Everything posted by Tiny Clark
Alternator Repair
Tiny Clark replied to QuackAttack's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs the recall dead on this? I had mine changed under the recall about 2-3 years ago. Here's a simple load test you can do. Start the car, remove the negative battery cable. Turn on the headlights, heater fan on high and flashers. While the car is running, if it still is, run the tach up to about 4 grand. If everything runs OK, your alternator is fine. If not, it's Tango Uniform.
buzzing sound with ignition on, engine off and depressed gas pedal
Horsefly under the gas pedal? Yea, best bet is locate it while it's doing it, with length of rubber hose to the ear or a stethoscope.
Sad and uncomfortable
Tiny Clark replied to dande's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmmm, maybe Toyota can figure this out too...
need to get more MPG in my '96 Legacy L 2.2 Liter w/ auto trans
Tiny Clark replied to Bright1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMay be time for new plugs, filter, O2 sensor.
car no start...just a click
Tiny Clark replied to Adam Lee's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFords had an external solenoid (I kinda like that idea), your Sube's in is the starter. You can replace the contacts; get them at a starter rebuild shop. I used to have directions and pics, but lost them to a computer mishap. You can always take the starter in to have it done as well. No reason to buy a starter.
GM selling it's stake in Subaru...
Tiny Clark replied to unverviking's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMaybe Subes won't have any more serious problems that they don't want to face up to in the future, like bad head gasket and clutch design, or smarter places to put cup holders and parking light switches
power steering vibration?
Tiny Clark replied to derekd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you ever changed the fluid? Not that it will fix it, but the fluid is probably shot anyway.
tire pressure
Tiny Clark replied to 97OBW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy only problem with running what the car has posted on it is that the outside edges of the tires seem to wear faster. The car manufacturers always take ride softness into account, so a little less pressure yields a better ride. I stick to 32 all the way around.
RPM and MPG
Tiny Clark replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou can also increase your mpg using a siphon hose...
1996 Outback: 16" Wheel upgrade. Worth it?
Tiny Clark replied to Len's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust remember that if you have 225/40-19's instead of 195/65/15's that when you have a blow-out, the volume of air in the 19"tire will be gone in a micro-give-me-crap. That, and the tires in ever expanding rim sizes are more expensive. Will the handling be better? Of course!! Ideally, a half inch of silicone on a flat 22" rim would offer great traction, but you'd feel every earthworm and dime you ran over!!!!
RPM and MPG
Tiny Clark replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think most EPA estimates are based on 55-60 mph.
So many Questions...
Tiny Clark replied to johnnyk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour only problem is the Legacy was designed for the road. If you went up two wheel sizes from 14" to 16" you 'd only gain an inch of clearance, then maybe another inch at the most with higher profile tires. I don't think that is what you are looking for. If you win the lotto, you could buy a real hummer with the military ground clearance, not that piece of crap they are selling at the dealerships.
I want my thermometer to read in °C not °F!!
Tiny Clark replied to kevinsUBARU's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXActually, a 2x4 is 1-1/2 x 3-1/2, and has been so for many, many years, mostly to save wood. Same as a 4 x 4 is actually 3 1/2 each way. Wood won't shrink that much when dried. We screwed the pooch when we didn't go metric in the early 70's, and from what I understand, it was the auto and building industry that was holding the tail out of the way. I love the metric system. When I go back to the states and have to look at the odometer, the miles go by sooooooo damn slow. And I love my metric vise grips...
Added another to the list of things carried in the wagon
Tiny Clark replied to outback_97's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI carried a restaurant style Bitburger Pils umbrella home (an ebay purchase), and it was 2" away from the windshield after I got the back door closed with the pipe resting against it. Nice armrest, kinda high tho...
fuse problem
Tiny Clark replied to thegnman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMB2 is the accessories. Do you have something plugged into the lighter jack, or you have a googlelaphonic stereo?
Help, temp gauge pegged to top after shop visit
Tiny Clark replied to serotta50's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf they filled it all all...
Legacy fluid changes
Tiny Clark replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSince I switched to a Fumota vave, I don't worry about it on the subie. But, and my opinion differs from most on this board, I've never used a new washer on any of my cars for the oil pan, and I've never had a drop out of them.
Locking the Engine with the Flywheel access hole
Tiny Clark replied to Dickensheets's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDanke, dudes!
why does my ABS light trigger after 01 outback sits idle for a few days?
Tiny Clark replied to scarfire's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRust?
Tiny Clark replied to Dickensheets's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhere is this plug located on the EJ22?
Help! My Legacy wagon rear hatch won't open!
Tiny Clark replied to Brettm57's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can adjust the rod length and make it a permanent fix.
96 Outback radio?
Tiny Clark replied to subaruba's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can get a decent CD player for 100 bucks.
Cruise control not working in '98 Impreza Outback Sport
Tiny Clark replied to tbrickn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had a Ford Van and if one of the brake lights was out, it would cause the C/C to quit working.
Fuel Filter location(s) 2000 Legacy.
Tiny Clark replied to mtsmiths's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXStill on the first filter after 123,000 miles, and going strong.
Urgent: Tranny Advice!!
Tiny Clark replied to Midwst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe only question I would have, or at least a point to ponder... Why was the system flushed at 155k and had it been done before, or was it the first trans fluid change? Go with your gut feeling, but that is a lot of miles on any tranny, especially if it wasn't serviced properly. Does it have a hitch on it? If so, it's been used to tow, so more life off the tranny.
