Tiny Clark
Everything posted by Tiny Clark
This has been said by myself and others on this board, and I will repeat it once more. The easiets way to check for spark is to use an extra spark plug, new or old, doesn't even have to be for your subie. Find a good piece of metal (ground) on the motor and clamp the plug to it with a pair of vise grips. Pull one (or all) of your plug wires off and connect them to the test plug. If you have spark, then it's a fuel/air problem. Tiny
I would suggest splice connectors for 2 main reasons. You already have a heat problem, so solder is not a good choice for these wires. Rosin in the solder can also cause corrsion at the solder joint. When properly done, crimp connectors do a very good job, and can be sealed up using silicone or heat shrink.
Hub Tamer
Tiny Clark replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I only use domesticated hubs, so I don't need the use of a tamer. -
I don't like the motorized seat belt for the following reason: My son's car has them, and I find myself forgetting to put the lap belt on because once the shoulder belt comes up, I "feel" like I'm belted in and forget the lap belt. I learned to drive in Germany way back when, and belts were required so I have always used them. I like to think that if people aren't smart enough to buckle up, they deserve whatever they get. Only problem with this rationale is that if they become paralyzed or suffer drain bamage, then they get stuff paid for by us belt-wearing folks in the form of taxes.
These Gemans on the autobahn over here must have the formula. On my way to the airport this morning, it was raining and extremely dark, and I was being passed by people going over a hundred mph. Or, maybe they use the formula that has a multiplier of stupidity in it... My formula is: If the road is pretty wet, slow down!
If you have a mechanical clutch, there should be about an inch of loose play on the pedal before it starts to engage the clutch. If hydraulic, maybe there is air in the system, but even with that, it wouldn't be engaging your clutch with no pedal pressure. There is an addition master cylinder under the hood for the clutch. It should be on or near the driver side firewall.
It could be your throwout bearing. A bad bearing will make a squealing noise just as soon as the clutch is engaged. How many miles on it? The bearings will usually last quite a while, but that depends on factors like holding the clutch pedal in at stop lights. Maybe it wasn't greased properly at the factory.
