idosubaru
344
same intake manifold through all the issues? those are easy enough to swap might be worth a shot. i've seen 88-91 XT6's have wiring warn through and the metal is exposed or a wire is infiltrated with green corrosion and both can create wildly erratic symptoms. fixed one last week - green corrosion at least a foot up the wiring loom past the connector. 1 or 2 times out of 10 they won't show a check engine light for some reason. the one i fixed last week never had a check engine light but was nearly undrivable. the green corrosion the car would drive fine, then not...drive, buck, stumble...then take off like a rocket...and somehow even when it was nearly undrivable, couldn't pull an incline it would have no check engine light. that's actually fairly common on XT6's for one wire in particular, i've seen it multiple times so I was able to work around it fairly quick and get my friends car home. I have never seen it in a newer gen car but they're aging to the point where it might be possible?
Rear output shaft seal has a very slow drip leak, been that way for years, about time to replace it. 2002 OBW H6 VDC. Any Subaru will probably be in the same ballpark. I'll jack the rear of the vehicle up so more fluid will stay in that way too. A quart? A bunch of quarts? Been awhile since I've done it and I usually had the nose way up so more comes out.
I've heard of folks hitting the water jacket as well trying to drill those out. Just tap into the exhaust pipe and plumb it up to the intake. It's actually really simple just a matter of figuring out what kind of pipe fitting and pipe you can learn how to work with really quick. Just run a pipe and attach it. It's not structural or high pressure so as long as you get it to seal you're golden.
I have always bled every ABS equipped subaru just like an older non-ABS subaru and have had no issues. I wouldn't think it's bleeding unless it needs bled because of some problem. There is a valve somewhere in the vacuum line I think - maybe that is wonky? They freeze on some folks every winter and cause issues...I forget what. Subaru master cylinder failure is very rare..... On other cars folks would say one of your flexible brake lines at the wheel is failing and "expanding" internally - ballooning. Expands to a point then firms up....repeat when it contracts. They can also collapse. I've replace those hoses on other makes but never seen or heard of one failing on a Subaru. It would be one of the 4 flexible brake line hoses at each knuckle assembly. I have seen rockauto have some crazy cheap brake hoses before....just cross reference the part number and make sure it's the right one.
My 2002 H6 OBW daily driver. The rear O2 sensor is welded to the bung, nice size bead. I tried removing it but no budging. Cut/grind the weld off? If I cut midway through the bead or a bit lower I'll have to cut below the hex part on the O2 sensor and then can't remove the sensor (easily). And the threads will probably be mangled and unusable...except that's the same threads as a spark plug so I can use a spark plug thread chaser to clean those up. That's probably the best option. I could add another bung somewhere maybe. That sounds difficult unless I just have an exhaust shop do it. They might not even weld into the catalytic converter though?
95 legacy should be a 4.11 final drive ratio. There are 3 available final drive ratios for automatics - 3.9, 4.11, and 4.44, you have to match that. Some early years, imprezas, or legacy turbo's have 3.9. EJ25 vehicles (Outbacks, LSi's, GT's, Forester, and Impreza RS) come with 4.44 final drive. Those will both bolt up and work just fine but you would need to swap the rear differential to work as well. If you do that - then you can use any Subaru automatic transmission. In 1998 the bellhousing bolt pattern changes but you can still interchange, just use the 4 bolt holes that line up. They also added a spin on external ATF filter, no big deal, just change it.
oil on the cam sprockets doesn't matter. oil on the timing belt at all is very bad. i've seen oil/coolant leaks onto new timing belts cause failures in a matter of months, it degrades the material. if you're doing the timing belt the $100 - $200 ebay timing kits with all new pulley is the way to go. the 15 year old pulley bearings are devoid of grease by now.
I have a 1999 LS or LSi wagon that's really nice and has the EJ22. Might want to see if you can find any of those if he wants a wagon? i guess it's an automatic? if it's a manual it's the only Outback ever offered with the EJ22 - 1996 MT OBW's. that is a fine price,sounds really nice for one with zero rust. that would be a really good price for a well maintained, great condition one in the Subaru rich northeast or out west. it is random, any number given is only an average containing all possible mileages so it's anecdotal and meaningless for purchasing. there is no mileage "where it tends to happen". there's more statistical analysis and comments but suffice it to say you'll see numbers tossed around - "120,000 miles" and what that means is that's the mileage most of them, in good shape, worth fixing, tend to have right now. it's not really indicative of when a headgasket will actually fail. not all. i don't know of a quantitative number. someone who has owned a Dodge neon would guess 25%, someone who has owned a 1995 EJ22 would guess 95%. LOL In general, what vehicle is more likely to end up on the used market?: 1. A perfectly running vehicle with no issues 2. One with ominous signs of looming issues Every week EJ25's are hitting the used market with the first signs of headgasket issues. Common thread starter on Subaru boards: "I got this Subaru because I thought they were reliable and a week later it's overheating"...there's one on subaruoutback.org right now and that's failure regular. First step is to make sure you're not getting that high percentage of used market that's hitting the market due to this issue. I have relied on the newer gasket but my limited experience falls wwwaaayyyy short of the millions of older gaskets that have been around for over a decade. to put an EJ18 or EJ22 in it. they're good though, just personal preference, try it out and see what happens. it's just a car and just a gasket.? my hang up for the EJ25D is the complete random nature of the overheating episodes. this detracts from ownership in two significant ways for me: 1. reliability. don't want to (or my wife) to get stranded. when the EJ25D starts to overheat it is random and can not be mitigated. in the past few years i have driven to colorado, maine, new orleans 3 times, florida, missouri, south georgia...almost ten 2,000+ mile road trips, and shorter distances often, so I'm a bit picky. No engine break downs and those Soobs all had 150k+ or more. 2. lower end issues. they occasionally loose rod bearings and i have always assumed it was due to prior overheating, the random nature and not being able to drive without it overheating lends itself to folks trying to "limp it home" since nothing else will work. some with blown motors i have gotten have already had the headgaskets replaced prior...not a huge sample size and could mean other things...but either way it's a concern. ideally you get an EJ25 that has never had headgaskets replaced, then you have a strong case for suggesting the block has never been compromised. I have done the following. Pull the perfectly good EJ25 in it now....then buy an EJ22 and install it. you can probably pay the mechanic and make money on the deal...and end up with a better motor. A friend bought a 98 outback, EJ25D, last year...this summer the headgasket blew, he had it less than a year. The motor is sitting in my office right now. i picked up an EJ22 for $300 (there were cheaper ones, i went low mileage) and installed new timing gear, seals, etc and gave it to him. by the time i sell the EJ25 he won't be that far in and might even break even.
Not that I'm aware of. He's had it 30,000 miles and had the headgasket replaced, that's it. no, that is what i was leaning on and normally I would replace but for them it's not a good fit to throw part$ at it, be nice to diagnose and with such specific symptoms I thought that might be pointing to something. For instance the fuel issue naru mentioned... But - I have never checked plugs/wires before, didn't really know visible signs were common enough to make it worth looking for, good to know, thanks russ. maybe plugs/wires will be my christmas present to them. LOL
great, thanks naru.1. where/how do you put a fuel pressure gauge on an EJ engine? I've never had to use my pressure gauge on a Subaru yet. 2. replace the injector or reseal it with new oring/seal? Check engine light only "flashes non-stop" during multiple cylinder misfires so can't be just one. when it does it - it's after a few days of sitting - and always results in a flashing CEL - every single time - never a constant "normal" check engine light. seems like those symptoms point to something specific, hopefully naru has it covered and i figure out how to use my fuel pressure gauge on a Subaru.
Friend has a 2002 Subaru legacy sedan EJ25, 135,000 miles. ***Only when the car sits for more than a day. He said it never happens if the car is driven daily. Misfires, apparently quite bad, car is jumpy, won't shift right and the check engine light blinks and then once the car is warmed up it goes away and runs fine. That's how I surmise misfire. It has only stayed lit consistently once, usually it's always flashing or off. In some ways I think plugs and wires in others I think it too coincidental that it's always (except once) multiples. Coil pack? I always have in my mind that fuel pump cap oring issue bleeding off pressure when the car sits but that also seems far fetched.
right on, hopefully you get that old style fixed and can just keep that. They are about $100 from online Subaru dealers. Dealers can match that price if you ask and they want to. $109.76 from here: https://www.subarugenuineparts.com/oe_parts_cat.html $85 on ebay, free shipping, in California: http://www.ebay.com/itm/97-08-Subaru-Hydraulic-Tensioner-NTN-JAPAN-13033-AA040-EJ20T-EJ22-EJ25-EJ25T-/261098819843
you my friend are the man - you used an o-scope - wow! have you swapped the coolant temperature sensor used by the ECU? what sensors have you not replaced? Have you considered doing the following two steps: 1. swap an entire intake manifold 2. get another body side wiring harness and stuff it around a strut tower for a test? buy one stripped and ready or get your own. you can likely resell it for swap material. that would nearly rule everything out.
Whats the biggest engine that could be fitted into a EA/EJ body?
idosubaru replied to torxxx's topic in Subaru Transplants
i agree, i'll tame the repeats....and yet same reply for the same general question, how big, how much, how fast, etc. like you, he's quite talented and well versed so his possibilities are broad. there were also some questions, trying to see how far he's wanting to go with it. -
awesome - yes that is it, just a simple bracket. the lower left larger hole is the one for the tensioner idler pulley and it's associated 14mm bolt. if the bolt isn't close to the surface where you can cut a slot in it for a screw driver then it's going to be annoying to remove without experience or good tools. take it to any shop or mechanic even - i bet even a basic oil change place will be able to get it out. if you have a drill and drill bits - drill it FROM THE BACK SIDE. use a bit a little smaller than the diameter of the hole so you don't hit the threads. a right handed drill bit from the back end will essentially be grabbing/twisting and pushing it to "unthread" from the other way - the way it normally threads in and may very well back out. put some oil/grease on the threads it would walk out on to help it along the way. once you get somewhat of a hole drilled or started, if it hasn't moved, let it cool down and you may be able to jab a tool/driver/chisel in there and use that to turn it out. probably again easiest from the back side (engine side) and "tighten" it or turn it clockwise so it backs out the way it was originally installed. i've done tons of EJ stuff and i don't ever recall a difference in those brackets, i wouldn't worry about it, if you get one it'll work. remove the tab if you have to it's benign and not necessary.
i had similar symptoms on my daily driver 1997 OBS 4EAT years ago. could not make it up steep inclines either. light throttle it was fine, i could get to and front work except for one particularly steep switchback incline was really annoying to get up, like almost impossible limping it along. i chased and swapped a few things. i read online that it could be EGR related. i replaced the valve and solenoid to no avail. i finally changed the small round filter inline with a vacuum hose that goes to the passengers side strut tower area - it's about the size of a quarter and costs a few bucks from Subaru. unbelievably (i'd be skeptical of this story myself, nor have i seen it since) the car drove like new. i'm not sure if it was the filter or a vacuum line i inadvertently "fixed" while replacing the filter and find it odd i've never seen anyone talk about it...i sold that car to a friend who is still driving it just fine many years later. i doubt that's your issue but it's at least easy enough to look into.
i've seen this before, with the new style tensioners, i'd like to know what causes it. anyway... you do know that, as folks have mentioned, the bracket comes off the engine and has the broken bolt inside of it? the bolt is broken in a bracket, not the block. any machine shop or even mechanics can get this out, this is a really easy fix. don't over think this, it looks awful to a first timer seeing broken bits in a block, but trust those of us that have done this before this is actually a really easy task. look up any machine shop or close mechanic and ask them. you can even just get another bracket.
