idosubaru
344
i wouldn't bother worrying about if the belt has been changed or not. at this point the pulleys are devoid of grease and can fail just as easily as the timing belt. i'd plan a complete timing pulley replacement with the belt. even if the belt was replaced it is unlikely they replaced the pulleys and tensioner. entire kits on ebay are only $160-$200 for belt, all the pulleys, and timing tensioner. do that and it's good until 250,000 miles for the next belt change. you can also remove the drivers side timing cover to inspect the belt, it's only held in place by three 10mm bolts. have the headgaskets been replaced?
places that auction or sell wrecked cars. craigslist works well but H6's aren't really seen often, though i just picked one up with a blown trans for cheap in excellent condition. i look almost every week and don't see them too often. ebay.
yes, use 2001+ 4 or 6 cylinder axles. avoid aftermarket axles like the plague. reboot yours or reboot a used axle. if you get a used Subaru axle, at least reboot in the inner DOJ, they typically only last a year, maybe two if you install a used axle. seen it many, many times and i just reboot them now. if you're not aware of the aftermarket axle issues, then just search any online subaru forum and read thread after thread of issues. vibrations, noises, and even completely blowing to pieces...waste of time.
i've tried turning off and on everything electrical - defrost, heated stuff, seats, etc and no change at all so far. it's very consistent, does the same exact thing every time, just like it has really weak reception. not even sure where the antenna is on these things, embedded in something? the glass? thanks, got lucky. it is very nice and i like the H6. was fortunate the original local owner sold it cheap with a blown trans in great condition.
new daily driver i just got on the road, 03 H6 sedan doesn't get radio reception at my house....but all my other subaru's always have. about half way to work it starts getting reception, though crackly. is this a stereo issue or........? it also cracks out on CD's sometimes, just seems to cut out. might need to try another CD to make sure that's not the problem.
really? i guess i get confused who is where! yeah - there's multiple swapped engine XT6's over there.
yeah just line it up carefully and it will stay. it's loaded by the valve train so it wants to spring out of position. once you get used to it, it's actually really easy. remove the passengers side lower timing belt idler pulley, it can be installed once the belt is in place easily and gives a little bit more play to install. get the belt around the crank and the drivers side pulley first and have a helper or use a clamp, clothes pin, or something to hold the belt onto the cam - that will prevent it from moving out of place as you go about installing it the rest of the way around everything else. once you get used to it, like i said, they go right on.
Shock fluid replacement for stiffer damping
idosubaru replied to presslab's topic in Old Gen.: 80's GL/DL/XT/Loyales...
did installation go like this: 1. install valve. 2. fill oil 3. compressed air or like this: 1. fill oil 2. install valve 3. compressed air you would recommend 10wt or 15wt oil depending on usage/climate then? i think i'd want a little stiffer too - 15wt if it could handle the winter temps here which is when i often drive the XT6. -
refilling air struts with new oil thread...
idosubaru replied to idosubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
great! that's it. i was searching for threads started by you and i didn't see that. thanks. since all 4WD XT6's came with air suspension we have a few air suspension threads on subaruxt.com. be a good idea to compile them all, with yours. we also have: 1. drier / dryer silica refilling http://subaruxt.com/forum/posting.php?mode=reply&f=1&t=12443 2. reconditioning the air struts 3. reconditioning the solenoids if you don't have rust maybe reconditioning air struts isn't an issue like it is out here. the strut body rusts and wears the bottom of the air bag where it attaches to the strut. -
in general that rules out every single possible swap. so you'll have to define "minor". everything will require adapter plates or trans swaps to go with it and most importantly - wiring. simple solution to that is to pay someone $200 to do it for you, there's a couple folks that do it, but you have to also buy and find a wiring harness which isn't super easy since it's buried behind the dash too. so again - you'll have to define "easy" nate - i think you've seen all the swaps on subaruxt.com - there's a couple EG33 swaps, EZ30 swaps, a bunch of EJ turbo swaps.....there's a tons of them right on the XT6 forum.
i like the cheap ones off ebay since i travel with them and take them places, in my work bag often, etc. if it breaks, no big deal, just buy another one. i've gotten them as cheap as $35 before. i'd buy nicer ones if i wasn't so mobile and rough on them. some ready the code only and don't tell you what it is. if that annoys you, you don't have a list of codes, will be working on multiple different kinds of vehicles, or don't have internet access - you might want the kinds that tell you what the codes are verses just the number. if you're just working on one or two vehicles, just print the lists of codes out and put them in the owners manual in the glove box and it doesnt' matter.
GD has a good point - the TCU's are very easy to swap and they very rarely fail so there's zero demand meaning they're not worth anything (they're cheap). it's a counter productive question because every thread ends up exactly the same way - tons of commentary and little, if any, real world experience. that doesn't help you. most people are going to say don't do it because something bad will happen. first they're wrong, because i've done it. second, who cares since it's already hosed!? it's a no brainer: 1. possibility of zero work and maybe needing to replace later. 2. replace now. #1 is a great fit sometimes and saves a bunch of time and money. no one has actually ever seen this cause a Duty C to fail, so that's rather good news. and i've driven a long time exactly like this, about 2 years, controlling the Duty C by a switch. if you're worried about it and dont' need 4WD - run it without the Duty C and remove the rear half of the driveshaft.
if it's leaking oil, does their 3 year warranty come into play?
i've never even done that, i just assume they're all relatively similar and visually appear that way. but that is really good advice, never thought of it. occassionally you'll have one that mangled a bit of thread, chasing it with a tap is a really good idea (regardless of whether or not you use new or old studs).
friend of mine is a mercedes mechanic, he recently had regional recognition and was selected for a free trip where they flew his family to germany this summer to view their plants, etc. he is now driving a very new...forget year/model i don't really follow cars at all, mercedes. he got it cheap because the AWD rear transfer components failed. he said this one has one rear transfer clutch plate in it and is really weak.
years ago i used to replace them...and now i just reuse them - the stud/nut combo's just turn into bolts, no big deal. some of the ones i replaced years ago then turned into bolts too! LOL i see no point in worrying about it anymore and i won't locktite anything in place because we have too much rust around here - would probably end up stripping threads once it's rusted and has to pull the stud out.
nice, a square for holding on the other ones! got a pipe wrench big enough to just fit on the entire flange? oh right, i wouldn't use the nut either. if you rig something up to hold it in place, it won't snap those driveshaft bolts. though you could just use different bolts and throw them away when you're done for the holding process in case you're worried about fatigue, stressing, etc, but it won't be an issue - they will hold. i would not hold one nut to counter against the pinion, but rather somehow bolt a piece of metal or wood or to a vice or something like that to hold it in place and use the bolt holes to hold it that way.
are you sure it's leaking and not just blow back from some other leak/fluid up front? i think you're on the right track. that does look like a beasty nut, though i've yet to need to remove one. i wouldn't think i'd have any problem trying some things to get it off. the flange has the 4 bolt holes in it too for the driveshaft i think, those could be used to hold it in place. a friend of mine uses his elec impact for cam pulley bolts which can be quite tight, might be worth a shot to put it on there for a minute and see what happens.
unless i'm missing the question the intake manifold should come off for a variety of reasons. *could* it be done without removing....yes. there really isn't much of a reason though. you're going to save 30 minutes of work but it could cost you 30 minutes...or an hour in other ways (like it already has on this post), and the likely hood of a lesser quality job. helpful to remove mostly for cleaning. the block mating surfaces need to be thoroughly cleaned for headgaskets, they aren't like normal gaskets and should be installed correctly every time - clean surfaces are a must for HG's. cleaning the block with the intake manifold in place is challenging and requires more effort than pulling the intake manifold off. you could clean from underneath if you enjoy that sort of thing... the heads to have to come out of the engine to clean them, though if you wanted to try this they could be dropped underneath. i've done it before...but it's hardly any extra work just to pull it off. it never saved me time because the manifold makes things harder to get to, harder to clean, less room, needs moved out of the way for something, and it's just hoses and throttle cables, very easy to remove. you can disconnect the minimum and prop it up out of the way or even flop it all the way back towards the windshield....but still all the same comments apply and simple to remove. but if you're the kind of person that likes the thought of it sounding and seeming quicker, then by all means roll with it! it's only a few minutes work, not a big deal either way.
