idosubaru
  1. 1 hour labor, 1 hour alignment. It's really easy but the press fit end getting stuck and lock nut and removing it without a special tool (or buying/renting the tool) can be troubling if you're not well experienced with tight fasteners. I can't see yours but that lock nut and the end joint press fit - can be crusty rusty in the northeast and cause a bit of a wrestling match without good tools and torch. I'd inspect the rack boot really well first or have a new steering rack boot on hand just in case - removing a quarter century old boot might render it unusable to reinstall. That's the most dangerous part on the entire vehicle, I'd use Subaru only for tie rods. I would quite literally install a used Subaru OEM before an aftermarket. If you get a Subaru one too it's probably easier to ensure alignment is the same by counting turns...assuming the parts are the same/equivalents. I've replaced subaru inner tie rods without removing the outer tie rod. Loosen the lock nut, turn the inner tie rod out so it comes out of the outer tie rod (thereby skipping the need to remove it). Remove boot. Use inner tie rod tool to swap tie rods. Literally don't have to remover any bolts or nuts - just the boot and tie rod itself. Count the number of turns of the tie rod and install the new one to the same depth.
  2. You weren't satisfied with it by your last two posts - what was the final fix here?
  3. I'd do exactly what you said - the fluid filter, ATF hoses, and do a visual inspection on the side and rear seals. Why was it in the yard, could you tell?
  4. 2002 and 2003 is when the rear transfer clutch solenoid wiring was reversed. I’m a little uncertain on that but that might be a good idea to check #4 - they can have “pending” codes, which don’t trigger the CEL. have to read the codes to see them. good to hear it doesn’t. Ive unplugged the shift resistor to firm up lagging slow shifting on 80s and early 90s 4EATs that were known to have slow/lagging shifting from 3-4. It was minor but enough that some people liked to tinker snd do that. There was nothing wrong with them, they were just like that. We just would disconnect the shift resistor entirely (just unplug it) and the shifts are much more crisp/sharp/fast. Could unplug it and drive but maybe it would have adverse affects on newer subarus. FSM may give a simple test you can do.
  5. All non diesel turbo engines are unreliable when compared to non turbo, so it depends what you mean by “reliable”. They’re unforgiving of heat, non synthetic oil, extended oil changes. Even a minor oversight means needing a new block (which are in high demand) By now a 2005 has a long unknown history. If they’ve got a known documented history of maintenance, never been run hot, synthetic oil changed very frequently, and taken care of, and it’s never eaten a turbo or turbo replaced with a cheap aftermarket garbage….they can a decent vehicle. Practically that almost never happens. So yes they’re reliable but no you probably won’t find one in the condition I described. It also needs Subaru timing belt pulleys tensioner and water pump no matter what it’s timing belt history. It’s probably old or has aftermarket parts or the pulleys and tensioner have never been replaced. “New timing belt” isn’t good enough. Has to be Subaru or AISIn and all new pulleys too.
  6. It has the same problem with a new transmission (with original MPT)? It seems like it has to be: a. TCU b. MPT c. Final drive ratio mismatch (I doubt this is it but I don’t like assuming too much from your diagnosis and my interpretation of types descriptions) d. Shift resistor (I’ve never seen one fail or cause those symptoms but it completes the list of *things a proper trans needs to shift properly*) lukcily those are all rather simple to diagnose or swap with a cheap used one 1. Youre positive it’s got the right final drive ratio matching trans and rear diff? 2. why does it have so low miles? 3. I’d swap the TCU. It’s easy and they almost never fail so they’re cheap 4. Scan check engine codes. What do you get? 5. Are there any trans or other lights illuminated on the dash? Unplug the shift resistor - what happens when driving now? Get a used one and swap it in What happens if you manually shift from 1st to 2nd to 3rd to D as needed rather than have it in drive? If you’re in D and manually shift to 3rd before pressing the gas pedal what’s happens?
  7. With relays removed is it 14.0 or 14.5 or…? Test voltage with only one of those two relays installed at a time. Does voltage do same thing or different? The relay test suggests potential JDM light issues - wiring or otherwise. “Began dropping” - give us some numbers and time frame to understand what’s going on. How low does it go? When it’s dripping what happens if you increase RPMs? The alternator isn’t outputting much at idle
  8. The new pigtail was wired in backwards by a previous shop. Compared it to the other side and the wires were opposite. The assemblies were faded and his uncle attempted to freshen them up before, so he decided to get new headlight assemblies which I installed last week. Thanks all!
  9. You’ve checked all bulb sockets and pigtails related to headlights? Make sure no rear or front headlight, low beam, high beam, taillight are corroded or bad? disconnect each headlight and tail light one at a time and see if any impact voltage differently. If there’s more than one per assembly - disconnect each wiring plug in the headlight assembly independently and the entire tailgate if there’s easy access (some are easier than others). Im not familiar with JDM but if any custom wiring was done that’s the first place to start. I worked on a friends problematic headlights last week. Turns out previous shop reversed the wiring to a replacement bulb connector. Still worked but not correctly.
  10. He nailed it on all points - I'd avoid EJ25D's and 259's, the way the EJ25D headgaskets fail are prone to prior historical multiple overheating events missed by owers and mechanics alike. The later 00+ (and 99 Forester/Imp) 2.5's are much more forgiving.
  11. Agreed. $300-$1,000 engine + $500-$1,500 for parts and install and the total cost of $800-$2,500 can easily be less than a headgasket replacement on a questionable DOHC EJ25.
  12. Approx $2,500 for dealer to do a 2.5 head gaskets in the vehicle. It can vary. Resurfacing (some dealers do, many don’t), timing components, valve covers, etc. and regional rates demand and staffing vary too. Call and ask they might give you a quote for an “average” headgasket job. That’s a fairly standard job locally speaking and some will give an estimate over the phone A cheap 98 legacy needing headgaskets can be questionable. If it was overheated bad enough the engine isn’t worth repairing. I’d walk cautiously around blown headgaskets EJ25s now - they’re old, not worth much and more prone to people limping them along and further compromising the lower end bearings.
  13. Cheers for it being a bearing!! I’ve encountered a couple with no diagnosable symptom. It would make noise while driving straight (under load/higher rpms I guess). That’s it. No play. No change when turning while driving. No feel when turned by hand. No noise with stethoscope. No temp change after driving. Even more odd - they were lumpy feeling when rotated once removed from the vehicle.
  14. Correct. Fronts are more exposed to heat and temp/cycling, road debris, additional functionality of steering components and exposure rates (axles removed, boots or replacement), and heavier (front heavier than rear and car nose dives in quick brake application). It’s just an all around busier higher stress area. When you say “serviceable” do you mean grease them like the 70s or replace just the bearing like the 90s? If you mean “like the 90s”, for Subaru I’d guess it’s simply due to the increasing complications of labor, special tools, and hub failures to replace them. Hub Tamer tools, rusted in parts pressing complications, deformed hubs requiring multiple bearing replacements. And they need great seals Ideally everyone is cleaning or repalcing their wheel seals with every axle removal - boots, replace, etc. That’s a lot of effort and hard to make consistently accomplished. Given the parts costs, labor, rust, presses, special tools, wheel seal replacement issues and damaged hubs - the cost isn’t really extravagantly different. There are more bearing failures now than in the 90s. Its not just Subaru either. Honda and Toyota’s have their weaker bearings as well. It’s an industry wide shift. My curiosity is why a 5 year old 1992 legacy bearing was far less likely to fail than a 5 year old Subaru (or Honda or Toyota) bearing today. It seems that current bearings should be capable of similar reliability but for some reason they’re not. OEM bearings don’t strand a vehicle and give ample warning and for new car consumers aren’t a detriment to purchase. Why do newer bearings have higher ratws of failure? Is it increasing vehicle weight? I doubt it…but I can’t think of any other significant changes. Id guess they’re assuming the trade offs of earlier issues and new ones is tolerable to consumers. If you mean “greasable” 70s bearings - As usual there’s a pros and cons list. Keep them greased, sealed and from overheating and bearings are likely to last the life of the vehicle. Theoretically sealed is great. But it isn’t practical for modern consumers and 200,000 mile vehicles seeing numerous axles changes, mud, snow, rust, salt, etc. there’s no shortage of equipment, trailer, tractor, boat and other serviceable bearing issues. A rusty nippple is likely in the northeast and annoying if it breaks off or clogs. My friend that daily drives 1970s cars is playing with bearings every 30k. Thats cool he loves it. I’ll pass on that but gladly spend my time worrying about tire circumference LOLOL 1970s Serviceable isn’t scalable to the masses of consumers less familiar with mechanics and maintenance.
  15. 96-03 4 cylinders are all very similar. I wouldn’t favor any of those years if I was going to put a 2.2 in it. im a little confused about your question though. What is your plan? You can’t just drop the same 2.2 in a 96 and 2003. 96-98 (and 99 OB or legacy) are phase I and 00-03 (and 99 For or Imp) are Phase II. As far as the systems other than the engines: major systems like brakes and power steering are essentially the same with minor tweaks and no issues. Front struts are interchangeable between them all. 00-03 have significant rear suspension changes. 99-2001 EJ22s (found in 99 legacies and 99-01 Imprezas) are not as robust as 96-98 EJ22s - they’re more prone to oil leaks/headgaskets than their 96-98 beast older cousin EJ22s. some 01-03s have H6s which can’t be swapped into 4 cylinder vehicles without full wiring ECU conversion. 99 and sometimes 98 or 2000 automatic have delayed engagement into drive. When first starting in the morning Shift from reverse to drive and wait 3-10 seconds to go. test drive them from cold start and see. If it happens (and wasn’t ignored for 5 years) it’s treatable for less than $10. I wouldn’t avoid 99ish automatics I’d just make sure it doesn’t currently delay for 10 or more seconds from cold (meaning it was ignored for years).
  16. What’s your issue with the other thread you asked the same question? Is your only option to have an engine shipped? search car-part.com with the various engines and models listed below. don’t search online - call the JDM suppliers and ask. These older engines aren’t seen for sale much any more. That doesn’t mean they don’t exist but you might find jt hard to find one. Check eBay too if you haven’t. In US terms a 1995-1998 EJ22 or a 1996-1998 EJ25 can be plug and play compatible. search for all of those or a 1999 legacy/outback 2.5 (but not a 99 Forster or Imp 2.5 - different electronics and incompatible) search for those Get a 00-04 2.5 block and bolt your heads and intake to it. Search for those engines close to you If you can cross the border PM me an offer and buy a 125k miles (200 km) 98 EJ25 with new headgaskets expand your search options. search local classifieds that sell used car parts You posted this once already you should probably clarify what in that thread didn’t help or work or make sense because I think I just repeated a bunch of things Keep in mind “best” is subjective and there are so many options and variables dependent on your skill set, your mechanics skill set snd price tag and your limited parts availability that ambiguous questions are hard to answer. And add to that any potential Canadian year model engine differences
  17. this is amazing! Well done team usmb!
  18. Why can’t you find it? Rockauto. Advance. napa. call and ask or stop in if you can’t find it on their website. Toyota dealer might even help first Google search via eBay I found one in 8 seconds: https://www.ebay.com/itm/224636839208?_trkparms=ispr%3D1&hash=item344d662528%3Ag%3AGZgAAOSw4DJhaoQ1&amdata=enc%3AAQAGAAACoPYe5NmHp%2B2JMhMi7yxGiTJkPrKr5t53CooMSQt2orsSK%2B2M%2Ffp5X4rboLTBP5niNTEQCmnCP236JOOtmLXZzcoM7eN3AUNEkBHOz%2FPz71RKlvUnF9FRqxZnCDpOprgMnPMoaUbGqp4g7Wp2EsST5OlKaAzDEaQqetG%2FTxqgK8gyI4zJA5vePKOFsRX5YcsJ91pqxAdExiojNKww0ALH%2BUB%2BPd2v4S%2F2zEjb21NIA1aRaNcYmjNHgnnN67ubE4%2FSMSVYIu5%2FQvN0oBBRBjBrsj5MC9mlyx3ar5l5aUvtll%2F1LnLzaX7RDM9t1AKa9vGcRH%2BsE2sDq9Zu7eI25kRFP73gXloMacUatZKuF4u4qrbO7B5%2BVkfNpZBlRKcQTFH1HQMCVabxmbS8LeEPbzxRerKCKc6BE%2FVIZJOd8jthuevVT4MgzHD7pg8Sn2RUqY2nt1qyW0qYqPpDtZAYZij76aHm%2FYH5FLdi0PmfJa0PE%2FAT9OXfAAhIyHzN1QymgmEIP37KPylo%2Blghhg4b7a9MgpIpFHHQvvvYCMSW0j6SocDUfvE08pk6My4ntEkX27fesR3JLYB45X4SISlhmIq2CcgKVml9pK98D2aXmi71jyRnaAKroqRCJxwjyFTt%2Bdy6%2FggkIsZJaINkJ1iDQzTwm9iE34ERUzPQXlnKssbUZMDacFg%2B8QE%2FgmJhEOOsK8BjYyfnPBhhqraD6hGEv%2F%2ByvYaf3SH9Ab6Bs9pvyGLqseOtG9GLxeZLky1MtqIyTG13yqqQ2pkFuRO5LgDYIc6snSu1Yi3W8axwqh89Lw9dba8oyHBfsj5EOEMFWReonX98t4Qb5zuNSP5amtjaNox8nHphFNX3RJosyW%2BuxrjlDV2aaaMLrPuMrJJD1Q8amslKww%3D%3D|clp%3A2499334|tkp%3ABFBMsMfQ6atf&fits=Year%3A1993|Model%3A4Runner|Make%3AToyota
  19. ***Youre asking in a thread by what I think is a Canadian member. So the original poster should clarify comments made about years/compatibility. For US market - 99 is phase II. It can be done but there’s a lot of issues to work around. If you’re asking about price for someone else to do it I doubt it’s a good fit. Have to swap entire 98 intake manifold wiring harness onto the 99 and still work around additional issues. The idle control being different with no easy work around being one. The “easy way” to use that engine would be to bolt thr 98 heads to the 99 block - that’s just a standard block swap pretty much. Remove 1998 and do a headgasket job but use the 99 block instead of the 98. Then the intake and working all stays the same - bolt 98 instake to the 98 heads installed on the 99 block. That’s essentially a headgaskets job with A little extra disassembly for the 99. $2,500 plus or minus 500 If you want the entire 1999 engine in the 98 - since that would be such a custom job price would vary depending how one did it and who you found to do it. If by inspection in MD you mean Maryland State safety inspections - they only inspect upon purchase unless it changed recently? You can swap away and it never matters until the car is sold/changes owner. But you’ll need check engine light out and to pass emissions in most (or all?) areas of Maryland.
  20. Are you in Canada? EJ22 or EJ25 engine? Why is the JDM throwing red flags? You could buy a newer EJ25 block and bolt your EJ22 heads to it. Have a machine shop rebuild your heads or try to buy some lower mileage EJ22 heads. Subaru even sells new EJ25 motors for $2k. I’m not sure the oldest generation they have but if 00-04 are available tjose would work. Doubt they’d honor the warranty in that application though ! Easiest is an EJ22. In the US any 90-98 EJ22 could be installed in your vehicle. 1996-1998 would be easiest. 90-95 requires: dual port exhaust manifold and bolt your 98 intake manifold onto the 90-95. Then it’ll install. There are EGR differences too but they can be worked around and often it’s a non issue. EJ25s have a lot of headgasket issues so after a quarter century it’s difficult to know what you’re getting. I have a good block to sell but distance and logistics no way. Post what you want in parts wanted maybe someone wants some
  21. Any subaru you’re looking at can “pull codes”. 95/96 and newer are compatible with generic OBDII scanners and connectors found in stores and eBay for cheap. 80s and early 90s requires no tool or scanner. Connect two connectors in the vehicle and the light on the dash flashes the code to you.
  22. That’s a power related issue: A: corroded, dirty, or loose terminals. Clean them up good. Check voltage of battery *posts* and voltage at the end of the metal terminal furthest from the battery. Make sure power is getting from the battery through the cable terminal B. Alternator - check output at alt terminal C. Alt belt slipping (alt isn’t spinning fast enough) D. Crank pulley separating (alternator won’t spin fast enough). Draw a line across the face of the crank pulkey and make sure it doesn’t separate after driving. Don’t condemn the battery or alternator until those other items are tested or ruled out.
  23. You should state MT or AT. You have to pull the trans out and remove the front diff to replace the bearings. The AT has side retaining rings and externally replaced seals, the MT does not. For preload - If you *locate* and tighten everything back to where it was you can get away without setting preload. Review the FSM procedure for bearing or front diff replacement. Mark the side retainers and count number of turns and the preload will theoretically be exactly what it was before you worked on it. A guy on here did just that - swapped front diffs and installed everything the same (counted number of turns of side retainers) and it worked fine. Did you price a new bearing yet? One of those front diff bearings is $100+ each. Replace the side seals while it’s apart - they’re directional so different part number each side. Definitely replace the seals if it’s an MT since they’re only accessible internally. AT can be done externally do they can be skipped snd replaced as needed.
  24. It’s always the carb. My friend just bought a chainsaw with fuel injection. Dinosaur tech. Clean it. Adjust it. Look/spray for vacuum leaks and check vacuum hoses. Carb is low fuel pressure. So probably not fuel if you’re getting any. Pull fuel line and crank engine. If it flows out you’re good. Spray starting fluid into intake - does it start?
