ej22 questions
knowing what year EJ22 would be helpful as there are differences. EJ22 - don't run it out of oil or overheat and the block is probably going to last as long as you care to maintain it. fantastic motors when properly taken care of with no real issues. replace the rear separator plate with a metal one. replace all the timing components - ebay kits are $80 - $200 with all new pulleys and tensioner and belt. like miles said, reseal the oil pump and tighten the backing plate screws. replace the cam seals, cam orings, and crank seal (part of the oil pump). basic, easy stuff that's generally apart of a timing belt job on older subarus just to keep the leaks down which it sounds like this thing had. adjust the valves if it has adjustable valves. they do best with the stock NGK plugs and Subaru ignition wires but that's easy stuff.
92 outback tranny problem
idosubaru replied to mwbean's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXis the car drivable? sometimes they just have a poor shift point, other times they are nearly undrivable. just drive it if it's operating fine. if the transmission is bad, replacing the trans with a used one isn't that bad of a choice. they don't fail that often so used is a good option and they're usually reasonably priced because demand is low. http://www.car-parts.com your area looks expensive, $450 cheapest. i can get one for $200. with the prevalence of subarus in your area you can probably find one on the board here or locally for sale. post in the parts wanted section of this forum.
No EGR - pass emitions
i have a non-EGR ECU, engine, and intake manifold installed in my legacy and still get the codes. seems convoluted that the issue lies in the body side wiring harness, but that's all that's left on mine? get an intake manifold with EGR and have the EGR pipe tapped into the exhaust. that would be the easiest/cheapest solution.
Flex plate bolts hard to drill?
idosubaru replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi do that, but i asked earlier in this thread with no response yet - would a welded on nut hold this much force? it seems like it should theoretically work but i feel like it would break (i had a 2.5 foot pipe on the socket and it wouldn't budge - it was really tight). my sloppy cheap, wire feed mig welder might not be up to the task? the slag doesn't lend itself to filling in a nice puddle in the nut. i could practice next time.
ea82 cam seal holder oring ?
+1 on both points - the cam seal sets have the seal and oring and they're just standard orings, the V shape is due to usage.
idosubaru replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthat's exactly what i did, i got it off no problem. but - i'd like to get left handed drill bits capable of doing this quicker. grinding isn't the fastest thing in the world and being in the rust i see this kind of stuff sometimes (though never on flex plate bolts?). seems like there has to be good bits that can drill them? i've seen those CNC machines in engineering facilities that can drill anything and immense quantities...aren't there bits out there that will tackle this?
idosubaru replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthat's just the thing i asked and looked online and went with Cobalt bits and they wouldn't touch it either. all properly oiled and everything.
Searching for help on interchange
idosubaru replied to TRAVIS75's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhy are they going through so many engines? headgaskets? broken timing belts? running low on oil? overheating? if the headgaskets are failing - have it properly repaired. if it's valve damage also have it properly repaired.
Fuel Pump or Relay??
check fuel pressure. before i had a fuel pressure gauge i would pull the fuel line in the engine bay and crank the car. if the pump is dead then sometimes it's really obvious if you don't have a fuel pressure gauge to work with. a gauge would be nice though, quickly verify if that's the issue. of course you always have the possibility that it's flowing but not enough...if that's possible with a carb?
Oh Great! New style HG problems!
idosubaru replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXawesome, hopefully that gasket or the turbo can work on previous generations.
'91 Loyale - EA82 - Nasty Oil leak.
don't do this: that can burn time and frustrate you. do this: is it wet under the valve cover gaskets or grommets? if there's oil there then that is likely the culprit. start looking from the passengers side of the engine underneath. where is it first wet with oil as you start from the outside passengers edge of the motor (valve covers) and work your way in towards the center of the motor? the valve cover gaskets are easy. have a 10mm ratcheting wrench handy. makes the job take 20 minutes instead of an hour. it's rather simple though - just remove like one hose and 6 10mm bolts, that's it. the grommets will be in terrible condition, good to replace those while the cover is off. Fel Pro kits sometimes include the gasket and grommets. the grommets are really expensive from Subaru (for what they are, not like they actually cost much).
rear main seal leak 97 ouback
idosubaru replied to koybern's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXfrom previous attempts do you know for sure it's leaking at the ID or is it the OD? probably ID around the shaft? might want to measure or gauge the crank for wear and make the sleeve decision based on that? i have never used a sleeve but i've seen other folks on the boards do it. i've seen variances in size of the same brand and seal - Fel Pro EA82 crankshaft seal is one. I've used tons of them in the past but had one that would not seat normally as if the OD was too large. i took my time and eventually got it to seat and wedged in there - notably tighter than normal. as you can guess, it ended up leaking. next seal went in just fine. i've used Fel Pro's numerous times in the past without issue though? since then i've used almost exclusively Subaru seals, though i've used Fel Pro's on occasion and still have some in my garage. one bad seal? quality control?
idosubaru replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcrank shaft bolts, not the torque converter bolts. the TC bolts are easy to drill, because we had to drill one of those too on the same engine. oddly enough my buddy drilled it out using a right handed bit with the drill set on left hand, which i didn't know was possible. a couple bolts were inordinately tight and the engine had been replaced before - i suppose the previous install was to blame as i've never had trouble with any of those bolts before, they're never rusty or corroded. maybe that's also why the "new" engine went kaboom!? i doubt i'll use an EZ out again, i'm not sure what word to use to describe the task at hand when one of those shear off, which they easily do. a 2 and a half foot pipe on my socket wasn't moving it and a 900 ft/lb impact rounded it off, i think it rounded off because it was inordinately tight. *** given that it had that much force on it - would a welded nut hold? i've done that before but couldn't picture it holding that kind of force. theoretically it should hold if a good weld but practically i don't know that it would. my sloppy mig wire feed might not be up to that task?
rounded off flex plate bolt, needed to drill it out. none of my bits would touch it to drill it out. i ordered some expensive cobalt bits as recommended by a machinist....they wouldn't much touch it either - had it soaking in oil to keep it cool and cutting. ended up needing to grind it off with my grinder. why are these things so hard to drill? what kind of bits do i buy that can eat through those things next time?
idosubaru replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXawesome, sounds like it's not too bad? clean it up once a year? there's mention on subaruoutback.org of a headgasket change in 2010 or 2011, the thread was fairly informative and i would find it again if i were currently diving into this question (and maybe now if i wasn't on dial up ). this issue has gone through some revisions over the years (or decades ) and you see where we still are. i've seen a few 08's and an 09, so if there was a change in 07 it seems like it is not a total relief. what is odd is that the turbo motors don't have HG issues, weird considering they have more heat and stress? next time i do a newer engine i might look into the efficacy of using a 2.5 turbo headgasket on a non-turbo block? unless it's head differences causing the issue? that's news to me and i've never seen it. i wouldn't expect cat issues from externally seeping headgaskets? maybe folks abusing a car that's overheating due to HG failure...thereby leading to overheating that causes other issues that damage the cat? but just from the HG leaking sounds suspect to me. that's no good. fooey!!!!
Power Steering delete?
what they said - this is too easy to try to work around. simplest solution is to just get a used pump, should only run $20-$40. car-parts.com will give you the cheapest listed one in the country - probably $10 plus shipping unless you're lucky to find one close. there is also an oring under the reservoir that often leaks and is really easy to fix, don't even have to remove the pump - just the reservoir via a two bolts or something - remove it and replace the 50 cent oring. that fixes a lot of them. the complete rebuild kits aren't that expensive either to reseal the rear and front of the pump - that's the 100% solution that will last the life of the car. i would add fluid first and make sure the pump isn't currently shot though from being run too low for too long on fluid. but the reseal kits are a little extra work too. but all in all this is a common issue with lots of information online and an easy fix. subaru power steering pumps rarely fail - they leak - but rarely fail and when they do they're easy to replace.
What if FWD fuse fixes torque bind
idosubaru replied to NOMAD327's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdescribe "change"? was it just drained once, multiple times, or flushed? draining the fluid once only gets about 33% of the fluid out. if that doesn't work then the clutches are shot and there are grooves that likely need to be checked/filed down.
Stock radios with auxiliary inputs?
idosubaru replied to mellow65's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi've used this to add an AUX line to an existing radio: http://www.ebay.com/itm/STEREO-RADIO-RCA-AUX-INPUT-ADAPTER-WIRED-FM-MODULATOR-/390320627678?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3ASubaru&vxp=mtr&hash=item5ae0ec1fde others have tapped into existing Subaru radios and soldered in their own AUX in - i've seen threads about it. i dislike electrical work so i avoid it although i have a drooling ambition for AUX in as well. http://hackaday.com/2011/05/18/aux-in-hacking-an-04-subaru-radio/ there are aftermarket devices that are plug and play and thus could be portable if your stereo ever fails: http://www.jazzyengineering.com/product_info.php?products_id=45&osCsid=b4bp6rod3mnjue7go1h9brv4r1 apparently there's a guy adding AUX inputs and selling them on ebay: http://www.ebay.com/itm/99-Legacy-SUBARU-CD-Tape-Radio-WB-Mp3-Ipod-Aux-SAT-external-input-86201-AC430-/190591701541?pt=Car_Audio_Video&vxp=mtr&hash=item2c60269225
forester tire got slashed!
idosubaru replied to crockettbrat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwith 5,000 miles it's not going to matter. i would just get a new tire and be done with it. the sure thing to do is measure them and check tread depth and see any difference. the rears should wear less if they haven't been rotated yet - so if one of the rears got slashed the new one would probably be more likely to match that tread depth than the fronts. but either way, 5,000 is nothing. bordertire.com was an awesome used tire distributor online i bought tires from but i believe they were going out of business last i checked. tires with 50% tread and such are much easier to find though when going used. 99% tread tires are not the most common used tires. a new tire is probably just as close or closer than a used tire to the current 5,000 mile rubber on there (if that number is accurate). craigslist, ebay, local bulletin board style ads, etc there's lots of options to find used tires.
idosubaru replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXright - subaru's have headgasket issues, that's well known and those years are not a surprise to most, did you have a question? that particular comment is truth surrounded by inflammatory rhetoric, it's not necessary to replace them immediately (if you can stand dripping oil and pour oil into the engine) and oil/coolant mixing is rare.
Head bolts. Any thread sealer r locker
if you did everything properly and the heads/block were good it'll be fine. Quite a few of us have done countless headgaskets, GD comes to mind, and have never had a repeat failure that we know of.
EJ22 roller rockers on dual port heads?
idosubaru replied to cal_look_zero's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat he said. the 99+ EJ22 is the Phase II - much different than 98 and earlier stuff. the 99+ are hard to find so it's a good motor to snag if you can find one and have on hand. i'm swapping two 99 EJ22's right now. one lost a belt, bent valves, another ran out of oil.
EG33 into an xt6-quick question regarding cooling
you would want to try and stick with the XT6 radiator. if you can't then you have to retrofit - which means you need to make sure there's height and width clearance, the lower mounts probably won't be the same, and the fan mounting holes will be different. of course XT6 radiators aren't cheap so that's probably why you're asking? they are only available from Subaru.
Identifying a bad CV joint
noise in turns - outer CV joint noise/vibrations under load while moving forward - inner DOJ so what you're describing is classic DOJ symptoms. but of course it could be something else as well. temp guns help isolate bad wheel bearings. after driving, if one is notably hotter then it's bad. the inner DOJ's also "feel" inner sometimes, like you can tell it's not on the outside (bearing/outer CV) of the vehicle, but closer to the trans. if you have any sense about it being outer or inner that might help. if it turns out to be a CV - someone on the subaruxt.com forum (he's a member here too but rarely see him here), has taken both axles apart and swapped parts for an essentially free - or 'cost of boots' repair - i'm not sure which ones but there's a rotation of sorts since they tend to wear in a particular pattern - swapping parts gives them fresh surfaces to work with. the board is currently cracking out for me and not populating the webpage properly but not sure if it'll do that for you but here's his thread about it: http://www.subaruxt.com/forum/viewtopic.php?f=1&t=8956&start=0&st=0&sk=t&sd=a&hilit=wayne+ driveshaft ujoints do fail and tend to vibrate under load and are worse at certain speeds. sometimes you can simply grab the driveshaft and shake it and notice play. sometimes the joint is seized so it seems tight on the vehicle, but off it's obviously seized and doesn't have proper articulation. sometimes you acn visually see issues with the joint too - like it's offset improperly, clean shiney metal showing, etc. having a look and shaking the shaft might be worth a couple minutes.
EA82? use nothing, install the bolts clean and simply lubricated with a very small amount of oil on the threads. clean the bolts, clean the bolts threads, and ideally the hole threads if you can. run a bolt in and out of each hole as many times as you can tolerate to clean them out. if you're not using Fel Pro headgaskets don't forget EA82's require a retorque procedure on the headbolts.
