idosubaru
    344
  1. these are hydraulic valve lash adjuster equipped motors, no valve adjustment is necessary or even possible. usually start with some MMO added to the oil and frequent oil changes. dirty oil makes the HLA's (hydraulic valve lash adjusters) finnicky. that could quiet them immediately or could take along time. if it doesnt' work soon, reseal the oil pump. 10 dollars in seals/gasket and an oring. requires removing the timing belt (not that hard of a job, easy on the EA82 in my oppinion). 230,000, it probably is the original transmission and engine, that's fairly typical on these motors trans. i've had them over 200,000 and my current daily driver is at 150 or 160,000 and i'm figuring it'll last to 200+ no problems. that's the norm for the motors. oil leaks and valve noise are the issues, but the non-turbo motors tend to last quite a long time. you have to overheat, run it out of oil and generally abuse them for any significant internal failure.
  2. assuming nothing is wrong, the stub will slide back in. i would assume the bad cv axle worked the stub loose, that's no big deal. there is definitely no need to do a transmission swap, installing a stub takes about 8 seconds. i've pulled stubs out before, they are held in place by a circlip at the base on the trans side of the stub...i think. it's been awhile. post a picture of it if you can, that will jog my memory. if the circlip is still dangling from the stub, then just press it back in. might take some leverage or gentle tapping with a mallet to pop it in. if you yank on a CV still connected to the trans the stubs pull out relatively easily, that's not a big deal at all. do not bother thinking about replacing the seal there either, big PITA. if your stub doesn't have that circlip then maybe my memory is failing. either way, i've pulled them out and reinstalled them before and it's really easy, that's the bottom line. used Subaru CV joints are excellent candidates for replacement. the boot may break but the axles never do. i've had a couple 200,000+ mile XT6's that i've driven off road and lots of miles with broken boots and the only axle i've ever had break was a new (remane'd) with about 50 miles or less on it. i've driven the subaru axles 50,000 miles front and 100,000 miles on the rear with broken boots and clicking...but they never break (for me).
  3. or find a used 2.2 liter motor that doesn't blow headgaskets and be done with the 2.5's! then you'd be done for under $500. plenty on the board have done it. the 2.2 is a great motor (and i have one for sale by the way, shameless plug). it's cheaper, no head gasket issues, less time than a head gasket job...not a bad option. but a little less power. if you have the time/money/tools then go wtih the all out rebuild. drop the block off for a rebuild. if the block is okay, reuse it. any shop will rebuild the heads. i just had a set of 6 cylinder subaru heads done for $175 for a complete valve job, pressure test and machining. and that shop is not the cheapest around, but they do specialize in aluminum heads and have worked on subaru heads before. and i like them. do you know your block is toast for sure? block rebuilds are the real expense. you could look for a used block that doesnt' need rebuilt, and install your heads with new gaskets.
  4. how does exhaust gas reduce temps? the exhaust is post-combustion hot stuff right? will blocking a working EGR valve (not leaking) affect mileage at all?
  5. what does this affect? i'd like to do the same. don't you need to plug the hole in the head as well? does it affect gas mileage? always seemed weird that's it's only on one side of the exhaust?
  6. sorry jake, i was wondering if piston slap ever occurs with the 2.2 liter motor.
  7. are you positive of the year of your car? maybe check the date of manufacture to be sure of the month and year? your close enough that maybe you still have the cable?
  8. i don't think you have to worry about a fire. unless i'm not understanding you, the possibility of an exhaust leak won't cause any increased risk in fire. those exhaust studs and threads are annoying, i feel your pain on that one. good job with the quick fix though, that's hardcore. i like it. can you try welding over it again? i've patched exhaust before and nothing short of welding has proved long-term. if the patch holds up, let us know and post exactly what stuff you used.
  9. for safety make sure immediatley that the axle nut isn't coming loose like just mentioned. i don't bother with torque spec's on them, i tighten them as far as i can with my 3 foot pipe on the end of a 3/4" ratchet. there have been lots of problems with reman axles. go with subaru OEM axles or MWE. even used axles with good boots are a good option and inexpensive. the stock OEM axles are excellent and i've never seen one break. i am the victim of reman'ed axles breaking. it's crazy....the Subaru OEM 20 year old axles never break, but remann'ed axles do? i would inspect the cv's next and probably replace them if you can't figure anything else out. with vibrating, steering drift and noises, it could be alot of things, cv axles seem the best bet for causing all of them. check those, replace and post results.
  10. they have drawbacks as far as high output is concerned. subarubrat looked into turbo options and decided against the ER27T due to block design, cooling ability, oil supply, oil galleys, etc. for reliable high power, the EJ is probably the way to go. the EJ series mounts line up fine with EA series cars so i don't think the EJ would be that far off in the XT6. might have to take a drill to the existing motor mount holes, but that's no big deal. probably better off getting an EJ trans, but you could just get an adapter plate for your XT6 transmission so the engine bolts up. not sure if you'd have to move the trans forward to meet up with the trans, but if you did you'd have to have the driveshaft lengthened. if you stayed with the XT6 trans you wouldn't have to worry about the hubs, cv axle differences, drive shaft differences, swapping the rear diff and cv's, linkages. but the EJ is probably a better trans.
  11. unless you plan on addressing brake calipers, wheel bearings, cv axles, tie rods, ball joints, radiator, etc....basically any car that old will need work at some point. great cars, great motors but after time it is what it is, and older vehicle. getting a newer vehicle might be a good option. but the 82 is probably salvageable if you have the time and patience. when you do a ball joint, replace both. when you replace or repack a wheel bearing do them all. rebuild your brake calipers. do a job a month as preventative mainteance and they are cheap and reliable. and after a few months most major issues are addressed. you can pick up a good used motor for cheap. sounds like an EA81, shouldn't have a problem scoring a decent one on this board i'd imagine. EA82's aren't hard to come by at least. reseal the entire motor, repack any pulley bearings, replace the oil pump seals and water pump and all hoses and clamps and it should be golden. make sure the radiator and thermostat are up to par so it doesn't overheat again. sounds like a lot but isn't that much work for the result - a great motor that will last a long time. always great to have two vehicles though i know in college that isn't such a smooth option. good luck and have fun. keep your head up.
  12. NICE HIT DUDE!!!! that's great news. i have an impreza parts car, so let me know how the impreza goes or i'll try it myself at some point. i have an XT Turbo and XT6 i'd love to swap new impreza seats into. great hit information! thanks!
  13. if it helps at all the FSM testing procedures and values for the TPS of an XT6 are not right. no TPS on an XT6 will be within the specifications of the FSM. i'd expect similar results from late model 87 and up XT's. but that's just a guess. i had a troubling TPS issue once. car had trouble idling and wouldn't start on occassion. replaced the connector to the TPS along with about 6 - 8 inches of wiring behind it and all was well. i located the problem by grabbing the wiring harness connector that plugs into the TPS. i wiggled it, then gradually drifter back bending/ squeezing and rolling the wiring between my fingers. about 3 or 4 inches behind the TPS the car would do all sorts of craziness, stall, run right (for once), RPM's jump, not start, etc. replaced the wiring and all was well. at this point i think i'd swap in another TPS and see if that helped. and the ECU like you mentoined he's going to be doing. good luck.
  14. i'm a moderator of XT6.net and don't recall seeing that post. i guess i missed it, maybe you should make sure it's there though just in case? i've sent parts to the guys in NZ, could do the same for you as well. email or post a picture of what parts you need, i have a couple XT6 parts cars. make sure they are interchangeable between XT Turbo and XT6. i have an XTTurbo 1987.5 so i should be able to look and see. no RHD parts though. but blinkers okay. i'm super freaking busy but i can help you out if you get in touch with me. contact suber dave first if you can.
  15. you need these to pass inspection? i'm with the above comment, get something to work to pass even if it looks terrible. then get the right thing from the junk yard. they are obvious and easy to see from the drivers seat or standing next to the car without doing anything or pushing any buttons !! (good thought though, you never know on these nut case cars!) if you have trouble getting the exact thing i can probably pull one off my parts XT6 and send it to you, hoses and all. if the squirters are attached to the long plastic trim then i won't be able to ship that though, too long. don't know how they are attached, never removed one. i've already sent parts to two people in NZ....one day i'll send myself over there.
  16. you could have damaged head gaskets, but that's all speculation for now. start with what you know: are you loosing coolant? you said you had to add it, so it sounds like you may be. find out where the coolant is going. a leak should be obvious, particularly if it's leaking enough that you have to keep adding. did you add coolant to the radiator or the overflow tank only? any excessive coolant/water out the tailpipe or along any leaks in the exhaust at start up? replace the thermostat. very easy and costs under 10 bucks. test the old one in a pot of boiling water if you suspect it was bad. any leaks from hoses or radiator? maybe the radiator is plugged? if it happened while driving your fans are likely okay. after it heats up (gets too hot), does it bubble in the overflow tank? i may not be back on here for a couple more days, but answer these questions and the knowledgable folks here can help you pinpoint this and hopefully avoid blowing the headgasket.
  17. ha ha, good one! an honest guy...you should go post this at nabisco.
  18. i would just replace the tie rod ends, the steering racks have such a low failure rate it's not worth replacing without reason. that being said you can usually buy steering rack boots if those are broken and just replace them. i believe they are dust shields only and not critical. sounds to me like you only need to replace the tie rod end that will have a new ball joint on it. if there's something i'm missing, let me know. bad tie rod ends can fail and are one of the most dangerous types of failure. not trying to scare you, but i would replace them immediately if they look bad. try advanced auto parts or http://www.thepartsbin.com and check prices. if they are high, find a used unit. there are hunreds of thousands of 20+ year old subaru's with 200,000+ with the original tie rods still on them, used ones that are in good condition are a decent solution to known bad ones. post on here for used ones in the parts wanted forum. i and others have subaru's for parts. and if you can post pictures of the problem areas that's really helpful for the confused folk like me, i get suspension terminology mixed up sometimes.
  19. here's another similar thread ongoing right now: http://www.ultimatesubaru.org/forum/showthread.php?t=53225 i made some notes there on this subject. start simple like Nipper said - basic complete tune up first then move on. this site can help you out, one step at a time.
  20. my gas mileage went up a mpg or two in my 97 impreza after i did a break job. all was fine, i was just replacing the pads and wasn't doing the brake job for gas mileage reasons. i assume the caliper slides were a just sticky enough to make the pads ride on the rotors more than necessary. i took all highway trips before and after and noticed the difference as i always keep track of gas mileage on trips. regrease the slides on the calipers to make sure there's as little resistance on the rotors as possible.
  21. at 232,000 the fuel injectors are most likely dripping/leaking or not up to original performance. i'd have them rebuilt. others have posted rebuild results here and i have my sheets. unless they're making the numbers/data up then there is significant improvement after having 200,000 mile injectors cleaned. i send mine to RC Engineering, about $20 - $25 for each injector. there's another company witch...something or another that does them for about half the price. these companies completely rebuild them and give you before and after test results of flow characteristics. fuel injector cleaner might want to try that first if you don't want to spend the time/money on a complete rebuild. also replace the distributor cap/rotor O2 sensor check tire pressure installing new ground wires can be beneficial if the connections are dirty, rusted or corroded at all. do a compression test, at this mileage you could have some loss of compression, though 20 is really low for highway mileage. 20 mpg might be about right for auto, city driving, lower compression due to age, AWD trans....etc. here's another thread on the subject: http://www.ultimatesubaru.org/forum/showthread.php?t=53219
  22. make sure the coolant is full and no air in the system. could the radiator be plugged?
  23. there is a company that sells a device to splice in-line with the shift resistor. they market it for the SVX i believe, but it'll work with a wide range of 4EAT's. i think the idea is that it bypasses the resistor at certain times. basically it's a marketing tool that makes money off the option of disconnecting the shift resistor entirely. that device seems more than needed to me. better option is to disconnect the shift resistor and if you don't like the way it shifts, reconnect it and leave it stock. mine are always disconnected, shifts much better. it's harder and firmer shifting but feels much more solid to me. there's even been discussion a long time ago that it's better for the trans because the clutches engage quicker without it. doesn't feel as cushy, but it's quicer and firmer, leaving less time for the clutches to wear. but that effect is certainly minimal whatever it may be. i haven't payed much attention to the newer models though. i don't think my impreza does it as bad as the XT6, i'll try it on my impreza if i remember. we've discussed, posted pictures and stuff at http://www.xt6.net before, i'm guessing there's info on it at usmb as well? this probably isn't the cause of his problems, but something to look at if it is a 2-3 shift issue. if the resistor is bad you can isolate the problem by disconnecting it.
