Everything posted by NoahDL88
With a pulley, yes, its a 6000 lbs winch, but if its designed for 3000 pounds I don't foresee it lasting too long without the cable snapping
Honestly i'd be more worried about if your winch is even capable of pulling your car out. If you get so stuck that you need a winch you'll be fighting more than double the weight of the car. At a very minimum I'd wager a 4500 would be as small as you really want to go, a 5000 or 6000 would be better. I'd also go 1/4 inch, If you don't have a welder that will penetrate 1/4" I'm sure there is someone else on this board near you with one that will. Now that I think about it, 3/8's might be better.
The wiring, if done by someone else and shipped to you isn't terribly bad, I would recommend pulling the harness, and having it cut down, and then with the engine still in the original car, try getting it running, after that its all pretty much easy.
+1 on the write up, if you can't do about 90% of the swap without supervision then its probably not the project for you. Wiring will be the hardest part, study that and be sure you want to tackle it before you start.
wagon to ute/pickup conversion?
NoahDL88 replied to LPGsuperchargedBrumby's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I can see that going over well, Dear Subaru, I'd like you to make a car that you just recently took out of production because it's sales volume was poor. Sincerely, My newest Subaru is already 15 years old and I won't be buying a new one ever. PS, every model should only come with a 6 speed dual range and a turbo. -
Waterwagon 3 Build-up, and the SJR+EJ Lift Thread!
NoahDL88 replied to Ratty2Austin's topic in Members Rides
Red on black does venom lack, Red on yellow will kill a fellow. Nice driveshaft by the way -
engine swap.
NoahDL88 replied to ellets's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Your Leggo is a 94 at best, the 95 was not offered with a turbo. I'd recommend against it, the non turbo has higher compression and will not run well with the turbo, and it doesn't have oil squirters to keep the pistons cool. Unless of course you want to make it a non turbo, in which case I'd suggest selling it to a Subaru enthusiast and getting a non turbo car instead. It would be a shame to loose another turbo. -
diesel motor into brat
NoahDL88 replied to mvpickup's topic in Historic Subaru Forum: 50's thru 70's
I don't think the Vanagon ever had a horizontally opposed diesel engine. Edit, It came with an inline. I think your best bet would be a 1.9 diesel out of a rabbit, or other small VW cars. I won't bolt in and the fab would have to get creative, and I'm pretty sure the top of your engine will be sticking out of your hood. -
Not with a turbo they're not. I'd even worry with a 2.5 if you're using a 2.2 or a 1.8 harness
What to get on my License plate?
NoahDL88 replied to suberdave's topic in Old Gen.: 80's GL/DL/XT/Loyales...
In Michigan I had USMB -
What timing belt did you end up using?
Overheating, especially in these swaps can be common if you really flog your car and is a sign that the radiator isn't radiating enough heat fast enough to keep up with the engine. By putting in a lower temp, 10 degrees? you just delay the inevitable. Look at the stock radiator on a Legacy and you'll see that the entire thing is covered with 2 large fans. If the same amount of CFM is not used on your swap you will surely overheat.
Its normal, not to worry It was not without reason he was banned, nuttier than squirrel poop
If you have no heat you have no coolant. Put the front wheels up on jack stands and open the bleeder and the radiator cap and run the engine with the heater on. Add fluid until the coolant that bubbles out is warm. If the radiator never gets not the thermostat never opened and you only filled it half way. Could also be that it has a blown head gasket, clogged hose or muddy radiator.
