Everything posted by NoahDL88
	More info please Did you take off the intake manifold? do you have your heater lines hooked up if you pull the plugs is the cylinder full of water? did you pull the freeze plugs to pull the pistons? Have you had the heads off?
	Where do you go offroading? What are the regulations about going offroading over there? And most importantly, can I import a car from America to Israel? If i move over there that would be an important determining factor.
	Ask him if he's replaced the turbo on his 6.0 yet, then ask if he minds going in every 3-5 thousand miles to have it cleaned (half a day procedure) so that we can fix his hesitation problem. then ask if he's ready to have it down for a week while they replace the high pressure oil lines. then, for the most important question, ask if he'll be ok with all this after its out of warranty. There is a reason i work on fords and drive Subaru's. I like the job security, and i don't want to be late for work.
	Maybe the devil needs something reliable with 4wd to carry all the evil souls around in. If you had to spend and eternity with just 1 car, a brat is probably a good choice.
	could be the gasket between the transmission and the t-case, the t-case being the back 6 inches of your tranny. maybe its got a hole in it, or the drain plug is loose/gone?
	Could be the engine's temp sensor, if its reading warm, it won't go into cold start enrichment mode.
	Avoid hydroscopic body fillers, they absorb water and harbor rust, use professional body filler, its better as it doesn't absorb water, and won't create new rust problems.
	Here's the solution
	Its got some data recording functions, havn't really played with it much, but it does have a computer interface so i'm hopeing i can export stored data from it onto the computer where it will be easier to read. I still need to figure out everything it can do, but so far it seems to be a good mix of not too expensive, but still usefull enough to actually do real diag with, as opposed to just read codes.
	My .02 is that your battery is toast, check your battery voltage, engine off, if its below 11 volts, its draging your voltage down as its so discharged that your alt can't keep up. worst case it will fry your new alternator. I've had this happen at work a couple of times. Also make sure your battery connections are good, tight and clean, also your fusible links should also be clean and tight. Check for resistance between the battery and the frame, and also from the battery to the alternator power terminal.
	Should be able to lengthen the shaft like on the 3 inch lift from PK, you will also need to extend the brake lines, and a few other wires and hoses to make everything work.
	I went from SPFI to weber, to weber on a built EA-81, what am I running now? the EJ22, the SPFI was great, and had there been a new EA-82 underneath it with good compression, i might have had a good running rig, but i meddled, and put on a weber, so that when i put in the EA-81 i wouldn't have to redrill the distributor, well, going from SPFI to weber was the biggest mistake i made in my subaru journey. i've not gone from a hitachi to a weber so i can't say anything about that, but it would seem anything is better than the hitachi. The weber is great, but it won't fix engine problems, will get less fuel economy unless its tuned right, and as Snowman said, there finiky on cold days. If you have the time and the patience, i'd say an SPFI swap is a better choice, or even the EJ22 swap.
	Hate to poop on your popcicle, but the engine has plugs that allow the pistons to be pulled without pulling the motor, and the body has holes that allow the head bolts to come out for the same reason. "amatures" tend to pull more than they need to, which makes the final job easier, but takes much more time, professionals pull as little as possible, and are only slightly inconvienienced by reparing heads and possibly pistons in car. And really the piston isn't really bottom end is it? i mean, theres no bearings on it are there?
	I have a red top in my 88 EJ swapper, and it went through cranking for a few weeks when i was trying to get the wiring right, and when i finally did, it caught on the first revolution. when i get a winch i'll probably get a yellow top, just cause it makes sense for the winch, but i've had nothing but good luck with the red top, that and the spec batter comes with 450 CCA and the red top is 950. sure helps on cold mornings when you want to move the car around the block on starter power.
	Have them boroscope your cylinders to see if you have bent valves, won't be 100% but they should be able to tell if anything major has broken or bent. 750 for timing belts had better include seals, waterpump and an oil pump reseal, thats kinda steep for just the timing components It does sound like you've jumped timing, and have bent valves, at least in one head, so it may be better to take that 750 and put it towards a new motor.
				floorboard insulation source?
NoahDL88 replied to diluded000's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've heard great things about Raamat, and i believe he's on Nasioc, and owns subies.
