idosubaru
    344
  1. Swap the stubby shafts (install each one on opposite side) and see if anything changes? If it happens the moment it's out in gear Id want to watch or video tape it when it happens. It seems to me he is aware that nominally the stub stays in the trans and the axle slides onto it and is held in Place with a pin. He is saying the stud pulls out. He's. It saying he is pulling it out.
  2. also - OEM automotive audio hasnt been a strong point in this market and Subaru is a good example. The offerings are rarely modern and slick. They offered straight up AUX-in like 20 years ago on very few vehicles and I wish they would have kept it and improved it - but have been as consistent as lottery numbers instead. That's why there's all sorts of hacks, the jazzy engineering mod, FM modulators, people swap in stereos with tapes just to use archaic tape adapters....silly for something so easy its easily hacked and DiYed by determined folks. Very very weird. Give it a go of course but I wouldn't completely rule out being open to a better long term solution like installing aftermarket capable products.
  3. Typed words are trickier to fully understand - to be clear - Why does it matter if the icon is missing? Id focus more on functionality - what symptoms are you having besides the light not coming on? Have you tried reinstalling the app? Looked up a reset or clear feature for the car? Any changes to the car - mods, work, battery drained? Everything else works fine? Check Cars101.com is a great resource for remote, security, FOBs programming and troubleshooting. see if they have starlink covered too. Did you Google it? Stop into the dealer and ask in person.
  4. At least you caught it and figured it out. I'd chase all the threads and clean them up incase any were compromised.
  5. It will have some small additonal value if it's in great condition (it's not a classic or novelty people would want to restore), but it's a small market, even for Subaru which is already smallish) so you'll need exposure to extract that value. Rust free, great condition, one owner, low-ish miles, some records and documentation will probably be most of its value. Offer me a percentage and I'll sell it for you. Lol
  6. Wish I had seen this last year. No way I'd worry about or touch it. That headbolt isn't going anywhere nor going to "give up" any tension or cause any issues. I mean look at your intake bolts - they're screaming at you that there's no chance those bolts are giving any ground without specific focused applied forces. I'd love to hear what you ended up doing.
  7. I'd use used Subaru head bolts before aftermarket head bolts. You're saying one head bolt broke right? 1. Chase the threads first with a tap before installing the head bolts. Pay particular attention to the bolt hole that snapped. 2. Carefully oil the threads - not so much that it pushes out and runs everywhere. 3. Thread the bolt by hand without the head first so it's not under any tension and see how easily it installs. 4. Verify your torque procedure 5. Verify the units you're using - are you converting or how does your torque wrench read? 6. Test or calibrate your torque wrench. How old is it?
  8. In my experience it'll run great for awhile with no noticeable symptoms and then catastrophically fail in a few months, maybe a year. i'd install another transmission and don't want to say it since it makes it easy for unsavory people to hose the next owner should they sell it. i think he's saying the engine was removed, not the transmission.
  9. Ask Scott from SJR - I'd bet he knows places that have installed his stuff before.
  10. This: Look again. Look up FSM or google pic's to locate bolt holes you might be missing.
  11. Subaru? EA81 or EA82? I often google and check part numbers at multiple places. If something is the same in many places and showing up on Subaru forums correctly it's usually good. some people post a link to *one* parts source and wonder why it's wrong or confusing. It's like they're trying to make it hard on themselves. Someone just did it last week on another forum. If you find one place that's inconsistent or says something different than every other place then it's probably wrong. I order XT6 wheel seals and frequently get the incorrect 4 cylinder seals - how hard can they be to get if I always get them when I don't want too? Lol
  12. It sat for 25 years - is it now not going to sit? I'd set traps, poison and kill every rodent I could. Remove all the debris you can. Ignore every comment about liquid concoctions that work. They don't. They cant get behind panels, folds, inside materials, passages, etc. Rent an ozone generator and run it for at least 12 hours. Fire departments and some hotels usually have them. Or rent them, places that rent equipment (bobcats, backhoes, tractors) usually have them. There are even online companies that will mail you one to rent. before running it, expose every surface you can - remove floor matts, seats, easily pulled panels, open glove box, etc. hook up a battery charger so you can leave the fan blowing all night and circulate the air. Sometimes I'll run it all night but just a few hours with fans running. Make sure the vehicle isn't accessible by anyone while it's filled with ozone. That's the only simple method of neutralizing *really nasty* organic smells from pet, smoke, mildew, or rodents. Works very well.
  13. ...Says the guy who has been around racing...very valuable to pay attention to this! my suggestions regarding failed "locked" VLSD's should be taken no more than light use daily drivers.
  14. Then you have a VLSD center diff: Find a failed VLSD and swap that into your car. People replace the VLSD's or transmissions and throw the old failed ones away. They fail to the "permanently locked" state, so what is typically a throw away failed VLSD could be free/cheap and give you RWD once you remove the front axles. Or:
  15. Great thanks. Do you know that 05 outer CV will fit onto an 04 axle shaft?
  16. gptcha. Makes sense 04 and 05 would differ due to that bearing change. Will 00-04 inner joints install on an 2005+ axle?
  17. Great! Just to clarify you're running: EJ knuckle FWD impreza rotor and caliper bracket XT6 caliper and caliper slide pin Do you know if older style EJ axles will work in 2005+ knuckles? I'm wondering when I swap if I could use 2005+ knuckles with bolt in bearings and older 00-04 axles.
  18. Have you checked to see if the newer H6 plugs are the same as the older ones? I've only done a handful but based on the remarkable condition of H6 plugs I wouldn't replace them early on an average use daily driver.
  19. If it has the external spin on filter, change that. The internal filters aren't even filters, they're just screens and are pointless to replace. H6 spark plugs are tricky. You can google it, there are multiple ways to attack it but bottom line is there isn't much room between the valve covers and frame rails. A. some people juggle various size extensions and sockets and pulling some from the top and some from the bottom. B. some people unbolt the engine mounts and jack the engine up for better access (there's only 2 14mm nuts on the bottom holding the engine in place so it's not hard). C. the spark plugs are easy to replace with the valve covers removed. Since the VCG's (valve cover gaskets) aren't likely to make 250,000 miles anyway, I usually just do both at the same time and check the valve clearance. Makes spark plug changes easy. If you're going to own the vehicle 200,000 or so miles - you'll basically typically need plugs and VCG's once. Might as well do them at the same time and check valve clearance while you're at it. H6's rarely need valve adjustments, but it does rarely happen. The older H6 plugs look almost perfect after 100,000 miles and easily surpass those mileages. If I had a new H6 and they have the same plugs as the older ones I'd probably just leave them until 125,000 miles and change the spark plugs and VCG's at the same time.
  20. All 97+ Subarus are interference. Subaru OEM is best for timing stuff. I use Gates kits but some question the quality. The Import Experts used to supply great kits but I haven't bought one in at least 5 years I don't think. Subaru headgasket. I think you'd need to hear from unbiased we'll versed shop owners/techs (GD, Crawler Dan, GLoyale) about the efficacy of turbo heads on nonturbo blocks over and above the regular OEM gasket. I've done a lot of EJ head gaskets for a DIY person but my experience is still anecdotal. If you're really worried about it I would search from comments from them over waiting for anecdotal comments from folks that have only done 10 or so. I'm pretty sure Crawlerdan has used hundreds of Fel Pro kits, as have others, with excellent results. Resurface the heads. If the shop is set up to do it (rarely) resurface the block too Aisin is the OEM water pump and available aftermarket. Gasket OEM but I feel like the Aisin pump I just bought came with it.
  21. You first want to make sure the transmission or rear diff weren't replaced with an different final drive ratio unit.
  22. You can also replace one at a time or just front or just rears. Replace fronts and simply disconnect rear once they're aired up and leave them. Or jumper appropriate height sensor wires for removed air struts to mimic height sensor "In range" status so you have coil over installed but it acts like good air struts are in place indefinitely. Do your front and rears still hold air?
