Everything posted by Tiny Clark
Hello to you! / car break in period?
Tiny Clark replied to Zephyr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXQuit worrying and drive it, it will be fine.
Spark Plug Installation Question
Tiny Clark replied to rem14's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUsing copper on aluminum is an aerospace vehicle no-no.
Oil Spray on your rubber gaskets
Tiny Clark replied to Matt831's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you use the Outback to hunt down King Crabs?
When braking legacy pulls to right..
Tiny Clark replied to scottw's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave it aligned before jumping to conkluzions.
Tiny Clark replied to rem14's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo.
Type of AT drain plug
Tiny Clark replied to danz75's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's why there is a drain plug, so you don't have to EFF with the pan.
synthetic oil
Tiny Clark replied to ctstriper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBULLLSHHHHITTTT! Do whatever you want. Modern engines use tapered rings, so break-in is not an issue. So you spend 5 to 10 bucks between oil changes! Wow, that's a six-pack of a good locally brewed beer!!!
Antenna Up - How? 1996 Legacy Wagon
Tiny Clark replied to ejmoore's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.visegrips.com just kidding... pull the hell out of it
E Brake dummy light
Tiny Clark replied to charm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you sure it isn't the "low fluid" warning light? I know, stupid question...
Tire Dressing?
Tiny Clark replied to Midwst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRub some brake fluid on them.
No Chilton?!!!
Tiny Clark replied to Lawsonmh15's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry the Paris Chilton, it goes every which way, and loose!!!
FWD fuse and AWD Legacys
Tiny Clark replied to ringe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's close to the firewall on the passenger side of the engine bay.
non interferance
Tiny Clark replied to Midwst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubies use a hydraulic tensioner. If it is a son-of-a-beast to compress, it's still good.
Its the dreaded head gasket, isn't it?
Tiny Clark replied to ILLIFIED's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think one of the major problems of a small head gasket leak is that if you do something you think will fix it, i.e. thermostat, you fill the car back up with coolant/water and everything works fine until you loose enough water for it to start heating up again. I think if you added coolant on a regualr basis, you could run it for a while with little problem. Too bad small leaks turn into big ones...
oil overfill?
Tiny Clark replied to Midwst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI seriously doubt it.
Auto shifter won't come out of park!
Tiny Clark replied to swi66's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOut of all the cars I've owned with A/T, I can count the number of times I've used the parking brake on one hand.
Valve clearance meas. question?
Tiny Clark replied to Beltfed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBetter 2 be loose than 2 tight.
Clutch fluid overheating? What happened here?
Tiny Clark replied to syphon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's why auto tx's are good in the city. Move, I hate frikkin' traffic!!
Oil Pump Replacement, No Pressure! 96 Legacy 2.2
Tiny Clark replied to jkmason's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAt least ya figgered it out.. gitter done!!!
Tiny Clark replied to jkmason's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo more than a few seconds, especially if you fill the filter first. This doesn't sound good. Are you sure you didn't block an channel on reassembly?
2002 Impreza RS 2.5 A/C Problem
Tiny Clark replied to tdorman55's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat about defrost mode? Does it put out cold air at the windshield vent. Maybe the air deflector door is screwed up...
What brand of oil do you use?
Tiny Clark replied to swc7916's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis goes back to the point that the oil companies and car manufacturers are always looking for ways to improve products and reduce waste. They aren't always out to get us...
Any good Ideas to past an E test.
Tiny Clark replied to turbo92subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMake sure the rubbing alcohol is a high percentage rating. Some off the shelf stuff is about 70%, the other part being water.
AC control question
Tiny Clark replied to Skip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust curious, but what turns on the A/C? It seems to me it could easily be bypassed, but I have no diagram. A switch in parallel with whatever turns it on now should work.
Tiny Clark replied to swc7916's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it meets the current API standards and you change it regularly, then whatever you choose should be OK. I use Castrol myself. Or, you could go check out bobistheoilgod.com, or whatever it is, and see what he recommends.
