
